Author Topic: JMR billet block build with RSC 970 transmission  (Read 7251 times)
Online PeWe
Re: JMR billet block build with RSC 970 transmission
« Reply #75 on: April 02, 2025, 08:18:20 PM »
Looking good, head and cylinder as one ;)
Offline newday777
« Reply #76 on: April 03, 2025, 01:16:25 AM »
Yes it sure is very good looking. I was late coming along to the party to learn of the making of the billet block to get one. 😪
Stu
My current rides
Prior bikes....
Online PeWe
« Reply #77 on: April 03, 2025, 04:11:59 AM »
Will post a Dyno video soon in the chassis with TMR carbs and HRC 4-4 Daytona exhaust
Oxygenated race fuel?
>110Whp is the goal? ;)
« Reply #78 on: April 03, 2025, 05:31:15 AM »
I'd 110 RWHP is a reasonable expectation Per and I don't think it will need designer fuel...it has enough compression, cam etc. Oxygenated fuel could add up to 4 HP increase. Torque should be interesting.
Online PeWe
« Reply #79 on: April 03, 2025, 09:22:18 AM »
I look forward to see the graph!
It would be fine if we could have higher octane here. Shell V-power is around 98RON. 100 would be fine as I have seen in southern Europe.
My K6 is not far from pinging.I thought I  think I heard a little yesterday when twisted a  little on 5th gear from lower speed. Could have been something else.
Last year when needles where 1/2 step lower and main jets  one step of 2.5 smaller it was very clear.
 Not jet too rich to avoid it.  It is correct now.
Higher octane  would be better.
I'm sure 110whp will happen, if not small adjustments can do it.
I run my 125-75 with 0.004/0.006" valve lash. 0.10/0.15mm
I have seen before that smaller lash can reduce the compression. But that was with a  DP315 cam
Offline Tracksnblades1
« Reply #80 on: April 03, 2025, 02:51:59 PM »
Does your Shell V Power have ethanol in it..? Or is it straight gasoline..?
Locally, 25 miles away,  we have a VP gas station that has pump dispensed high octane gasoline ranging from 95-113..
It near the MarkTwain lake. Servicing the multiple engine go fast boats that frequent the lake.
The 100 octane gasoline is $8.50 a gallon..I’ve used the 95 and 100 in our Honda CRs ranging in sizes from 85cc- 500cc.
Besides being really forgiving starting cold or hot I don’t notice a big difference in performance. The CR125 and 250 seem to have more low end torque on steep trail and hills.. My son insists on the 100 octane so that’s what I usually purchase. We don’t get to go as often as we like so we don’t worry about it setting in the can for a month before using it..
I’ve read your Shell V Power needs less timing than our Shell 93 on this side of the pond…
Have you noticed any performance gains with slower timing on you side..?
Age Quod Agis
Online PeWe
« Reply #81 on: April 03, 2025, 08:36:57 PM »
Shell V-Power has 98 or maybe a little higher when they specify >98 RON, see pdf below. Max 5% ethanol, maybe less.
It was +99 before, maybe 15 years ago.
I have tested various ign setting.
The advancer unit has cut springs which is a must for stable idle and evenly running engine.
Verified the real TDC. The advancer must sit most counterclockwards in its play before tighten it.
I have an additional mark (ca 3mm to the right) on block if advancer sit in it most clockward position.
It runs better when marks lines up at 1200rpm when adjusting the ignition.
Not later or earlier.
Dyna-S and Dyna 5 ohm coils.
Same with my stock K2. It need cut springs too. The loop that fasten it on one side is cut, bent out a new and shape with pliers.
« Last Edit: April 03, 2025, 08:45:42 PM by PeWe »
Offline bigutah
« Reply #82 on: April 04, 2025, 06:22:15 PM »
Pretty stoked on this find for the build.
Online PeWe
« Reply #83 on: April 04, 2025, 09:40:35 PM »
Too good to be used?
Offline bigutah
« Reply #84 on: April 05, 2025, 03:07:19 AM »
It gets painted and goes right on the bike.
Offline bigutah
« Reply #85 on: April 05, 2025, 03:20:37 AM »
What’s better than having one JMR block? 2!
Full new kit too, Pretty wild stuff.
Offline simon#42
  • liverpool
« Reply #86 on: April 05, 2025, 03:51:35 AM »
yes . no use in a box , it was made for a bike so put it on a bike!
Online PeWe
« Reply #87 on: April 05, 2025, 05:24:45 AM »
That's good stuff!
72mm or 71/71.25mm?
« Reply #88 on: April 05, 2025, 05:28:10 AM »
That's good stuff!
72mm or 71/71.25mm?
71.25 with the unobtanium piston rings.
Online PeWe
« Reply #89 on: April 05, 2025, 07:06:56 AM »
That's good stuff!
72mm or 71/71.25mm?
My accident when I pinched ONE flimsy oil rail made me to order a complete set of 71.25mm rings for 4 pistons was sheer luck then!
The shipping price was high, rings cheap, $25US/piston so better to order 4 sets.
I have my old rings as spares.
I guess it must be rings out there. Dynoman and Summit Racing had early 2017.
Offline newday777
« Reply #90 on: April 05, 2025, 12:35:04 PM »
WOW!
Stu
My current rides
Prior bikes....
« Reply #91 on: April 05, 2025, 12:45:00 PM »
Good for you for putting part of Keith's huge unobtanium stash to good use. RIP Keith
« Reply #92 on: April 05, 2025, 03:40:27 PM »
1 year ago April 3rd Jerry.
« Reply #93 on: April 06, 2025, 08:06:09 PM »
Big U-Tah,
Got any picture of Kenny’s Magic Windows Artwork…?
Curiousity and the Cat..
Your build looks great and Top Notch…😇
Age Quod Agis
Offline bigutah
« Reply #94 on: April 18, 2025, 09:24:15 AM »
One expensive ass chunk of metal.
Planning on reassembly Monday.
I’m sure I could dig up Kenny’s magic window work somewhere.
Offline newday777
« Reply #95 on: April 18, 2025, 06:11:19 PM »
Nice chunk of metal
Stu
My current rides
Prior bikes....
« Reply #96 on: April 19, 2025, 04:27:07 PM »
 I could see me wrapping that in bubble wrap, a big bag, brown paper, cardboard, plywood and several ratchet straps! Precious metal indeed.
« Reply #97 on: April 20, 2025, 04:47:48 AM »
Following along for the bike porn  8)
Offline bigutah
« Reply #98 on: April 23, 2025, 09:59:29 PM »
Picture update
Genuine RSC tank is getting paint. Will
Post soon. Long days cutting grass.
« Reply #99 on: April 24, 2025, 04:54:19 AM »
You must be getting excited.👍
