Author Topic: Rescuing a '78 CB750F SS  (Read 9566 times)
Offline toomanybikes
Re: Rescuing a '78 CB750F SS
« Reply #25 on: May 26, 2025, 12:11:38 PM »
UPDATE - With the carbs now clean and new OEM float valves, today marked the first legit test start.
I mounted the carbs but not the airbox so I could more closely monitor fuel leaks. Yes, I did do a bench test first. There were a few leaks on the bench, but they seemed to be improving as the gas swelled the old orings. Carb 4 still has a small leak coming out the bottom, so I'll monitor that. I did not totally de-rack the carbs based on input from another thread. As long as the fuel tubes don't leak I'll keep the assembly intact.
To test the openness of the slow jet, I fitted a fuel tube over the jet (shown below) then sprayed various fluids (carb cleaner, kroil, alcohol) into the tube letting them soak until the fluids ran through the jet ran freely. Compressed air helped the process.
The bike now starts and runs consistently, but since the airbox is not yet installed I have to constantly manipulate the choke to limit the air flow. Cyls 2&3 got nice and hot, but 1&4 were just warm. They have good compression and spark, so it must be a fuel/air issue. #4 might be too rich due to the overfill described above.  I'll mount the airbox next session and see if the full system & time fixes 1&4. If so, I'll move on to brakes, tank, tires, chain, etc.
« Last Edit: May 26, 2025, 12:13:56 PM by toomanybikes »
current stable, always subject to change ...
'22 MG V85TT
'19 Triumph Scrambler XC
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #26 on: May 26, 2025, 01:21:54 PM »
 I believe the pilot air circuit pulls air through one of the bleeds in the opening at the air filter end, it goes past the idle screw valve, pulling air and fuel through the jet and its emulsion tube holes, it then gets pulled into the venturi near the slide notch. Carb cleaner and air can be used in any/all of those openings to be sure they have flow.
  I'm sure something I wrote is technically incorrect but that's my thought process when cleaning the carb idle system.
  I like the float valves with the little screens on top, I've used the ones for F1 in a similar numbered K6 carb. I'm pretty unfamiliar with the 77/78 keyhole carbs though.
« Last Edit: May 26, 2025, 01:27:22 PM by Don R »
« Reply #27 on: July 17, 2025, 02:40:34 AM »
UPDATE - She's getting close. I'm now just brakes and a clean tank away from a test ride. The tank and front brakes will be tackled this weekend, but the rear brake remains a challenge.
The original m/c is frozen solid, as is a replacement bought from a parts bike nearby.
If I can't get either moving I'll have to look for a third option, either legit CB750F or one from another bike, preferably another Honda. Any suggestions?
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
Offline newday777
« Reply #28 on: July 17, 2025, 04:13:32 AM »
I saw your wanted ad for the rear caliper and master cylinder and posted a link on using a grease gun to free up the stuck pistons.  Have you tried that? I was successful in freeing a spare 78F rear master and caliper that were both stuck this way. Let me know if it works for you or not...
Hydraulic method to free master cylinder (and calipers are done the same way)
Did you get it running properly from your idle circuit cleaning tube/concoction mix?? You didn't say any more on it above.
If not, this is a great write-up and pictures of properly cleaning 78F carbs and the accelerator pump circuits so it will run the way it should.
78F carb cleaning thread
Stu
My current rides
Prior bikes....
« Reply #29 on: July 17, 2025, 04:34:25 AM »
Hi newday,
It is running and idling proper now, although a few of the float bowls have occasional leaks I need to resolve.
I haven't yet tried a hydraulic approach to freeing the piston, but will do that soon. Thinking through that, it may also free up the master  cyl if I can cobble together bolts and lines to make the fluid pressure from a good m/c apply pressure to the bad one. Conveniently, I have a BMW R1200RT project with front brake/ABS issues, so that functioning master cyl may provide the hydraulic source for freeing things up.
BTW, here are the latest pics, with some of the chrome polished and decades old grunge removed from the sprocket area
« Last Edit: July 17, 2025, 04:38:29 AM by toomanybikes »
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
Offline newday777
« Reply #30 on: July 17, 2025, 07:21:08 AM »
Good progress 👏
Stu
My current rides
Prior bikes....
Offline Dime
« Reply #31 on: July 17, 2025, 07:24:20 AM »
Looks great. Great work.
Sent from my SM-S721W using Tapatalk
Offline kap384@telus.net
« Reply #32 on: July 18, 2025, 09:53:15 AM »
Looks great!  Good luck on brakes.
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
« Reply #33 on: July 24, 2025, 07:28:32 AM »
Rear end taking shape. New chain (with one link removed), cleaned up the sprockets and guard. Haven't yet cleaned up the shocks or center stand.
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
