Author Topic: Super Cheap 1975 CB750 $150 rummage sale special  (Read 3250 times)
ElCheapo
« on: September 03, 2005, 08:12:34 PM »
I am new to this forum but I figured open forum was best for this subject.
Just the other day I was looking for new project and was on my way to the locksmith to have an ignition for an old Bridgestone rekeyed. As I drove by on the main street I looked down the back street and my head almost spun around as I saw bike sitting in what looked like a rummage sale. I had always heard about deals like this happening but had never had the oportunity happen until now.
I raced around the block at almost double the speed limit to get to this bike. When I pulled up I knew immeaditely that it was a CB750 four. Not in bad condition. As I walked up on the bike I figured that it was going to be long out of my price range. I walked up to see a hand written tag on note paper with a $200 price tag ;D and some notes about ignition switch - wiring problems - needs battery taped to the gas tank. The only thing that I could see outwardly that the bike needed was a set of tires because of weather checking and a seat if one was to be picky. The owner approached me and we talked about the bike. I prodded at it a bit and with nerves of steel I said "would you take $150 right now?".......... There was a pause, he consulted with his wife for a second and returned with yes.  ;D ;D ;D I almost fell down. Still with nerves of steel I inquired about the title, keys, the box of parts next to it including a full front fairing. Trying hard not to see to anxious I shelled out the $150, collected the title and the keys and told them that I would be back for it in about an hour. I was driving my Toyota Corolla at the time so you see the problem. Fortunately the bike was only four small city blocks from my house so I decided to get a ride back and retrieve the bike and push it home.
About half way home I thought I was going to have a heart attack. I smoke way too much to push a heavy bike even though I am not in bad shape. Anyway got it home and located a battery for $35.
Not able to wait I started cleaning the bike right away and figured I would get the battery later. Like a good "new bike" owner I checked the oil and filled her up. MMMMM did I forget to mention it was on the small kickstand? (the room full of veterans erupts in laughter). For reference, I had a bit of a mess later when I did get it to start. Read on.
Setting up the battery was not a surprise that I was ready for. Having to fill the battery and all that. Far cry from getting a car battery. Anyway after I got the battery all set up and installed I inserted the key and turned it------nothing. Not one light. Nope, nothing nada........
After some mulling around I traced the hot wire back to the ignition switch with the trusty DVOM. Ok have power at all the points that I was supposed to????? Plugged the switch back in and voila LIGHTS... Dirty connection I think.
The right hand controls where shot (like no start button) so I jumped the solenoid and the the starter spun to life, but it would not start. I stopped to remove the air box (lots of swearing) and sprayed carb spray into the carbs. Hit the solenoid again and a little rump..pump...bump... Ok getting close...
Removed the fuel tank real quick and double checked all of the connections for the coils. Cylinders 1/4 coil ground was unplugged. Plugged that back in. Reinstalled the tank and put more fuel in it. OUCH! OVER $6 for two lousy gallons. Got everything back into position and tryed to start again. This time it roared to life sounded pretty impressive to me. Only it would not idle not wind up right. Spraying carb spary in the two middle carbs the motor stumbled. Spraying carb spray in cylinders 1 and 4 had no effect.
Ok it was running sort of... Time to regroup and get to the books. A quick look at the schematic for the bike which I found on this site! I saw that there was two sets of points. It did give me a rosey feeling to know that 1 and 4 where dead and it was a great possibility that the points were to blame. Remember I have never worked on one of these bikes before.
Removed the points cover and gave the motor a turn with the kick start and saw... guess what... youre right the points were not opening. Spec was supposed to be like .016 for the points. I static set the 1/4 points at .016 and tryed to start it. It ran, but still not hitting on 1 and 4. Recheck the points on 2/3 it was set to .027. So I set the 1/4 points to match. Crossed my fingers, turned the key and stuffed my screwdriver into the solenoid jumpping the terminals and the bike cranked a few times, cleared and roared to life. The tone definetly different. Almost scarry. However what was much more disturbing was the fact that the bike was pumping I mean PUMPING :o :o :o oil on the ground. After trapping the exxon valdez slick in the driveway I rechecked the oil and found that it was grossly over full. MMM? I wonder what dummy did that?  ??? ::). Drained the oil back to the normal level and restarted the bike. All was well and it was time for that test ride.
The test ride was a success. The bike rode nicely and sounded very normal. Great power and idle. Now it's time to fix a few aboriginal lighting hacks on the bike and it is complete.
Thanks for reading hope you like. At the very least the dumb look on my face when oil started pumping out of the bike was priceless for anyone who was around to see it. LOL.
Re: Super Cheap 1975 CB750 $150 rummage sale special
« Reply #1 on: September 03, 2005, 08:32:17 PM »
The only thing I can say to that elCheapo is welcome to the forum you lucky sod.
You will be pleased to know that your $3 for gas would'nt buy you 3 liters in the UK.
Good luck with the bike and safe riding.
Regards Sam.
Offline 74cb750
« Reply #2 on: September 03, 2005, 09:35:34 PM »
Kool story. Can't beat the price. If you are not too busy could you come over and figure out why mine is still sucking air and skipping at all rpm's?
Wellcome to the club.
michel
Laugh at least once a day.
Life  $ucks, then you die.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #3 on: September 03, 2005, 09:37:37 PM »
Great story :D
Sounds like you will get to know her real well over the next few weeks .....months........years.......
Ride and Smile.
bike54
« Reply #4 on: September 04, 2005, 02:30:06 AM »
hi el chepo
welcome to the forum liked the story what a deal i think you should change your name to something like lucky enjoy the bike it sounds like a good one
merv
Offline KB02
« Reply #5 on: September 04, 2005, 09:47:55 AM »
Well done, ElCheapo!!! Well Done indeed! I got my 76 CB705F for the same price, but mine needed a little more work to get it going (still does). Actually it ran fine, but there was problems with the Tranny that required an entire engine tear down. :P :P :P Sounds like yours is better off. Enjoy!!!
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline mcpuffett
« Reply #6 on: September 05, 2005, 06:33:48 AM »
nice one elcheapo, any chance of some pictures of your bargain    ;)   mick.
« Reply #7 on: September 05, 2005, 07:28:44 PM »
To quote one of your other posts, " BLAH BLAH BLAH!  >:(" Ha ha, seems we all get a bit "long winded", hey mate? Welcome to the forum, enjoy yourself, and post some pics! Cheers, Terry. ;D
ElCheapo
« Reply #8 on: September 08, 2005, 07:21:22 AM »
Thanks guys. This is an awsome forum. So far the bike is proving to be a good investment. Just the minimal stuff, like it has old rubber on it ok for motoring but I certainly would not do 70 on them. :o Rigged up a start switch yesterday so I can ditch the screwdriver and look respectable LOL. I am glad to be among the proud 750 riders. Whats more on the luck thing is that I have two 66 Bridgestones. I got those for $30. Just got the one running this week. They were basket cases when they arrived. Looked like a living thing with it guts hangin out. Anyway got one running with title and one parts bike. I just got the opening bid for $200 on eBay this morning, who know where this luck will end but I hope it holds out. Just wish that guy with the free Yamaha Venture would call back ARRHHG!.
Because my head is always in the book and out in the drive working and tinkering to the point that my wife thinks its not such a great idea, I am always willing to help out a fellow biker....even if he rides a Harley.
I love the way this bike looks stock, but I keep looking for another to do the killer "Rice Chopper". I know sick... but fun.
I get more long winded than anyone.
Here's a pic of the old girl.
Offline skamania19
« Reply #9 on: September 08, 2005, 04:00:15 PM »
You and me, we gotta go shoppin' some time. I'll bring the money, you just bring your mojo. As my son would say, "Flippin' sweet!"
Columbia River Gorge: Where the wind blows and the rain sucks.
ElCheapo
« Reply #10 on: September 09, 2005, 07:39:10 PM »
I do know how to pick'em. The two Bridgestones just jumped to $255 with over 587 viewers and numerous watchers. I think this one will end in a blood bath.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4573889184&sspagename=STRK%3AMESE%3AIT
Maybe it has something to do with the fact that I tried something new by letting people hear what this bike runs like in a sound sample.
Offline Ted Nomura
« Reply #11 on: March 16, 2006, 01:37:57 PM »
I got a '71 500/4 for free once. I still have it and dragged it a mile home in 90 degree heat. The rear wheel was stuck so yeah, I dragged it. Fortunately I'm young and in awesome shape so with some help from my brother we did it.
Funny story about your bike, enjoy your new purchase.
I also got a 1971 CB500 for free (with a non-stock 4 into 1 exhaust), along with a 1976 CB400F (missing gas tank and side covers but with a stock exhaust). But the best deal I had was when I bought a 99% stock CB750K2 from a Honda dealer about a decade ago for $700. After removing the Wixom fairing, crash bar and rear luggage rack, all it needed was to replace the late type rear turn signals with early type and get the original ignition switch mount from a spare CB750K2 parts bike I bought for $200. The latter had the original red 1969-1970 gas tank. I also bought a near stock 1970 CB750 in pieces for $220. The only non-stock part was the seat, which was the converted King and Queen seat. I recently purchased a near mint CB750K1 seat from ebay for $20, not including shipping. I think the 1990s were the best time for buying old CB750s. It was for me.
1969 Honda CB750, two 1970 CB750, two 1972 CB750K2, 1971 CB500, 1975 CB550, 1976 CB400F, 1968 CL450, 1973 CL450, 1974 CB450, 1970 1/2 SL350K1, 1971 SL350K1, 1972 SL350K2, 1972 CL350, 1972 CB350, 1983 CB1000C, 1976 Kawasaki KZ900A4, 1976 KH500A8, 1979 KZ400B, 1983 ZN1300, and so on and so on...
