Author Topic: CB350F right side exhust smoking?  (Read 1387 times)
Offline JerryRice
« on: July 27, 2008, 12:28:41 AM »
Hello, I recently bought a CB350F. The right side exhust smokes a little bit. Burning oil.
What can cause this? I am going to be fixing a head gasket leak this week and would love
to be able to fix the smoke if it is an easy job.
Any help/advice would be appreciated.
Thanks .
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline JerryRice
Re: CB350F right side exhust smoking?
« Reply #1 on: July 27, 2008, 03:44:31 PM »
Does anyone have any ideas?
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline bender01
« Reply #2 on: July 27, 2008, 03:55:03 PM »
Is it an original exhaust? Or a 4 into 2? If 4>2 that would make it cylinder 3or4. Is it black smoke?
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline JerryRice
« Reply #3 on: July 27, 2008, 08:31:08 PM »
It's 2 into one on each side. The smoke is black.
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline bender01
« Reply #4 on: July 28, 2008, 06:14:45 AM »
Check the plugs for carbon buildup. Have you cleaned the carbs yet?
75 550 K1
74 750 K4
74 750k 836 project
Good luck!
Two Tired Quote !
Offline JerryRice
« Reply #5 on: July 28, 2008, 08:16:26 PM »
I will check them in a few days when I do the head gasket.
- I havent even inspected the plugs yet.
Thanks,
Jack
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline schneider419
« Reply #6 on: July 30, 2008, 01:39:49 PM »
cylinder running rich? or bad valve seals?
Offline Loudpipe
  • Broken Vehicle Collector
« Reply #7 on: July 30, 2008, 04:15:51 PM »
If the smoke is black it's not oil.  Oil smoke is bluish color.  If the smoke is black, you're probably running rich and could use to lean out whatever cylinders are smoking.  Pull the plugs and see if they're black.
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Offline JerryRice
« Reply #8 on: August 06, 2008, 09:01:40 PM »
I pulled the plugs and took a pic:
What do you think is going on with the engine?
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline JerryRice
« Reply #9 on: August 07, 2008, 01:31:25 PM »
Any readings on these bad boys?
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline heffay
« Reply #10 on: August 07, 2008, 02:12:28 PM »
yes, number 4 looks like your culprit.
clean the plugs.
make sure you've got spark... although, it doesn't look wet now.
check for smoke.
may need to mess w/ your carb settings... 4 looks rich, 2 and 3 maybe on the lean side, 1 looks decent.
you've got the plugs out, you could just go for new.   ;)
Offline JerryRice
« Reply #11 on: August 07, 2008, 05:53:25 PM »
Put in new plugs. How long should I ride before checking them?
The Real JERRY RICE
My Dream Bike
www.CB350F.com
Offline loonymoon
    • Loonymoon's CB350F enthusiasts gallery
« Reply #12 on: August 07, 2008, 06:04:42 PM »
I used to get smoke from cylinder 3. We thought it was sticking rings. Treatment with a fuel additive and /or an eletronic ignition seems to have cured it.. not too sure which!
