Author Topic: New tach for free  (Read 1735 times)
Offline bistromath
New tach for free
« on: September 11, 2005, 09:22:01 PM »
Friday night I went out for a spin and the screws on my tach face, which had been slowly rattling loose over the last year or so, finally loosened enough to bind the needle above 2000RPM. The tach looked pretty scruffy anyway, a result of sitting in the sun over the last 30 years. So I went into action:
Before:
After:
I took the tach dial off, scanned it, cleaned it up in Photoshop (if you like I can post the hi-res template I made), and then printed it out on a transparency. I sanded the tach dial and spray-painted it flat white, so the clear numerals would show up white. Turns out, the tach is painted using a layer of green over a layer of white anyway. The plastic for the dial is translucent green. I mounted the transparency using super glue and put it all back together, repainting the needle while I was at it.
It looks almost stock! Definitely better than before. The fluorescent red used for the redline doesn't exist in printer ink, so that's not quite right, but hey -- what do you want for free?
EDIT: oh, the night light thing: I should post some after-dark pics, but it looks stock except a little brighter. Next time I'll use two coats of white =)
« Last Edit: September 11, 2005, 09:42:15 PM by bistromath »
'75 CB550F
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: New tach for free
« Reply #1 on: September 11, 2005, 09:56:52 PM »
Sweet ;D
How did you get the thing apart?
Did you use the pry method or the cut with a dremel method?
Carpyhttp://www.cb750cafe.com/  has some cool Cafe faces for these things but I have been afraid to screw mine up disassembling them.
Offline kghost
« Reply #2 on: September 11, 2005, 09:57:57 PM »
try the search under "gauge faces". instructions and link popped up.
Try FAQ.
Stranger in a strange land
Offline bistromath
« Reply #3 on: September 11, 2005, 10:13:23 PM »
I cut it open and arc-welded it back together with a little piece of steel plate bridging the gap from the Dremel. I'm a terrible welder but so far it's held.
'75 CB550F
Offline kghost
« Reply #4 on: September 11, 2005, 10:19:31 PM »
You can take the bands apart.
Offline bistromath
« Reply #5 on: September 11, 2005, 10:40:31 PM »
Yeah, you can pry them loose, but after trying this on my old speedo I'm more inclined to go the Dremel route. The reassembly isn't as strong but the chrome band looks nicer afterward. Only one little weld instead of an entire re-clamped band.
'75 CB550F
Offline kghost
« Reply #6 on: September 11, 2005, 10:44:12 PM »
If your careful and go slow you can reuse the band.
Should I go take a picture of mine to prove it?
Wait, here ya go.................
« Last Edit: September 11, 2005, 10:52:09 PM by kghost »
Offline KB02
« Reply #7 on: September 12, 2005, 07:51:20 AM »
Wow. Your garage is WAY cleaner than mine...   ;D ;D :D
And I would loove to see that template you made, Bistromath.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
