Author Topic: Monoshock, or side mount shocks, whats the handling differences?  (Read 20690 times)
Offline Soos
I am seriously tempted to mount up a monoshock from an '85 gpz600 kawasaki on a '82 cb650 frame.
But i'm not sure whether welding shock mounts on the frame and putting on the single shock, or converting the swingarm to accept the dual shock setup stock to this cb650.
Are there stability or handling characteristics that are inherent to either shock system?
I would imagine the dual shock would be more stable in corners... but i'm not sure.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline crazypj
  • I'm brill, me
Re: Monoshock, or side mount shocks, whats the handling differences?
« Reply #1 on: October 02, 2008, 07:17:58 AM »
If its done right the mono shock is a lot more stable than twin shock set up. you feed the loads from rear wheel directly into frame backbone, it doesn't twist rear frame/shock mounts like a twin shock will ( CB500/550/650)
 All of them rust where seat section meets front frame section ( front of seat, rear of tank)  because the frame flexes and paint falls off
PJ
« Reply #2 on: October 02, 2008, 09:24:49 AM »
PJ
Those are very good points. Some others a little more esoteric: From a design standpoint, weight should be concentrated in a triangle formed by the axles and the shoulder pivot of the rider. Monoshock does this, twin shock does not. (Nor does hanging the battery in a tail section, but it does look cool) Its also a reason for flipping the forks backwards so the calipers are in the triangle and also near the pivot of the forks.
Also, unsprung weight is reduced. The bottom half of each twin shock and spring is unsprung weight. With a monoshock that is reduced to near 0 as the weight resides near the pivot.
« Last Edit: October 02, 2008, 09:27:05 AM by MCRider1 »
Offline KB02
« Reply #3 on: October 02, 2008, 10:03:19 AM »
From a handling stand point (and this may just be my mind making things up...) but if you have one shock go bad in a dual shock system, the handling of the bike with be very negatively effected. e.i. - twisting of the swing arm, stuff like that.
I thought about doing the monoshock routine with my 78 750 I am building. The swing arm I have would have extended the rear tire out too far for my liking.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #4 on: October 02, 2008, 10:18:38 AM »
Not likely on a street bike, but you are correct IMO. On my racer, I had to remove both for something and realized that one was virtually seized. My numb butt was not tuned well enough to detect it, but it couldn't have been good.
Offline Soos
« Reply #5 on: October 02, 2008, 01:33:29 PM »
going to have to search up if anyone has done this, if they used a jog or something to orient everything properly.
From what you all have said, and what I have read on mono shocks, it is an improvement.
Now to find out the price of a new one, or if these type are re-buildable..
I hate stiff old shocks.
When I had put new shocks on my '79 it made a world of difference.
I don't like old shocks.
And my butt couldn't tell either.
But my back could, especially on long rides.
l8r
-=≡ Soos ≡=-
Offline WFO
  • Will work for powerbands
« Reply #6 on: October 02, 2008, 01:38:32 PM »
Iam sure having one shock centered is alot better i remember having one shock on my old XR messing up and that made the ride all messed up so having slight differences in one shock is really hard to detect and real easy to detect in a mono shock that being said the mono is way better.
That will be the trick..
82 cb650 sc nighthawk - 78 kz 650 b
Offline doobiebro
« Reply #7 on: October 02, 2008, 02:55:17 PM »
This is great info.  Just a few weeks ago I saw the ProLink monoshock and swingarm from a '81 or '82 CBX on e-Bay and I was thinking that it would be so cool to adapt my '77 750K frame to fit it.  I thought the CBX frame geometry would be close to the 750 - but perhaps too wide.  Anyways, it is good to know my thinking of better stability was correct.
Offline CBJoe
« Reply #8 on: October 02, 2008, 03:19:27 PM »
Given the talk about proper orientation and such...  How does this work  ???
I would think that a shock mounted like this would cause twisting on bumps....
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline scunny
  • don't call me expert
« Reply #9 on: October 02, 2008, 03:26:23 PM »
it's all in how stiff you make the swing arm, don't forget the single sided swing arms
CAUTION I've been thinking
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Shenanigans
  • Right turn?
« Reply #10 on: October 02, 2008, 03:36:44 PM »
I always wondered about the side shock set up, as I have seen the Ducati sport classic which has that set up. I was surprised the shock was not so beefy but then again that bike is not exactly a super sport.
Offline alltherightpills
« Reply #11 on: October 02, 2008, 04:04:48 PM »
Here is a monoshocked 350 twin from the Inspiration Gallery...
Looks cool to have it totally open like that, but unless that seat is made out of carbon fiber or some other super stiff, super light material, I don't imagine it would last very long without bracing. :o :o :o ;)
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Offline WFO
« Reply #12 on: October 02, 2008, 04:05:06 PM »
Iam sure the frame was built to compensate for the flex.
Offline bigsherm
« Reply #13 on: October 02, 2008, 10:09:20 PM »
I've been agonizing over this very decision for a couple weeks.  I was on the verge of springing big bucks for really good dual shocks and a stiffer swingarm.
Then I ran across Ducati 750/800/900/1000ss swingarms with their cantilever monoshock design.  I'm considering modifying this swingarm by cutting off the pivot tube, shortening the front of the swingarm, and welding it back on with some additional bracing.  I don't want a longer swingarm than stock because I like the responsiveness of the stock wheelbase.  This way, I'd have a strong piece that will accept modern fat rubber, and has proven geometry that you can get a shock for.
I made a geometric model to determine the difference in the forces on the shock with the shortened swingarm, and in this case they are virtually the same as with the stock length if you shorten the front instead of the rear of the swingam because you are reducing the arm length from the pivot to the wheel, and from the pivot to to the shock.
Ohlins shocks for the Ducati ss models are quite cheaper than their twin shocks, too!
One problem - where do I put the oil tank?  I think a stock oil tank would work if I don't modify the rear up tubes, but I want to keep my bike see-through, and that seat cowl will be removeable with a passenger seat underneath.
Sherm
Here's a drawing of my idea.  CLICK TO MAKE BIGGER.
« Last Edit: October 02, 2008, 11:25:58 PM by bigsherm »
Offline crazypj
  • I'm brill, me
« Reply #14 on: October 02, 2008, 10:37:39 PM »
 Back around 1989 I fitted a modified Yamaha RD350LC swing arm (pre-YPVS) into a CB400f with shock pretty much parallel with frame backbone , just above carbs. Also fitted CX500 forks (for the dual disc set up) with comstar wheels from CB400T.
The difference in handling was totally awesome.
Unfortunately I don't have any pictures but there were pictures of a similar one posted a year or so ago, it looked similar to the drawing.
 That CB350 looks like it has a GSX-R shock and ride height adjuster fitted. I would think that's a bit stiff for 350?
PJ
« Last Edit: October 02, 2008, 10:50:47 PM by crazypj »
Offline dusterdude
« Reply #15 on: October 03, 2008, 01:56:19 PM »
i seem to remember someone on here either did it or was tinkering with the idea,i dont recall who it was tho
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline crazypj
  • I'm brill, me
« Reply #16 on: October 04, 2008, 12:34:02 AM »
Probably not me, I only do Suzuki mono shock swing arms into Yamaha XS650 nowadays  ;D
PJ
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #17 on: April 14, 2009, 08:02:10 PM »
I know it's an old thread, but resurrection is fun.
look at my idea, very similar to bigsherms.
i'd use a bigger shock for sure, just trying to see what it would look like.
P.S. it's photoshop
« Last Edit: April 14, 2009, 08:07:00 PM by Industrial Cafe »
Offline cafebob
« Reply #18 on: April 14, 2009, 08:26:54 PM »
I have done this to a 750.  Riding it is much more response, I feel I can really get into corners much more than I used to.  To me it is a really nice mod.
As to doing it. Keep in mind that you really need to try and preserve the original swing arm geometry from the doner bike.  You want to make sure the shock travel and range of motion is the same, or things can bind. Also, ride height is a concern, if not done right the bike can look very cockeye.  Oh, and make sure you are using a doner bike that weights about the same or you will need to change the spring out.  Most bikes I have seen the spring/ shock usually travels somewhat up and down, on a angle like that you might have binding issues.
CB
  • Like a well oiled
    • Undead Asphalt
« Reply #19 on: April 14, 2009, 08:42:42 PM »
with that pic up there i'd use an '80 cb750 swingarm with the upper brace modification and try to use 2 shocks to be different. i played with the movement of the swing arm in gimp and the shock placement seems optimal with no foreseeable binding.
Then again its just an idea, I'm full of 'em... Wish my pockets were full of money :(
Offline Inferno Rider
« Reply #20 on: April 14, 2009, 10:15:28 PM »
This bike has one from a CBR:
  • Like a well oiled
    • Undead Asphalt
« Reply #21 on: April 15, 2009, 07:44:43 AM »
thats a cool bike, but I never liked the "thrown together" look of the vertical shock, when it's put on the cb750. It doesn't look like something the factory would have tried.
I got the idea from a BMW in the inspiration gallery.
 It would look more factory and I could use two 12-13 inch shocks.
(I think the "mono" looks too new, and everyone does that)
Offline SKTP
« Reply #22 on: April 15, 2009, 08:32:59 AM »
I saw this bike at a trade show in San Diego
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
  • Like a well oiled
    • Undead Asphalt
« Reply #23 on: April 15, 2009, 08:44:55 AM »
oh wow! Go put that in the inspiration gallery, if it's not there already!!
Offline tinyrobot
  • Mock it up before you Fock it up!
    • ChiVinMoto
« Reply #24 on: April 15, 2009, 09:19:09 AM »
I believe that and 2 others are already in the gallery.  They are different dirt bikes made to be cafes IIRC.  I think Roland Sands did one of them?
