Author Topic: 1970 CB750 Rebuild (Actually a K4 based on the VIN)  (Read 9166 times)
Findlater
Re: 1970 CB750 Rebuild (Actually a K4 based on the VIN)
« Reply #25 on: December 21, 2008, 02:25:16 PM »
Time for an update with some new pictures!
Rocker Arms pulled and organized.
Valves look great! Little crud on the #3 but will easily scrape off.
Likewise on the pistons cylinders smooth and free moving
Cylinders in great condition
Everything looks good on this side
Sprocket is covered in old smelly crap- I'll be cleaning this soon
Clutch/Shifter looks good how do I tell if the gears are worn? gotta open the case still?
Engine as it stands today
Anyways so thats the engine currently. Im starting to wonder about cleaning what Ive pulled so far, painting the cooling fins like I want buying the new gaskets I'll need and put it back together. Everything internally is looking MUCH better than I had expected.
Thoughts from the group?
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #26 on: December 21, 2008, 08:47:39 PM »
Mine looked about like that with 40k miles.
Only way to tell about the transmission is to split the cases and look.
Over all everything seems to be not half bad.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #27 on: March 14, 2009, 05:59:41 PM »
Maybe I'm confused, you're polishing a steel swingarm?
dwmilton
« Reply #28 on: March 15, 2009, 04:04:57 PM »
Polish the pee outta it, and hit it with some clear hi-temp rustoleum...
Do they even MAKE clear hi-temp rustoleum?   ;D
