Author Topic: newb help.... can't find my answer in the manual.. LOL  (Read 1228 times)
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
« on: November 12, 2008, 08:25:01 AM »
I need help...I don't have a clue how to get this little bugger off the rim...
cause I need to get this out...
any thoughts? ( The manual seems to be pretty vague on the issue) LOL
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Re: newb help.... can't find my answer in the manual.. LOL
« Reply #1 on: November 12, 2008, 08:35:40 AM »
The first picture is your axle nut. Find a wrench to fit it. THe second picture is your axle which goes all the way through the hub and is the inside of the nut in pic 1. There should be a hole in the axle end that you can put a large size Phillips screwdriver or punch in.
THen turn the nut off on the other end. Easier said than done as holding the axle end can be a struggle. Put a length of pipe on the screwdriver or punch so it goes to the floor and you have something to turn against. Or put the axle in a vice.
Once the nut is off, you can pull the axle out from the speedo drive side if necessary.
« Reply #2 on: November 12, 2008, 08:57:42 AM »
thank you...  I was struggling like a #$%**@)@!!!! #$#$#$  to get that thing off.. never thought of the pipe over a screw driver..
thanks!
« Reply #3 on: November 12, 2008, 09:11:27 AM »
You're welcome. A little PB Blaster or WD-40 type penetrant douldn't hurt. Good luck!
Offline ev0lve
« Reply #4 on: November 12, 2008, 09:13:34 AM »
 ;D I just did that last weekend. It DID take a little more force than I was initially comfortable with (thought the screwdriver would bust).
