Author Topic: removing finish off aluminum forks  (Read 3219 times)
Offline tygrant
« on: January 13, 2009, 12:13:57 PM »
title basiacly says it. i bought some aluminum cleaner and when i scrub them with steel wool it worked well but its clear as day where the clearcoat is thats still on the aluminum but i cant seem to find anything that will take it off, i tried HC acid and aircraft stripper
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: removing finish off aluminum forks
« Reply #1 on: January 13, 2009, 12:19:48 PM »
wet sand
Offline tygrant
« Reply #2 on: January 13, 2009, 12:21:12 PM »
what grit would you say is the ebst that will leave minimal scartch marks visible when done, im not plishing these o a buffing wheel so i dont want the brush one here and another way here look if you know what i mean
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #3 on: January 13, 2009, 02:47:28 PM »
800 should work.  If not go one way or the other.
Offline Really?
« Reply #4 on: January 13, 2009, 02:58:53 PM »
Do not go as low as 220 grit.  Those scratches take a lot of time to get out.  To me 320 grit would be the lowest but if you do, you will want to go up to 600 and maybe 800 after that, as seaweb suggested.  The bigger then umber, the smoother/cleaner it will get.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline cbr-eric
« Reply #5 on: January 13, 2009, 03:43:45 PM »
you can also use paint stripper, pulled the clear of my motor covers for me and left them shiny :)
k8 project, a long way from done.....
okie
« Reply #6 on: January 13, 2009, 03:55:04 PM »
I know I'm gonna' get a lot of flack for this, but the best solution I have found is media blasting.  I use walnut hulls and it cleans up the forks quickly and requires very little prep to polish.  I have used aircraft stripper, sandpaper, cussing ;) and anything else that I thought might work.  Walnut hulls work for me every time.
KingCustomCycles.com
« Reply #7 on: January 13, 2009, 04:10:42 PM »
+1 but i use glass beads and then paint or just clear coat the bare metal.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #8 on: January 13, 2009, 04:17:32 PM »
Most people don't have blaster in their arsenal of tools. ;D
« Reply #9 on: January 13, 2009, 04:25:48 PM »
I agree with seaweb, you have to physically remove some of these coatings. Then you need to figure out what they used, it must be tough stuff.
Offline tygrant
« Reply #10 on: January 13, 2009, 06:24:15 PM »
i have a little sand blaster but its filled with black beauty. i think il try starting with some realy light sand paper and wet sand them then go back to steel wool and some hand polish. i dont want to remove them either. im lazy
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
« Reply #11 on: January 13, 2009, 06:43:11 PM »
Get a buffing wheel from Sear or wherever and some poslihing compounds for that final finish. The harsh stuff will remove the swirls from the steel wool. Then you go finer to bring out the shine. That is what I have done and I promise you I am lazier than you are. No need to pull the fork legs. Drop the wheel and spin them around.
Offline pablo78cb550
  • mmmph.
« Reply #12 on: January 13, 2009, 07:20:00 PM »
go to your local pep boy auto zone. and pick up a red scotch brite wheel. it in the body shop aisle. break out your drill and go to town.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #13 on: January 14, 2009, 03:04:24 PM »
Use aircraft paint stripper!!!
Its the best but also the Most DANGEROUS!!!!
Read the back of the can :o
Leaves your parts nice and clean right down to the metal.
Cheers
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
« Reply #14 on: January 14, 2009, 03:42:13 PM »
If you were really lazy you would park it outside for a few years and it would strip and peel off naturally.  Many before you have done it just like that.  ;D
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #15 on: January 14, 2009, 06:41:16 PM »
I use a small orbital sander with a sheet of old 220, followed by a quick wetsand, then black compound on the wheel.
But then I probably don't do it to the same high level as the others here.  A few scratches here and there gives the clear powder coat some tooth. :D
spwg
Offline pddpimp
« Reply #16 on: January 14, 2009, 07:56:27 PM »
You can find a trick under your sink.
I often use Easy Off oven cleaner. It works great.
Also works great for taking the anodizing off of the controls.
When the majority of the United States population get to be 70 years old, they will finally realize what is really important. And by then it'll be too late.
-'77 CB750 Cafe/Muscle bike (early clone)
Soon to have a hopped up 836cc *sold*
-'75 CB750 with a little bit of character
Offline tygrant
« Reply #17 on: January 14, 2009, 08:52:42 PM »
i tried aircraft stripper... the brown stuff in the blue can. it doesnt work on the clear coat on my forks. im guna try sanding once it warms up out in the garage. even with the heat on its guna be too cold this weekend out there.
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
  • Dang IT!!!
« Reply #18 on: January 15, 2009, 12:36:08 PM »
Really??
You have to make sure your forks are clean as a whistle!!! No road grime or Oil, or it won't cut through.
 If this still doesn't work, I'd suggest working with a 320grit and wet sand it all the way to a 3000 grit.
YOU WILL GET PROFESSIONAL RESULTS!
But the key to the final buff, is using a real light touch...and I do mean "light'.
Post your results when your done.
Cheers
LL
My rides:
Past Rides:
Offline tygrant
« Reply #19 on: January 15, 2009, 01:19:45 PM »
yes i was supprised it wasnt dissolving the clear coat... it eats everything else!. the can  have is a few years old now and i think it may have lost som of its bite. I may buy another can
1975 CB550F - cafe
2001 YZF-R6
2002 HD fatboy
Offline goon 1492
  • Sucka Repellant
« Reply #20 on: January 15, 2009, 01:51:11 PM »
I got one up on the media blast, instead of using walnut shells(which is a excellent fine grit to use by the way) use baking soda, it will take all the paint off and not even scratch the metal  ;) ;) ;) ;D.
When I sand my parts some I have to go as low as 220(which like giga said sucks); that's for pits and bad stains/oxidation thats in the aluminum, then I go to 320 wet, 400 wet, then 0000fine steel wool wet, then 0000 steel wool with chrome polish for a buffing agent. The chrome polish will darken the metal alittle with the oils that are in it but you can wash it off after that step and hit it gently with the 0000 steel wool after washing the polish off and it will give it more of a chrome shine  ;).
All the aluminum parts I have taken off my bike so far I have done this way and they have a mild polish with an almost satin sheen to it, and a buffing wheel would top it off after that.
Offline Joksa
Offline Big Port Jimmy 6
« Reply #22 on: January 15, 2009, 05:39:01 PM »
Life happens between empty and full.
78 750 K 78 CB 400 TII
Offline mrbreeze
  • Not your average
« Reply #23 on: January 15, 2009, 06:04:50 PM »
I've used the EZ off on stock controls and my upper triple clamp.Worked good but I heard it shouldn't be left on the aluminum too long (TwoTired said it).For removing clear coat on the engine covers and forks....I used this citrus paint remover that comes in a aerosol can.I spray it on the part and it foams up.I usually just set it on some old newspaper and come back to it a day later.The clear coat just wipes right off.
MEMBER # 257
