Author Topic: Aluminum swingarm  (Read 3254 times)
Offline bert96
  • past ride
Aluminum swingarm
« on: February 03, 2009, 02:48:41 AM »
I would like to install an aluminum swingarm on my k4,and i was wondering which one is the easiest/less mods to install?
Would like to see pics ::)
Thanks
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Re: Aluminum swingarm
« Reply #1 on: February 03, 2009, 03:19:58 AM »
Hi Bert, this one fitted straight in but i had to cut out the monoshock section, shorten it and weld on the shock mounts, not sure if this is what you want but here's a pic anyway.
Cheers......Mick
Offline bert96
  • past ride
« Reply #2 on: February 03, 2009, 03:25:23 AM »
it came from???
« Reply #3 on: February 03, 2009, 03:31:43 AM »
Sorry, GSXR 1100K, same width as the honda swingarm at the swingarm pivot.
Cheers ...Mick
Offline bert96
  • past ride
« Reply #4 on: February 03, 2009, 03:38:24 AM »
 any years?
« Reply #5 on: February 03, 2009, 03:45:40 AM »
In Australia it was a 1988 model. And it was a 1100 J...sorry, Too many things on my mind...
« Last Edit: February 03, 2009, 03:47:33 AM by retro rocket »
Offline bert96
  • past ride
Offline bert96
  • past ride
« Reply #7 on: February 03, 2009, 10:41:52 AM »
 Some one can give me the width at pivot point of a 750 k4.I did not remove my swingarm yet.
I don't think there is a big difference between the swingarm from a GSX 600,750 AND 1100.Am i wrong?
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #8 on: February 03, 2009, 10:52:14 AM »
Depends on the year, but there's not much difference. IIRC there's 3 or 4 year ranges that they are basically the same.
Something like:
04-05 gsxr600/750 should be the same
then
06-08 gsxr600/750 should be same or similar
then
00-03 gsxr750 - 01-04 gsxr1000 should be the same or similar as well.
Keep in mind I'm not looking at them....but these are all different from each other so:
04-05 might not be the same as the 06-08 or hte 00-03 and 01-04.
And I have no idea if they fit in a Honda frame....  :-\ sorry.
Hope that makes sense lol.  ;D ;)
« Last Edit: February 03, 2009, 10:54:51 AM by HavocTurbo »
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Geeto67
  • A grumpy
« Reply #9 on: February 03, 2009, 11:14:40 AM »
some GSXR swingarms have an offset pivot - not sure of the years though.
That 2001 posted has an offset arm, if you look the left side is further from the centerline than the right. It might still work but you have to keep that in mind when doing shock mounts.
« Last Edit: February 03, 2009, 11:17:25 AM by Geeto67 »
Maintenance Matters Most
Offline bert96
  • past ride
« Reply #10 on: February 03, 2009, 11:40:11 AM »
I have found a swingarm from a GSX750 '88,maybe a better choice!?
Offline Clyde
« Reply #11 on: February 03, 2009, 03:20:09 PM »
How do they compare lengthwise with the original?
I am interested in doing a similar thing.
Thanks
Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
« Reply #12 on: February 03, 2009, 03:33:03 PM »
I wasn't too sure about this, that is why i am using the Suzuki wheels as well. It was easier to use all the standard spacers.
Offline HavocTurbo
  • Can you tell?
« Reply #13 on: February 03, 2009, 03:40:44 PM »
It's also easier to machine down the carriers than it is to add to them. Might have to either remake your spacers, offset your front sprocket, or all 3.
Either way it will be easier to start from a centered wheel than trying to center everything all at once.
09 XL883L - No Name
« Reply #14 on: February 03, 2009, 03:44:49 PM »
Your right, i had some material machined off the rear sprocket carrier and i also need a 10mm offset front sprocket, thankfully all easy to do.
Offline bert96
  • past ride
« Reply #15 on: February 08, 2009, 12:50:23 PM »
Anyone know if a swingarm from a cbr600 or 1000 fit straight in?
Offline bert96
  • past ride
« Reply #16 on: February 08, 2009, 12:54:10 PM »
...or cbr900???
Offline bradweingartner
  • 74 CB 550 x2
« Reply #17 on: February 08, 2009, 02:24:59 PM »
Most likely not. I can say for sure that a rear swingarm from a CBR600 F4 era will definitely not fit even remotely. Would take a lot of work.
« Reply #18 on: February 09, 2009, 09:55:05 AM »
Bert,
Did you post something?  I was distracted by your avatar!
Offline bert96
  • past ride
« Reply #19 on: February 09, 2009, 09:56:35 AM »
you're not the first one! ;D
