Author Topic: what electronics can you upgrade? (78 cb750)  (Read 18042 times)
Offline timdhawk
  • 1978 CB750K
Re: what electronics can you upgrade? (78 cb750)
« Reply #25 on: March 05, 2009, 07:58:32 PM »
that looks great! keep it up. this is right in line with what i'm wanting to do, so i may do some copying of your work.
In deeper than I should be...
gregory1975
« Reply #26 on: March 07, 2009, 04:13:07 PM »
I am enjoying this thread.. I also plan on upgrading/rearranging my electrics.
I would like to add the Cycle X Power Arc Ignition.
http://www.cyclexchange.net/HighPer%20Ignition%20Page.htm
I started another thread specific to the Power Arc Ignition to get opinions on it ( so I wouldn't hijack this one) ....
http://forums.sohc4.net/index.php?topic=47700.0
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #27 on: March 10, 2009, 09:37:16 AM »
Here are some pix of my set up
Dyna 3 Ohm coils, Hondaman 1K Ohm resistor pack
Offline 78CB750CAFE
  • I'm not really an
« Reply #28 on: March 10, 2009, 09:38:23 AM »
Headlight switch on bucket
Offline 78CB750CAFE
  • I'm not really an
« Reply #29 on: March 10, 2009, 09:39:22 AM »
Relays for lights
Offline 78CB750CAFE
  • I'm not really an
« Reply #30 on: March 10, 2009, 09:40:24 AM »
left side panel
Offline 78CB750CAFE
  • I'm not really an
« Reply #31 on: March 10, 2009, 09:41:17 AM »
behind the battery
I didn't use a fuse box per se because I can access the fuses like this with my sidecover still attached
Offline 78CB750CAFE
  • I'm not really an
« Reply #32 on: March 10, 2009, 09:46:00 AM »
The all mighty Hondaman ignition box of wonders
Offline 78CB750CAFE
  • I'm not really an
« Reply #33 on: March 10, 2009, 09:47:48 AM »
This week my 4 week old AGM battery crapped out, it was defective.... Batteries Plus is replacing it today, pix later of the rest of the set up.
robert6920
« Reply #34 on: March 21, 2009, 01:54:08 AM »
Have just installed electronic ignition, made in Japan but sourced in Holland for €133.  Simplicity itself to install, less than 30 minutes, the fiddliest bit was a two minute wrestle with the waterproof grommet taking the wiring from the "points" to the loom by the airbox.  The whole thing fits under the points cover - very neat and tidy
No more changing points, condensers, fiddling with the timing etc
http://www.cmsnl.com/product.php?partcode=00000KIT0046
Thoroughly recommended
« Last Edit: March 21, 2009, 02:16:03 AM by robert6920 »
