Author Topic: Score! **750 cafe build** Completed!  (Read 40411 times)
Offline Shoeboxjoe
  • Large Breasts
Re: Score! **750 cafe build**
« Reply #25 on: March 30, 2010, 07:02:01 AM »
Frame and rear sets primed, waiting for the weather to warm up before spraying the color.
Laced my first wheels last night, only scratched a couple spots in the enamel on the hubs. Probably should have waited for them to cure a bit...
Waiting on bearings and retainers before i can assemble the wheels and true them.
1977 Honda CB750K Project IDK yet
http://forums.sohc4.net/index.php?topic=121669.0
SOLD 1976 Honda CB750K Cafe project
http://forums.sohc4.net/index.php?topic=52576.0
1964 Honda Trail 55 (C105T) Custom project
http://forums.sohc4.net/index.php?topic=64962.0
1967 Norton P11 (restoring for father-in-law)
1978 Ford Fiesta (at body shop!)
Offline Shoeboxjoe
  • Large Breasts
« Reply #26 on: March 31, 2010, 06:51:03 AM »
Offline Shoeboxjoe
  • Large Breasts
« Reply #27 on: April 30, 2010, 09:07:27 AM »
New bearings, seals, and retainers installed. More stuff painted.
I should have installed the new bearings before lacing the wheels  :-\
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #28 on: April 30, 2010, 09:13:14 AM »
nice score
Offline Shoeboxjoe
  • Large Breasts
« Reply #29 on: May 03, 2010, 06:55:06 AM »
Tapered bearing kit installed...
Forks rebuilt with Progressive springs, new seals and 15w oil...
Front wheel mounted...
Truing the front wheel...
Should have the swing arm back from Hondaman Tuesday so I can go right into building the rear end and truing the rear wheel. I'm happy the bike is mostly in one location now, instead of being spread throughout the basement and garage in loose parts  ;D
« Last Edit: May 03, 2010, 06:58:49 AM by Shoeboxjoe »
Offline Shoeboxjoe
  • Large Breasts
« Reply #30 on: May 11, 2010, 07:22:31 AM »
Got the swing arm painted, installed and greased and new shocks from CycleX.
Rear wheel installed and trued.
New tires installed. I went with Continental TKV11 front (100/90-19)...
and Continental TKV12 rear (110/90-18)
Now i can sit on it in the driveway and go "Vrooom vroooom!"
Onto the engine...
Offline Shoeboxjoe
  • Large Breasts
« Reply #31 on: June 02, 2010, 07:35:13 AM »
Tear down (sorry for blurry pics)
Here you can see the crack in the case which has been pushed against the gears...
The crack in the lower case is being welded by a friend at the moment while I'm going through the Inspection section of Mark's book. Ordered a gasket/seal kit from CycleX and will probably be ordering a bolt kit as well. Stole my brothers Mikita lithium-ion impact driver which worked awesome with a #3 phillips to get the cover screws out, only had to drill a couple.
« Last Edit: June 02, 2010, 07:39:42 AM by Shoeboxjoe »
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #32 on: June 02, 2010, 08:18:13 AM »
Looks good Mr. Box.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #33 on: June 02, 2010, 09:56:26 AM »
nice work lacing the wheels. I want to see if I can do that myself. I have an extra swinger I was gonna use as a truing stand.
how difficult was it? and how much did you save? any idea what buchanans charges for that?
I got the same cycleX gasket kit, the one that comes with oil seals. it's pretty nice.
great work so far!
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #34 on: June 02, 2010, 10:19:10 AM »
Niiiiiceee!
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline SKTP
« Reply #35 on: June 02, 2010, 10:40:57 AM »
love how this is looking...can you tell me a little about your fork ears? What year are they and what is the contrasting silver ring? A mod? Stock from a certain year? I am planning to paint/powdercoat mine black as well...yours look very clean and nice...looking forward to watching your progress
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Shoeboxjoe
  • Large Breasts
« Reply #36 on: June 02, 2010, 01:57:50 PM »
Lacing the wheels was very easy actually using the write up under the FAQ section. I don't know what i saved by lacing myself but i did get a quote from a local shop on truing which would have been $60 per wheel. I'm a bit nervous on how i did with truing since I've never done it before. They are close to stock spec and well within serviceable spec but i have yet to get it on the road to actually feel how well I did.
The fork ears I found on ebay and claimed they were from a '72. I bought them just because they didn't have the reflectors and they were painted instead of chrome like my stock '76 ears. When I finally got them though the paint was worse than it appeared with some rust so I sandblasted them only to discover they once had reflectors that were cut off and filled with body filler. So I reapplied more filler and sanded them down, primed and painted. The silver rings at the bottom of the ears were stock from my '76 I believe.
Offline SKTP
« Reply #37 on: June 02, 2010, 02:22:33 PM »
Thanks...the ear hunt begins!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #38 on: June 04, 2010, 10:30:24 PM »
thanks for the info
traveler
« Reply #39 on: June 05, 2010, 07:29:59 AM »
looks great!
Damn shame about your fork tubes being so rusty....I wonder if it would be a good idea to mask off and give the top area a light coat of rustoleum primer and re-install.... :-\
~Joe
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #40 on: June 05, 2010, 10:13:13 AM »
had the same prob and painted mine. as long as the sliding bit has good chrome, you can do it.
Offline Shoeboxjoe
  • Large Breasts
« Reply #41 on: July 07, 2010, 06:38:14 AM »
Had a welder friend fix the crack in the top case. I'm guessing it was caused by a chain slap when the chain broke possibly? the case was gouged pretty deeply by a chain right near the crack.
Sand blasted the paint off the head, cylinders, and cases. Now I'm cleaning all the fricken blasting media off everything  :P Hope to have some progress this week and get some paint on.
Offline Shoeboxjoe
  • Large Breasts
« Reply #42 on: July 10, 2010, 08:44:38 PM »
Cleaned cases and transmission, oil pump rebuilt (it was seized with grit and oil), finished most of the inspection and started assembling.
Cases blasted and painted
Hope the transmission was reassembled correctly  ;D
Offline KB02
« Reply #43 on: July 11, 2010, 06:24:30 AM »
You've got the shift forks in correctly. That was the mistake that I made on my bike.  ::) At least you will have avoided my mistakes.  ;)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Shoeboxjoe
  • Large Breasts
« Reply #44 on: July 13, 2010, 08:05:55 AM »
Sealed the cases up last night. I wasn't expecting the Hondabond to be so runny and kind of made a mess of it. Thankfully my wife is all artsy and had some small paint brushes around, they really helped a lot. I'm sure i forgot something though and will be taking this all apart again in a month  ;D
Cleaning and painting the top end now...
Offline Shoeboxjoe
  • Large Breasts
« Reply #45 on: August 01, 2010, 06:39:01 AM »
Polished aluminum covers which are now in need of more polishing after the engine was installed and got a chrome Allen head bolt kit from CycleX.
Made some quick engine stand adapters from gate hardware, polished head and valves, painted and reassembled.
Cam installed, timed, chain tensioned, everything torqued, tappets adjusted.
Engine installed!
Now all that's left is everything else  ;D
I think with the help of some friends of narrowed down the colors i want for the tank and seat. Majority of votes were for an off white or pearl white for the tank and seat with some vintage number decals and Honda wing logo. Need to order more parts quick if I'm going to have this ready for a ride in mid September. Speaking of that, does anyone have a front brake caliper they'd be willing to sell or trade for?
traveler
« Reply #46 on: August 01, 2010, 08:58:09 AM »
really looks nice, sweet build.
Personally, I'd go black on the tank and side covers.
~Joe
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #47 on: August 01, 2010, 11:18:19 AM »
lookin killer!
that cracked case thing with the chain is pretty common I guess.
« Last Edit: August 01, 2010, 11:20:09 AM by greasy j »
Offline Shoeboxjoe
  • Large Breasts
« Reply #48 on: August 13, 2010, 07:27:22 AM »
Bike is coming together. Have most of the wiring sorted now. Had to make a few runs out to Alfa Heaven for parts that i was missing or couldn't save. If you have never heard of or been to Alfa Heaven you're REALLY missing out. http://alfaheaven.com/ Had to pickup a right side control housing, headlight bucket, petcock, front brake caliper, and plastic rear fender.
After cleaning my sprockets and chain i see they are pretty well trashed. Anyone suggest a source for new chain and sprockets?
Also got the seat back from my good friends at Perfect Upholstery http://perfectupholsteryllc.com Although i don't know if he's keen on doing any more motorcycle seats after working with this super thick leather and the 8 layers of material he ended up with in the corners of the seats.
The red was a friend's idea and once i saw what he had in mind the bike just came together in my head perfectly. I just have to make that happen physically now!  8)
Offline Shoeboxjoe
  • Large Breasts
« Reply #49 on: August 24, 2010, 08:29:07 AM »
Carbs cleaned and completely rebuilt, new sprockets and chain, controls installed and adjusted, exhaust installed, and engine topped off with oil but still haven't gotten any oil pressure. Think i'll try the tilting the bike while you kick it over trick. I primed the oil pump before installing but then turned the engine over to adjust the cam timing so it spit out the oil  ::)
