Author Topic: How far do you go on a tank (CB750K)?  (Read 3461 times)
Offline the technological J
  • deliciouso!
Re: How far do you go on a tank (CB750K)?
« Reply #25 on: July 13, 2009, 07:17:13 AM »
i just timed my bike and am getting better milage was 25..  but looking up now...  someone said something about brakes dragging... go for a ride dont use the front brake pull over (using the back brake) and feel if it seems hot... i am  just guessing but wouldnt the friction from a dragging brake cause  the disc to heat up?
Yes it would... and I checked it right after I got it back on the road (stone cold) but not recently. Probably not the problem. Maybe I don't have a problem? Why do I need a problem?  ;D
sorry if you have alredy said this but whens the last time u timed her? or done the valves?... i noticed a big diference when i did my timing and a sych..
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline ev0lve
« Reply #26 on: July 13, 2009, 07:53:34 AM »
Getting right around the time to change the oil at this point. On the road since late april and I found 2 of my valves were a little loose and a little tight a few months ago. Think I'll replace the points, time it, do the valves and sync the carbs again and see what I get sometime in August.
Offline cookindaddy
  • I sure love this bike!
« Reply #27 on: July 13, 2009, 06:03:30 PM »
Thanks for all the replies and interesting comments. My 180 mile ride (until reserve) was mostly two lane highway, pretty flat with a bit of hills. As far as I know, I have no special tuning or parts. Just following the Honda service manual. It was also only the first time that I filled right up and ran until the reserve was needed. I'll have to do it again to double check.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #28 on: July 13, 2009, 06:05:28 PM »
we aims ta please ;D
Offline jhasewhite
  • my best vacation is your worst nightmare
« Reply #29 on: July 13, 2009, 07:58:25 PM »
I hit reserve at 75-85 on my 76f. but it takes a lot of physical work and a good eye for police.  I have never gone over 130 on a tank,  still too rich?
slow and steady does nothing.
« Reply #30 on: July 13, 2009, 08:04:47 PM »
I have 120 Mains and the 78K has accel pump. I set the pump to come in earlier and the mains make me run a tad rich. The gas lasts a bit longer than my ass on longer runs.
