Author Topic: What did you do to your bike today ?  (Read 3676916 times)
Offline veloracermike
« Reply #11225 on: July 18, 2012, 02:30:52 PM »
My bike has that 'New Shock Smell'.
Offline PrsCustom22j
  • "they've done studies you know...60% of the time it works every time"
« Reply #11226 on: July 18, 2012, 04:26:31 PM »
nice bike...i'm digging the paint job
1976 Honda CB550K
« Reply #11227 on: July 18, 2012, 04:42:13 PM »
Thanks!!!
I also relocated the license plate and added two LED license plate bolts.
Offline Dimitri13
  • 1974 CB550K
« Reply #11228 on: July 18, 2012, 05:48:35 PM »
Thanks!!!
The plate has been relocated to the spot in that picture? I like it! Any pictures of how it's attached or a DIY guide? I hate axle-mounted  plates and I don't ahve enough clearance under my tail.
Offline JamesM
« Reply #11229 on: July 19, 2012, 05:43:23 AM »
Lowered 3" in the front, 2.5" in the back. New drag bars. Went over carbs again and finally got them to quit leaking fuel, I adjusted the flaots with the carbs at a 45 degree angle instead of vertically and they are good to go now. Bike runs awesome.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #11230 on: July 19, 2012, 11:36:41 AM »
Thats a nice bike there jamesM
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Mcwilliams570
« Reply #11231 on: July 19, 2012, 12:40:56 PM »
Went to the DMV and got it registered :) Took it for a ride about 80 miles today my cheeks hurt from the sh@t eating grin on my face..
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
« Reply #11232 on: July 19, 2012, 12:44:00 PM »
JamesM - I do like the stance  8)  How does your bike perform with fuel levels so far off spec? :o  get back to us in a few weeks  ;D
tuning your carbs like ^ not recommended.  change in fuel level alters performance.
IIWM, id pay $20 for new float valves and set my carbs up correctly. ;)
Offline Dimitri13
  • 1974 CB550K
« Reply #11233 on: July 19, 2012, 01:09:29 PM »
Told myself I was going to mess with the front end for the third time in a week. I might actually go out and do it today.
Offline Shenanigans
  • Right turn?
« Reply #11234 on: July 19, 2012, 09:11:36 PM »
Picked up a 75F and a wrecked K parts bike a little while ago, I finally got around to see if I could get the F to run. Motor was seized and number 4 was filled with rust & gunk so I thought it was a gone'er. Turns out that cylinder just so happens to be on TDC so a couple hours after freeing it she ran! Probably going to sell her to fund my 592 and 69 750 projects. Ignore the mess...
« Last Edit: July 19, 2012, 09:15:23 PM by Shenanigans »
Offline Tews19
  • I am no
« Reply #11235 on: July 19, 2012, 09:25:56 PM »
Received my fork tubes from forking by franks today. These are extremely nice. Only 40 bucks to cut down to stock length and 25 to overnight shipping. Ap not bad IMO. The rebuilt the forks installed on the bike. Installed the K0 gauges on her too. Also put in the all balls bearing in the front hub. Went smooth but now the axel doesn't move when tightened all the way.
1970 Honda CB750 survivor.
Offline Dimitri13
  • 1974 CB550K
« Reply #11236 on: July 20, 2012, 12:17:56 AM »
Did you line up the speedo drive? There's a set of tangs that you line up with the indents in the speedo drive.
Do the bearings spin freely by hand (spinning the inner race with your fingers)? If not, then the non-retainer side bearing may be a floating bearing and shouldn't be driven all the way in, just like the rear.
Unlikely the spacer stack is wrong, as there's only one spacer.
How'd you drive the bearings out? I used some PB Blaster on it and tried using a punch and hammer. Couldn't get a good bite on it. I'm soaking it overnight, and will try again in the morning, hopefully with a better technique.
« Last Edit: July 20, 2012, 12:21:44 AM by Dimitri13 »
Offline Tews19
  • I am no
« Reply #11237 on: July 20, 2012, 05:27:12 AM »
I used all Balls so I am not sure if they had a specific direction to be put in. I followed HondaMans instructions from his book. I will take apart again tonight and take a look.
Bearings due spins freely though ...
http://www.harborfreight.com/fwd-front-wheel-bearing-adapters-66829.html
I used something similar to this. from the same place but the one I used is like 20 bucks. Came out really easy
Offline WhyNot2
  • I'm finally an
« Reply #11238 on: July 20, 2012, 07:08:06 AM »
Hey Tews, you can rent a kit like that at Autozone, or Advance Auto
They make ya use a credit card but they don't charge it unless you don't bring it back.
« Last Edit: July 20, 2012, 09:08:26 AM by budlite282 »
Offline Accolay
« Reply #11239 on: July 20, 2012, 08:54:37 AM »
Performed marathon overnight carb cleaning and general tune up. Raised the clip position one notch to lean them out- plugs were quite rich. Replaced plugs, adjusted valve lash, cam chain adjustment. Synched carbs. Now overflows from carb #3. Idle is quite high as well at about 2000 RPM. Need to try synching again and take the carbs off again to fix the leaking problem. Probably that valve is still dirty me thinks. Will measure float height again and check that the float tab is working. Will try the clear tube method prior to taking off carbs again. Could have missed something during a tired time during the night. Otherwise, runs like a champ :)
Also, I love my JIS screwdrivers.
1977 CB550F
Offline Dimitri13
  • 1974 CB550K
« Reply #11240 on: July 20, 2012, 01:21:48 PM »
If the bearings do spin freely, then it's likely the speedo drive isn't lined up. My mechanic that did my tire had that issue, and I only found out yesterday when I disassembled the axle and found the speedo drive had pressed into the retainer making new indents.
Offline fire113
« Reply #11241 on: July 20, 2012, 03:03:00 PM »
...cleaned the next two carb sets, finished the covers, they where chromed before and in bad condition.
Offline Spanner 1
« Reply #11242 on: July 20, 2012, 05:56:37 PM »
 ' fire 113 ' is on fire with all the bike work he does :o.... I'll bet he gets a K3 next and then maybe a K4  ;)
Offline piute
  • Piute
  • TRICK OR TREAT...B....es
« Reply #11243 on: July 20, 2012, 08:00:18 PM »
  After the batt. went dry and amped out my headlight,Melted winker wires and rear running l. e. d.'s,did I say blow a fuse,Made due by useing bagg lights for running and winkers,This state don't need no stinking headlight unless you wont some body to see you.
 So went and found some of the Ole route 66 ! Hella Hot so bettewr pics later.
« Last Edit: July 20, 2012, 08:02:02 PM by piute »
Ride to live Live for Jesus
1977 750 F2
Offline Tews19
  • I am no
« Reply #11244 on: July 20, 2012, 08:50:45 PM »
You were spot on with the speedo. Took that apart and noticed someone was there before and hacked the hell out of it. Took a spare one off another wheel and replaced.
I got the front end completely done. Everything mounted minus the headlight. Took her for a quick spin in the dark with no headlight and then pulled back into the garage. Tomorrow I will get the rest of the wiring done and new tire on the rear. Then hopefully for a ride before the wife heads out to see that one movie all the perverted ladies are seeing
« Last Edit: July 20, 2012, 08:57:33 PM by Tews19 »
Offline thecoy
« Reply #11245 on: July 20, 2012, 08:54:23 PM »
stayed 20 miles away from it cause im on call and its safely tucked away in my buddys nice dry safe shop
« Reply #11246 on: July 20, 2012, 09:08:43 PM »
Do you know where your buddy is?  :P
Fork oil drain. Mineral spirits flush. Refill. Road test.
20 min.  ;D
Offline thecoy
« Reply #11247 on: July 20, 2012, 09:12:22 PM »
hopefully hes soldering up some wires i didnt have time to finish the other night.
Offline Dimitri13
  • 1974 CB550K
« Reply #11248 on: July 20, 2012, 09:23:35 PM »
Great to hear :) Still doing my wheel bearings. Having my shop (that I worked at) bang em out because I don't have the right tools. After that I should be good to go.
Did you drive in both bearings all the way, or is one a floating bearing?
Offline fire113
« Reply #11249 on: July 21, 2012, 02:52:36 AM »
Hi Spanner,
...nope! just bought two K2's and a K0 frame  ;D
