Author Topic: 16t/48t gear ratio safe to run  (Read 6394 times)
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
Re: 16t/48t gear ratio safe to run
« Reply #25 on: April 05, 2010, 05:08:57 PM »
So getting one of those 40 tooth rear sprockets just doesn't sound practical if you plan on some highway miles?
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline mrbreeze
  • Not your average
« Reply #26 on: April 06, 2010, 10:28:49 AM »
40 is great for the highway (I run 42). Not as good in town but I'm not a stop light racer either.The stock 48 tooth will put you at a higher rpm on the freeway than a numerically lower numbered sprocket.
MEMBER # 257
Offline swellguy
« Reply #27 on: April 06, 2010, 11:22:13 AM »
Hey thanks, sometimes my math works backwards.
