Author Topic: installed webcam 41 grind.. motor seems to run hot?  (Read 5918 times)
Offline garretcb750
« on: May 04, 2010, 01:40:00 AM »
OK fellas, here is my story, last night I decided to tear into the motor for my bike, I had a webcam 41 grind cam sitting around for awhile an decided to go ahead and install it. I tore the motor out of the bike, installed the cam and got the motor back in the bike in one evening. The cam seemed to be very SLIGHTLY retarded on its timing. So I was skeptical of how it would run. When everything was back together it fired right up, sounded great, but it was running really hot. My question is this because the cam needs to be degreed? or is it running lean? Webcam says this is a "bolt in" cam. It seems to run too well to be a valve timing issue but I could be wrong.
  • Moderator
Re: installed webcam 41 grind.. motor seems to run hot?
« Reply #1 on: May 04, 2010, 02:22:16 AM »
The 41 is a bolt in cam and should be OK at stock cam timing.
Sam. ;)
« Reply #2 on: May 07, 2010, 08:04:45 AM »
You are adding more air into the cylinders with a bigger cam, more then likely you are running lean.
Yeah that'd be my guess. May need needle adjustment as well as main jet. Does it pop on decel?
Offline KB02
« Reply #3 on: May 07, 2010, 08:30:19 AM »
I've got the 41a in my 850 bike. I did need to degree it. I would listen to the other, though, as it does sound like it running lean.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline kos
    • m3racing.com
« Reply #4 on: May 07, 2010, 12:12:17 PM »
Also, verify ignition timing.
KOS
220...221, whatever it takes.
Offline Big Jay
    • CBRzone
« Reply #5 on: May 23, 2010, 04:38:30 PM »
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #6 on: May 23, 2010, 05:23:50 PM »
degree it anyway...why ?  because there is too much play around the cam sprocket bolts..... you cam thank me later    ;D
I like berries.
« Reply #7 on: May 23, 2010, 06:06:16 PM »
No, the cam should not make the motor run hot. Were you riding the bike when you observed this, or running it stationary with no air-flow over the cooling fins? If the latter, use a fan next time..
Offline KB02
« Reply #8 on: May 24, 2010, 04:44:46 AM »
Yeah, bolt in with one of these:
(nice and subtle, Jay.  ;D ;D ;D (and I agree... ;)))
I've got the 41a webcam in my bike and it does not run hot.  One other thing to add to the suggestion of degreeing the cam is to check your carbs. This cam will let in more gas/air than stock, so if you are running stock jetting, you may be running it lean as well.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
« Reply #9 on: May 24, 2010, 10:31:25 AM »
hi i m vist your web site for the first time and i gained knowledge from your web site. your website is great and much informative.. i like most in this is by the time mcp questions About this indicates that describes visually the concept of information, ie, the set of skills, abilities, behaviors and attitudes that enable the individual to search, access, evaluate and effectively use the most relevant information are every one usefull.I enjoyed my time working for them and I was treated really well. I just happened to google myself and found your website. I am now a big fan. It was so strange to find someone actually cool.
That's Fantastic!
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
Offline johnyvilla
« Reply #10 on: May 24, 2010, 04:57:53 PM »
I too installed a 41a in my 836 and it was 2 teeth off from the standard setting. No over heating.
« Last Edit: May 24, 2010, 05:48:37 PM by johnyvilla »
Offline rlvitt
« Reply #11 on: January 29, 2014, 03:45:58 PM »
I just dropped a 41a grind into my K0. It's running rich as heck. I've got #35 idle jets in and 120 mains with the needle dropped all the way now. It is still running rich and I'm having a bad time synching in the carbs. Also my inductive timing light will not pick up the spark signal to re check the timing though I'm running a Dyna electronic ignition and Dyna 5 ohm coils. I don't know where to begin to check for the problem. The idle is rough at 1000rpms and seems to smooth out by 3500 rpms. Does any one have an idea where I should start first?  Thanks
« Reply #12 on: January 29, 2014, 03:53:57 PM »
Any aftermarket cam should be timed using an adjustable cam sprocket
« Reply #13 on: January 30, 2014, 03:10:01 AM »
Ran Ok with old cam and same carbs?
I have had rich on low rpms. Horrible rich to start with, "Tsunami carbs" when they squirted fuel due to wrong ignition advance, full advance direct.
Step 2 was floats in carbs.
Clear tube verified that, show the result of float adjustments, float valves OK or sticking floats.
Offline rlvitt
« Reply #14 on: January 31, 2014, 01:45:34 PM »
MReick, The cam was installed with an adjustable cam sprocket at TDC. And the Dyna ignition was timed spot on with a timing light. Since then I've tried to check the timing again and can't get a reading from the timing light even with the Dyna coils installed. I know the light works after checking it's function on my truck. PeWe's idea about checking the float levels is also something I've been checking, along with leaner jetting. The whole thing is that I don't know now if I'm working with just one problem (the carbs) or two (carbs and ignition). I'm planning on installing new float valves just to make sure the bowls aren't over filling. But, so far I've checked them with a clear tube and they seem to be cutting the flow of at the 25 or 26 mm level.
I've installed new idle screws with the holes in them as that is one of the K0's original designs. They're turned out 1 full turn as were the old solid air screws. The main jets are 120's. I'm going to drop them to 110's and see if that leans the combustion out more. The needles are set on the top step already.
What I would like to know, also, is what characteristics the 41a grind has in smoothness at idle. Should I expect a rougher idle and how much rougher? I've only had experience with stock cams so I have a lot of questions about street cams......
« Reply #15 on: January 31, 2014, 01:58:51 PM »
I have a 41 in a 888cc engine with VM29 mikunis and a ported head, luscious, by MRieck. I did use a degree wheel and slotted sprocket to say that I did, even though its a drop in cam.  The degree wheel set it more accurately than the regular marks would have. The 41 is wimpier than a 41a. Mine is perfectly civil, idles sub-1000, and builds revs nicely. Call it pleasant. I'd say the same for a 41a.
Though a stock head and carbs will not lend any help to the cam, so it may be rougher running in your case.
Offline rlvitt
« Reply #16 on: January 31, 2014, 03:21:19 PM »
MC, I was doing a little work on it today. It idled down at about 1100 fairly nicely with the "old" style idle screws installed. Still rich though. I found the #1 and #4 carbs dumping gas though. I believe I'm going to have to explore the floats again. Could be that I've got some junk up in the float valve though I blew them out with compressed air. Looks like I'm going to have to pull the bottoms off and change to 110 main jets and replace the float valves and put in a set of #38 idle jets in place of the #35's in there now.
I managed to check the timing and it was spot on at 3000 rpm. The light doesn't want  to work until the rpm's are above 2500 for some reason.  It seems to run nicely in that range any how. I'm still trying to figure out why the light won't function until the rpm's are raised......
« Reply #17 on: January 31, 2014, 03:39:11 PM »
Sounds like if you have a rough idle its due to the carbs.
When you say the light doesn't work, what do you mean?
2500rpm sounds suspiciously like a stuck spark advancer, but that shouldn't affect the light. Just thinking...
Offline rlvitt
« Reply #18 on: January 31, 2014, 04:35:40 PM »
I agree that it's probably due to the carbs. They are the original carbs And I know they've never been opened since the early. So it's a sure thing that the cam change means they need to be refitted for proper carburation. It's probably going to be a matter of mixing and matching until I get the right sized jets in place. But what bugs me now is that the timing light does not function until the enging reaches about 2000/2500 rpms and then begins to flash. The timing marks are advanced to the proper marks when I check. I don't have reason to believe that they are stuck in the advanced position though. However I sure would like to confirm that by being able to check them at idle speed.
« Reply #19 on: February 08, 2014, 11:51:48 AM »
tried
the timing light sensor pointing at the other way?
another spark plug cable?
« Reply #20 on: February 08, 2014, 01:55:39 PM »
try hooking your timing light power leads to a battery that is not connected to the bike...I read this somewhere but can't remember why it makes a difference...but have had problems before with inductive timing lights on these bikes and using a spare battery for powering the timing light fixed it
Offline rlvitt
« Reply #21 on: February 10, 2014, 09:52:53 AM »
Thanks for the input guys. So long as my timing light shows the proper setting at the advance marks I pretty sure it's on the F mark at idle. I am going to try a second battery though. My spark advance seems very flexible and shows no sign of being stuck otherwise. I am centralizing my efforts on the Carbs at this point. I changed out all the jets and ploat valves. I put #40 idle jets in and dropped the main jet to  110. I had already dropped the needle to the top setting as advised by Hondaman. At this point I'm trying to make sure that the floats are operating properly. I'm noting a fuel overflow in the #1 and #3 carbs since the rebuild. I pretty sure that their levels are set properly at 25mm. I used a float gauge to check and adjust them if necessary. I am going to recheck their height using a clear tube off the float bowl drain to check the fuel level in the bowls.
Now here's a question that popped into my mind last night. I have the fuel tank feeding the carbs through am extended line from a shelf near the bike. The shelf is about 3 feet higher than the carbs. Could it be possible that there is too much "head" pressure from the elevation of the tank and that it might be forcing fuel past the float valves due to the pressure?
Thanks again for all teh advice and ideas. It is much appreciated.
Bob Vitt
« Reply #22 on: February 10, 2014, 11:02:06 AM »
Bob Vitt
I, and many racers and go-kart mechanics, etc, use an umbilical tank hanging from the ceiling for shop running the engine without the gas tank. No problems with pressure.
Offline rlvitt
« Reply #23 on: February 11, 2014, 03:15:07 PM »
Thanks MCR. I've seen them but I don't know who sells them. I tried to fashion my own and it didn't work too well. Should've been a simple thing...... I dropped the tank height down to a more natural level and that seemed to reduce the head pressure. I checked the float levels with a clear tube and found the float levels all over the place. One fuel level was at 3-4mm from the top of the bowl and another's was 30mm from the top.  Time to start bending fuel valve tangs and get them adjusted right.
Offline Tintop
« Reply #24 on: February 11, 2014, 03:39:33 PM »
I use an old plastic (no rust ;)) gas tank off a lawn mower.  Got it for free from my local small engine repair place off a junked mower.  Just need to add a something for a fuel shut-off tap.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
