Author Topic: 1975 CB750F Cinder Cone  (Read 20312 times)
Offline CBcafeJunkie
  • 75 CB750F
« on: May 07, 2010, 03:09:30 AM »
I have enbarked on an uneducated Journey to education by way of the road of hard knocks (or not so hard with the help of this forum.) by rebuilding my first bike and engine. I got it from someone living on a lake for $400. It had a frozen engine and about 2 cups of water in the exhaust manifold and head. :o. So far i have ripped it all the way down to a practically empty crank case and bare metal frame. I have painted the tank red with 4 white pinstipes that run into the rear cowel. Looks Sweet 8)
« Last Edit: November 30, 2013, 08:04:20 AM by CBcafeJunkie »
  • 75 CB750F
Re: My First Build 1975 CB750F
« Reply #1 on: May 16, 2010, 05:23:01 AM »
So here's the bike, head and cylinders I started with
  • 75 CB750F
« Reply #2 on: May 16, 2010, 05:25:56 AM »
Heres Some of the painted Items the tank doesnt have the stripes peeled in this pic as you can see
Offline KB02
« Reply #3 on: May 16, 2010, 06:25:10 AM »
Looking good far!!  8)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
  • 75 CB750F
« Reply #4 on: May 16, 2010, 07:06:09 AM »
Thanks man. Im going through a debate on wheather to make custom mounts for my oil tank like a bike I saw earlier or to just get it powder coated and go.....hmmmmm decisions decisions
  • 75 CB750F
Re: My First Build 1975 CB750F excitebike :)
« Reply #5 on: May 17, 2010, 06:19:58 AM »
So Im racking my brain in the ER, at madigan army medical center where I work on what i can do next. I have poured through the posts and have found a few things that are somewhat affordable to me now and some I know I will have to do later. Heres what i came up with so far.
1)Finish sandblasting and removing grease from my frame, swingarm, center stand, electrics plate, and battery box.
2)Remove old a** tires and clean/ beadblast rims. (Thinking about black rims with red spokes and white wall tires for wheels.....Now should I powder coat them or just paint em up???)
3)Paint headlight bucket
4)Strip paint of calipers and repaint white??? not to sure about this one.
5) Design my custom guage face plates. (Does anyone have a template or do i need to make one so others can design and have their own printed? anyone interested?)
6)Clean wire connections and grease em up dielectricaly :)
7)Clean up parts with brake cleaner.
8) Design custom oil tank.
9)Rebuild my forks
10) polish everything
Does anyone know some place near tacoma that lets you weld, powdercoat, sand blast and paint like techshop in Cali and Ptown oregon?
Any other sugestions?
  • 75 CB750F
« Reply #6 on: May 20, 2010, 08:50:05 PM »
So Im debating on GSXR front end or a 78 with modern duel disc brakes. Pros Cons?
traveler
Re: My First Build 1975 CB750F please Comment or advise!!!
« Reply #7 on: May 20, 2010, 11:21:02 PM »
Just say "NO!" to white wall tires on CB's! >:(
~Joe
  • 75 CB750F
« Reply #8 on: May 21, 2010, 12:32:14 AM »
~Joe
Why it will look Sick!!  8)
  • 75 CB750F
« Reply #9 on: May 21, 2010, 01:20:08 PM »
I was thinking of using the 78 forks to do duel discs infront then it was recomended to me just to switch the Rome from left to right so they mount with the breaks behind the forks. I will then have to make brackets to support modern breaks. not sure about the discs yet though. Well see.
  • 75 CB750F
« Reply #10 on: May 29, 2010, 02:24:13 AM »
So i took my frame swing arm and tripple trees to get coated yesturday. im so excited to see what the result is. My frame is going to be white while the rest of the pieces are getting sprayed the same red as my tank.
  • 75 CB750F
« Reply #11 on: June 04, 2010, 03:32:03 AM »
Well I just got my Frame back and im completely extatic with the results!! I belive i made a mistake though...Iwas in such a rush to get it done that I didnt take into account that I may need to do a few frame mods :( Oh well I guess there are worse things. None the lest its awesome. Heres some pics...the bottom is sort of my inspiration. I really like the hidden oil tank and electric fittings. Im reserching some options. Ive thought of taking an old gas tank and cutting it to make a rear cowl/oil tank and using the same electrical set up that "The Archetect" used.
« Last Edit: June 04, 2010, 03:54:32 AM by CBcafeJunkie »
Offline KB02
« Reply #12 on: June 04, 2010, 04:06:07 AM »
Yeah, that Wrench Monkey's bike has been inspiration for a lot of people. It is one slick looking ride.
I'm liking your paint. The white looks nice.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
  • 75 CB750F
« Reply #13 on: June 04, 2010, 04:15:23 AM »
So I work in the emergency room as a medic in the army and had a guy come in who wrecked his harley springer preatty bad. We got to talking and he said he had a 72 motor that worked!!! On top of that he just wanted it out of his garage so i went to pick it up. I Just ordered some finned tappet covers from parts and more check em out!
I also really want to find a finned clutch and points cover (PM me if you got one!!!)
« Last Edit: July 02, 2010, 04:57:02 AM by CBcafeJunkie »
Offline tweakin
  • tear down
« Reply #14 on: June 04, 2010, 04:39:24 AM »
Looks good.  Who did your powder work?  I have used just about all the coaters in the Tacoma area and they start off good but then raise the $$ or the work starts to be sh*tty.
Offline jaguar
« Reply #15 on: June 04, 2010, 09:25:45 AM »
if you run a 78 cb750F front end you can swap on 1982 twin piston oem honda calipers.
i like the look of the "vintage" front end rather then the "modern"
traveler
« Reply #16 on: June 04, 2010, 09:33:07 AM »
Looking back....now that I have built a cafe.....I would go with a more stock setup, unless your shorter than 6 ft.
Modern forks look really cool, but from a performance standpoint, unless you are going to ride her flat out in the corners, a modified (re-sprung) stock front end is more than capable.  As far as brakes....well, you can never have enough of them, IMHO.
And contrary to what some will tell you, you can buy lower priced springs (front and rear) and still get the handling needed for a hot street bike.
~Joe
« Last Edit: June 04, 2010, 09:34:58 AM by traveler »
Offline HellFishTat
  • I've UPGRADED to a '99 BMW R1100S
« Reply #17 on: June 04, 2010, 02:07:28 PM »
I like the paint.  I just recently realized that's it not as easy as I thought.  For me, I like the look of a mod/stock CB750F.  I have already bought forks off a '01 GSXR 750 to make the conversion this winter.  That and a boxed/widened swing arm with modern rear shocks and brakes is all I need to do.
If Honda, Suzuki, Yamaha or someone made a naked/standard MODERN 750cc-900cc motorcycle, I'd buy that and be done.
Cheers!
and Ride Safe.
Offline the architect
« Reply #18 on: June 07, 2010, 06:15:52 AM »
How about one that's just slightly larger?
http://www.youtube.com/watch?v=3Dn19VbH_98
Rider no. 83 on the 2013 SOHC/4 Honda World Tour
Rider no. 228 on the 2012 SOHC/4 Honda World Tour
Rider no. 70 on the 2011 SOHC/4 Honda World Tour
my '75 CB750 cafe build photo documentary:  looking for the Lone Stars is like playing Where's Waldo -- enjoy.
http://www.flickr.com/photos/34828040@N05/sets/72157615892537535/
CB350 twin, rigid meat grinder:
http://www.flickr.com/photos/34828040@N05/sets/72157627005176764/
Blip Workshop
http://www.blipworkshop.com
http://www.facebook.com/blipworkshop
  • 75 CB750F
« Reply #19 on: June 07, 2010, 08:44:47 AM »
I used rainier powder coating. He has a small home built oven and works
out of auburn. I found him on craigslist. Craigslist says he's in sumner if you look it up. If you go in tell him Ahren (Aaron) sent you.
Offline tweakin
  • tear down
« Reply #20 on: June 07, 2010, 12:04:33 PM »
Yep.  Rainier was the last shop I used to.  Jeff does some good work for a real fair price.
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #21 on: June 07, 2010, 01:05:45 PM »
nice frame!! i've been toying with the red and white paint theme, but im still leaning towards red and silver.  yours looks great though!!!
Offline jaguar
« Reply #22 on: June 07, 2010, 06:38:29 PM »
yeah i love the white frame.
always liked the ducatis that did that
  • 75 CB750F
« Reply #23 on: June 08, 2010, 06:54:31 AM »
only thing im not gonna like is cleaning it all the time:) I should be getting my kick and center stands back soon along with the swing arm and a few odds and ends. Anyone know how long dupicolor engine enamel holds up?
  • 75 CB750F
« Reply #24 on: June 08, 2010, 06:56:52 AM »
oh yeah i just got a cool gauge bracket from "the Architect" should be here next week
