Author Topic: rear hubs  (Read 834 times)
Offline rustrocket92
  • Mad Fabricator
  • Buster is in the Lab!
rear hubs
« on: May 25, 2010, 09:10:24 AM »
I have a couple different rear hubs and brake assembly and I am wondering if the 78k rear hub is the same as 73-76k hub ?
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Re: rear hubs
« Reply #1 on: May 25, 2010, 09:17:50 AM »
 It should be the same.. the sprocket carrier is different.
 77/78 K should have 17 inch rim if it is stock.
Offline Old Scrambler
Re: rear hubs
« Reply #2 on: May 25, 2010, 11:58:41 AM »
+1 with 754...........the sprocket carrier is wider but the earlier carrier will fit.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
  • Mad Fabricator
Re: rear hubs
« Reply #3 on: June 14, 2010, 01:45:36 PM »
Well I figured since I got off work a lil early friday I would attempt to lace the hub to my 16" wheel. I had everthing all laid out. Got me a couple beers and all the articles and how-to I could find for reference. Well it didn't go well. All the articles I had showed 2 spokes that looked the same but had a slightly different curve at the end my spokes have the same curve but 20 of them have a slight bend to them. I checked out tasclassic motorsports and they have the same spokes as me but their part description states they are all inside spokes no wrap arounds. So now I am back to the drawing board! ???
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
Re: rear hubs
« Reply #4 on: June 14, 2010, 05:11:10 PM »
Every 16 I've ever seen were all laced with 40 inside spokes with a cross one pattern. So 20 spokes would have to be a little different to cross over the other 20. Nevertheless all are inside spokes.
Hope that helps.
  • Mad Fabricator
Re: rear hubs
« Reply #5 on: June 14, 2010, 07:10:19 PM »
thanks mc rider for the help! I will have to try to find a good picture of one all laced on the inside because 16" wheel that came on my 73k when I bought it has both inner and outer spokes. Therefor it doesn't do me much good as a reference.
1973 cb750k
1976 cb750k
1978 cb750f
1978 cb750k
