Author Topic: Gear selector spline oil seal  (Read 1562 times)
Offline pablo78cb550
  • mmmph.
« on: February 07, 2006, 10:54:14 PM »
so i noticed a very very small amount of fluid like substance under the gear selector shaft. only a small amount because i haven't filled in with any oil yet. i'm still putting the bike together.
i'm wondering if i can replace the oil seal, with out removeing the shaft?
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Re: Gear selector spline oil seal
« Reply #1 on: February 07, 2006, 11:11:40 PM »
Yes, of course.
I use an old worn 1/8" tip flat blade screwdriver with a long shaft.
Use it like a chisel with the flat facing the shaft about 1/3 the distance from the outer edge to pierce the seals metal ring embedded in the rubber.  Once pierced, pry the seal out without nicking either the case OR the shaft.
Put thin tape on the shaft splines so they don't nick the new seal during install.
Press or tap the new one on with plastic pipe or other tubing with an O.D. just a bit smaller than the new seal.
  • mmmph.
« Reply #2 on: February 07, 2006, 11:20:52 PM »
thank you so much. i didn't want to have to have the mechanic work on it again. the cylinder and up rebuild was to much.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha XS400
1978 Honda CB550K
Sold off:
1992 Yamaha FZR600
