Author Topic: Who knows anything about boats?  (Read 17944 times)
Offline GroovieGhoulie
  • I have to return some videotapes.
Re: Who knows anything about boats?
« Reply #150 on: August 06, 2010, 09:31:39 PM »
From now on, Photos will be required to receive intelligent responses.
Yep.
Outdrives are foreign to me, (Inboard driver), but I'll go with SS being good, along with brass.
Seriously, post pics.  A pic is worth a thousand words, after all...  LOL!
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #151 on: August 06, 2010, 09:32:35 PM »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #152 on: August 06, 2010, 09:34:06 PM »
Don't know what is is, but you most likely want the new one to be stainless...
My guess is at some time over the years, the owner failed to replace the zincs on the leg.  The "pipe/line" was the easiest target for electrolysis.
Here is a good article on the subject.
http://www.boatus.com/boattech/casey/23.htm
Edit: Good hunting!
OK. So the count begins $53.89
Take a couple of photos of the legs....
This is good info from that link, pull the prop of and have a good look at it. They are cheep!
 "Propellers are normally protected by a zinc collar fashioned in two pieces and bolted together around the shaft forward of the propeller. It is essential to make sure the shaft is clean and bright before clamping the collar to it. Corrosion protection for outboard and outdrive propellers is typically provided by a bolt-in-place zinc ring or a zinc prop nut."
There will  usually be another one on the horizontal fin to protect the leg and components.
Offline Grnrngr
« Reply #153 on: August 06, 2010, 09:50:22 PM »
If their daughter can't hook you up, there's an outboard wrecking place on Foster betweeen 82nd and 205 that would be a good place to start looking...if you wanna go cheap...
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline Spanner 1
« Reply #154 on: August 06, 2010, 09:51:57 PM »
All freshwater here ... no need for sacrificial zinc.... btw,  + 1 million on never starting your engine 'dry' or ( IMO ) with one of those 'water ears' that sit over the water intake... boat backed into the lake/river/ ocean minimum to start motor.... or serious damage fast :(
« Reply #155 on: August 06, 2010, 09:55:26 PM »
Used a "Fake-a-Lake" a few times, and a running hose plugged right into the raw water intake hose other times.  Never had a problem as long as the revs never got too high.  Eight years on.
I mean, yeah, don't rev it to the moon in the driveway with a hose hooked up, but for idling, no biggy.  The raw water pump ain't pulling that hard.
(Fresh-water-only here too.  This "anode" stuff is above my paygrade.  No towboats certified for saltwater.)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #156 on: August 06, 2010, 10:01:56 PM »
I have used the "dry dock" hose adaptors for 25+ years with no problems.
Not sure why you had issues  ???  Could have been something else and it just happened at that time.
Offline Spanner 1
« Reply #157 on: August 06, 2010, 10:02:33 PM »
Yeah, just I've seen too many idiots trying to start their 2-stroke ( not that that matters ) outboards 20 feet above the water after a winter season of neglect before they back'em into the water.... the water pump impeller disintergrated way before the boat was launched  :o
Offline Grnrngr
« Reply #158 on: August 06, 2010, 10:03:25 PM »
The Columbia is tidal, not sure how far up the salt comes, or how far down the POs took the boat, even out in the ocean would be easy from here......a serious freshwater washdown is a good idea everytime you haul it out no matter what water you use it in...
'77 CB750A
« Reply #159 on: August 06, 2010, 10:07:13 PM »
Well that's just dumb.  I never start up until the pickup is in the water.
Offline Spanner 1
« Reply #160 on: August 06, 2010, 10:08:36 PM »
Well O.K. on the water ears.... luckily I'm 1 mile from the boat dock and any engine 'tweaking' can be tested in the lake in 5 minutes  ;D
Offline paulages
  • 1976 cb735
« Reply #161 on: August 06, 2010, 10:11:20 PM »
there is a zinc fin above the prop that appears to be in good shape, though it seems that bad shape would indicate bad things..
regardless of whether or not this boat has seen saltwater, there is clearly some electrolytic corrosion going on. i'll check out other parts for problems tomorrow.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline pdxPope
  • Hit Shit, Hat Shat, Hut Shut,
« Reply #162 on: August 06, 2010, 10:28:06 PM »
Paul,
We've been out all evening w/ friends, so I'm just getting to this. Funny thing we were just up the street from the shop (EastBurn- 17th & Burnside. Great food, BTW) and I seriously thought about driving by to see if you'd bought anything! Sounds like everything worked out very well. Projects that start out with good karma usually fare well.
Anyway, I have no idea what that particular piece is called other than a hydraulic junction block(?) I'm sure somebody will have one. Those outdrives are super common.
I agree, you should check the zinc anodes & replace if necessary. ALL boats ground themselves to the hull, so even in freshwater they produce electrolysis (although, salt water certainly speeds up the process).
HELL YEAH- let's see if we can get it wet this weekend! I'll give you a call tomorrow and set up a time to meet you @ the shop.
(Hope that all made sense. I think we might have done a little more drinking than eating @ dinner)  ;)  8)
-JP
The flowers say "Let's go shopping together..."
While the unicorn whispers "...for adult toys."
Offline MickeyX
« Reply #163 on: August 06, 2010, 10:44:54 PM »
you may get lucky at Harvey Marine in Aloha. Or you may not. but, they've been there for a long time and have older boats sitting there for sale. they may at least be able to point you in the right direction.  :)
Offline Grnrngr
« Reply #164 on: August 06, 2010, 10:46:42 PM »
That new zinc fin might be because the old one got eaten up and they just didn't get around to replacing (or noticing) other affected parts..
'77 CB750A
Offline paulages
  • 1976 cb735
« Reply #165 on: August 06, 2010, 11:15:24 PM »
JP- too bad you didn't stop by! if you're not busy tomorrow, feel free to swing by. Their daughter owns Columbia Marine Exchange, pretty much right at the intersection of 33rd and marine. I'll be there in the morning buying the random stuff that didn't come with it... depth/fish finder, anchor, marine-tex, etc. i'll call around for that part, but if i can't find it i'll have them order it.
MX- thanks, i'll try them. i'd love to find the part in town and get on with it.
grnrngr- the zinc fin doesn't look too new, actually. i talked to the the seller after that last post, and he seemed to think that the other zincs he came across looked good. we'll see, i suppose..
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #166 on: August 06, 2010, 11:22:51 PM »
some pics:
sorry for the sun and bad cell pics..
my lady friend Rebekkah testing out the fold-down seats:
marine-tex over fiberglass patching... the seller was doing the fairing. apparently the PO had done the glasswork. it feels much more solid than the surrounding areas. i'll be finishing this tomorrow and patching a couple small holes in the transom, like where the fuel line ran to the outboard motor:
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Grnrngr
« Reply #167 on: August 06, 2010, 11:29:29 PM »
heh...gotta feelin you'll not be at the shop much for a while... ;D
'77 CB750A
Offline paulages
  • 1976 cb735
« Reply #168 on: August 07, 2010, 12:03:11 AM »
whatcha mean? gotta use the tools and air to work on it.  ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #169 on: August 07, 2010, 12:25:36 AM »
That dashboard is "money" ;)
Offline paulages
  • 1976 cb735
« Reply #170 on: August 07, 2010, 12:27:49 AM »
i feel like i'm in an old bond movie when i'm sitting behind it.  ;D i just want to know where the torpedoes and machine guns are...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #171 on: August 07, 2010, 05:01:53 AM »
Congrats!  Best days of a boat owner are the day you buy it and the day you sell it!
Offline Grnrngr
« Reply #172 on: August 07, 2010, 07:44:45 AM »
One of the most important items for people on the water...Don't forget plenty of SUNSCREEN!!!  and once you get that fitting replaced, the only work you should need to do would be to bolt on a turbocharger..  8)  I have a danforth anchor you can have if you want, I'm gone all day today, but I could get it to you sometime tomorrow..along with the anchor, you need about 3-6 feet of chain and about 50 feet of anchor line (there are no "ropes" on a boat)...
'77 CB750A
« Reply #173 on: August 07, 2010, 08:06:49 AM »
I have 4 "ropes" on my boat, 2 for wakeboarding and 2 for tubing!
traveler
« Reply #174 on: August 07, 2010, 09:10:31 AM »
Really neat!  I like the old boats.
The paint is worn off on the edges of the steering wheel!  That old girl has some serious nautical miles on her! ;D
The hull repair scares the crap out of me though. :(
~Joe
