Author Topic: Honda ATC70.....MY FIRST BASKETCASE!!!  (Read 17474 times)
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« on: September 04, 2010, 08:27:11 PM »
OK, so most of you know me on here as the guy with the fugly CB550 bastard cafe racer, and the replacement CB750 sidecovers...well I have a new toy- project. I have been looking for a Honda 3 wheeler all summer, and last week I found one on CL from a guy on the other side of town. He told me ahead of time that it was apart and "waiting to be restored", and in his basement there it was.....apart. He had everything perfectly taken apart and in nice little piles. So, then lets get to it then.
This is how all projects start off right?
« Last Edit: September 07, 2010, 07:08:31 AM by frankenbike »
Re: Honda ATC70.....MY FIRST BASKETCASE!!!
« Reply #1 on: September 04, 2010, 08:32:00 PM »
DAY 1
BEFORE
carb needs to be cleaned
Took it all apart (I refuse to buy rebuild kits unless really really bad)
I use an ultrasonic cleaner with orange degreaser and the heater on.
« Reply #3 on: September 05, 2010, 05:16:14 AM »
WOW. Mine came with a good front fender, no tires, and my seat pan is worse than that. I am not sure of the year on mine. The guy told me 81 but I think it might be a 77. I tried a VIN decoder on an atv forum and it said "invalid".
Offline AHuff
« Reply #4 on: September 05, 2010, 08:51:59 PM »
Nice, I will get mine out of my house eventually.
[img width= height=]http://lh5.ggpht.com/_idGp-Y7uikY/TIRk-W0TNYI/AAAAAAAABKQ/pzJVzezWCd4/s288/ATC70.jpg[/img]
Glamis Dunes forum, Planet minis forum, Dr ATV, Sterdy Products, there is lots of info and parts out there depending on what you want to do.
« Reply #5 on: September 05, 2010, 11:09:23 PM »
sweet apehangers man! Thanks for the info on those sites. Where is the cheapest place to get tires? Or are they always about $27 a piece?
« Reply #6 on: September 06, 2010, 05:57:31 PM »
Day 2
I powerwashed all of the junk, and degreased with orange citrus.
tank before (pinholes, jb weld...and rust galore)
Going into the electrolysis dip. This was the first phase, the next one was a full dunk with the mesh surrounding it for 24 hours. wow
« Reply #7 on: September 06, 2010, 06:04:32 PM »
Engine after powerwash/before wire brush, bead blast, degrease
« Reply #8 on: September 06, 2010, 06:15:16 PM »
This is what my goal is.....just a clean stock look, not a restore, just clean. Then I will beat on it. ;D
« Reply #9 on: September 10, 2010, 05:17:39 PM »
I just painted the tank forks and fenders. dripping. awesome.
Offline jneuf
« Reply #10 on: September 10, 2010, 05:23:34 PM »
Oh man! I had one of those when I was a kid! Awesome!
'75 CB400f
« Reply #11 on: September 13, 2010, 08:06:02 PM »
Engine and frame are painted.
« Reply #12 on: September 22, 2010, 06:59:31 PM »
Just finished buffing and putting on tank decals.
« Reply #13 on: October 05, 2010, 07:33:14 PM »
Going together OK, but..tires lose air within minutes, spark is weak, I stripped the idle scew in the carb, have a cup O' leftover nuts and bolts and dont know where they go, large washer from rear axle goes where? petcock (petrol lock for SAM750A) leaks and the threads are gone to tighten it up....anything else? looks great though!!!
Offline scunny
  • don't call me expert
« Reply #14 on: October 05, 2010, 07:36:47 PM »
rigid front end ? you must have young kidneys.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #15 on: October 05, 2010, 07:39:54 PM »
Old kidneys ;D the tires are only filled to 7psi
« Reply #16 on: October 06, 2010, 08:08:44 PM »
Fresh paint with new decals. I used an epoxy fiberglass to fill the pinholes and line the tank.
« Reply #17 on: November 11, 2010, 02:05:32 PM »
Will. NOT. start.  >:( Am I an idiot? What am I missing. Strong spark, clean carb???? My back is killing from pull starting and all it does is *pop* every now and then.!! Help me out
Offline HalfFastMoto
« Reply #18 on: November 12, 2010, 08:44:48 AM »
Check your valve timing   ;)
-brad
Better HalfFast than HalfA$$ed
The appropriate number of bikes is "1" more!
« Reply #19 on: November 12, 2010, 09:25:20 AM »
how? points?
« Reply #20 on: November 12, 2010, 10:27:48 AM »
how? points?
Looks like you can download a pdf shopmanual here - http://www.freepdfmanual.com/2008/11/15/honda-atc70-official-shop-manual-1973-1984
Once you have the manual look up how to set TDC, adjust valves and finally the points
-brad
« Reply #21 on: November 12, 2010, 02:42:05 PM »
Thanks Halfastmoto. Such a simple motor....and it is messing with me. :-[
« Reply #22 on: November 13, 2010, 08:45:21 AM »
Give it a small shot of starting fluid and see if it at least fires up for a couple of seconds. Also make sure the idle screw isn't set to low.
« Reply #23 on: November 15, 2010, 09:30:32 AM »
Will. NOT. start.
So, did ya get her running over the weekend?   ???
-brad
Offline rippy154
« Reply #24 on: November 16, 2010, 05:37:55 PM »
So Frankenbike isn't your first basket case??????????
