Author Topic: How to route the K0 throttle cable?  (Read 5194 times)
Offline Magpie
« on: October 01, 2010, 03:20:57 PM »
I want to install the handlebars etc. and having trouble figuring out the correct route for the single throttle cable and where it splits to 4 cables. Does the single cable go around the left side of the steering head and under the cross member at the rear of the coils then attach to the splitter to the 4 cables from the carbs? It seems the cable is a bit short that way and may be better going in on the right side of the steering head. Pictures of a K0 without the tank on would be perfect.
Thanks in advance,
Cliff.
Offline Bob Wessner
  • "Carbs Suck!"
Re: How to route the K0 throttle cable?
« Reply #1 on: October 01, 2010, 04:37:57 PM »
Can't guarantee this is correct as I'm the scond owner, but mine goes through the bar collector and then down the right side of the neck.
Offline Johnie
« Reply #2 on: October 01, 2010, 05:52:02 PM »
Hi Cliff...mine goes the opposite of Bob's. It runs through the collector and to the left side of the steering head. It connects with the splitter under the coils. That is how I found mine after sitting for 19 years in a garage covered up. I am not having any trouble with it being to short.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: October 01, 2010, 05:59:59 PM »
That's interesting, John. I had to strip and clean my carbs etc. and when connecting things back up, thiught I would try it around the left side, but it was tight and turning the bars caused binding so I returned to the right side. Go figure.  :-\
Offline Johnie
« Reply #4 on: October 01, 2010, 06:12:50 PM »
Interesting Bob...I should go turn my bars to the right and see if it binds? The only reason I put mine to the left is that is how it was when I got it. Might not be the way Honda had it? Don't know for sure...
Oshkosh, WI  USA
Offline Magpie
« Reply #5 on: October 01, 2010, 06:45:21 PM »
What do you mean when you say "the collector"?
Cliff.
Offline Johnie
« Reply #6 on: October 01, 2010, 06:49:30 PM »
The collector is the big hole between the gauges that all the cables run through.
Oshkosh, WI  USA
Offline Magpie
« Reply #7 on: October 01, 2010, 07:00:45 PM »
Thanks guys! I'll get to work on the carbs tomorrow and report back.
Cliff.
Offline Johnie
« Reply #8 on: October 01, 2010, 08:31:13 PM »
Cliff...on page 158 of the KO Honda shop manual there is a picture showing the throttle cable routing on the left side of the steering head as you are sitting on the bike. It is routed under the main wiring harness that passes in the area too.
Oshkosh, WI  USA
« Reply #9 on: October 01, 2010, 08:37:49 PM »
Is this the picture Johnie ??
Offline Johnie
« Reply #10 on: October 02, 2010, 06:07:08 AM »
Perfect...that is the pic. Nice....
Oshkosh, WI  USA
Offline Old Scrambler
« Reply #11 on: October 02, 2010, 12:24:49 PM »
The advice and the pic are correct.........but........the handlebars were changed a very small amount on later bikes to get rid of a 'binding' or cable-pull when the frontend was turned full to the right. I remember that was the case on my sandcast. It never bothered me.  Be sure your throttle sleeve is all the way onto the handlebar.  This was also true of the first models with the taller bars from K3 onwards. The angle of the bars was changed to reduce the overall length of the cable pull effect.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #12 on: October 02, 2010, 02:55:14 PM »
Vic pictures
« Last Edit: October 02, 2010, 02:56:46 PM by Simpson »
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Magpie
« Reply #13 on: October 02, 2010, 05:50:15 PM »
Beauty! Thanks for the pics. Here's mine. Now I notice my wiring harness is not routed right.  ;D
Cliff.
Offline Simpson
  • I ain't no
« Reply #14 on: October 03, 2010, 05:50:59 AM »
Mine is not routed quite right but I'm not changing it at this point.  ;D
1970 CB750 K0
1975 CL/CB 360 Mix
