Author Topic: What does your customized kick starter look like?  (Read 3898 times)
Offline q2418130103p
« on: November 25, 2010, 07:12:50 PM »
The rubber is missing from mine, so I am trying to think of a way to fancy it up.
What have you done?
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
KingCustomCycles.com
Re: What does your customized kick starter look like?
« Reply #1 on: November 26, 2010, 02:25:43 AM »
1.  Wrap it neatly with brass aircraft safety wire.
2.  Order new rubber with the words "kickstart" molded in
3.  Drill some holes and paint it flat black
« Reply #2 on: November 26, 2010, 02:52:43 AM »
slip some garden hose over it,or drill a hole through an artificial dog chew bone and slip it on.you might have to salivate on it first.
« Reply #3 on: November 26, 2010, 07:01:12 AM »
 Ness used to run a cool little knurled peg on them. Not sure how, but I thought they turned it in a big lathe, drilled thru it on axis, cut off the original part, then tapped and mounted peg. I suppose it could be done on a drill fixture easily. Havong a register lip would help  frpm bedong the bolt.
 Maybe I ahould make up a couple..
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #4 on: November 26, 2010, 07:25:08 AM »
how about a 1/2 set of brass knuckles? (check your local laws).  old school, unique, edgy.
searching for a dr350se
Hinomaru
« Reply #5 on: November 26, 2010, 07:31:46 AM »
The Synthetic Rubber Coatings such as Plast Dip (or similar) would probably work.
http://www.plastidip.com/home_solutions/Plasti_Dip
I've been wanting to test the Plast Dip clear in the spray can to control the coating thickness. The test would be on the underside of fenders and the inside of fork ears, both problem areas for rust and pitting. Perhaps some other miscellaneous SOHC parts could also benefit from the rubber coating?
« Reply #6 on: November 26, 2010, 10:41:04 AM »
I like the idea of knurled, no idea how to do it though.
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #7 on: November 26, 2010, 11:37:54 AM »
You'd have to cut off the knob at the end of the pedal part of the kicker, slide a knurled barrel over the pedal, then drill and tap a hole on the peg for a retaining screw (or nut), and washer,
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
« Reply #8 on: November 26, 2010, 07:20:33 PM »
 Yeah, but they aint round, better to cut most of it off, drill and tap.
 BTW a 750 kicker is handy to have uder the seat in your cage.. if you come upon someone trapped in their sinking or burning car, if you grab the pedal end and swing it, it will break glass..
 and good for maybe something else...
« Last Edit: November 26, 2010, 07:23:03 PM by 754 »
Offline Alan F.
« Reply #9 on: November 26, 2010, 07:41:07 PM »
Spotted this one this summer at a show, no idea what it's from but doesn't seem stock for a 750.
And yeah I have a few more of the bike if anyone cares.
« Reply #10 on: November 26, 2010, 07:48:30 PM »
 Like the canteen, nice touch!
« Reply #13 on: November 27, 2010, 06:21:06 AM »
Here's an idea if you like "big".
http://www.dimecitycycles.com/cafe-racer-parts/vintage-honda-caferacer-cafe-racer-bobber-brat-chopper-custom-motorcycle-parts/vintage-honda-caferacer-cafe-racer-motorcycle-parts/honda-caferacer-motorocycle-kick-stand-start.html
Chuckstart for $119!?!  At least your foot won't slip off!
Maybe it is the "upchuck start"  at that price for a bicycle pedal I vomited in my throat.  Too cheesy custom Harley for me. The Fonz  ::) That being said, be careful of drilling a tapping something new onto the stock arm.  The stock unit it one piece, and very strong for a reason.  I can imagine the bolt shearing and the protruding stud ripping a nice gash in my right calf.
Offline tmac
« Reply #14 on: November 27, 2010, 10:47:20 AM »
Just buy the right rubber ??
Offline Alan F.
« Reply #15 on: November 27, 2010, 01:52:36 PM »
28311-329-000 for the 750 rubber
« Reply #16 on: November 27, 2010, 05:21:26 PM »
Yeah, I know I could get the rubber, but I was curios to see if anyone had some interesting suggestions.
I kinda like the safety wire idea.
Offline Kframe
  • Life is good!
« Reply #17 on: November 27, 2010, 06:22:22 PM »
Yeah, what's the whole bomb bike look like?
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
