Author Topic: throttle twisty grip  (Read 2726 times)
Offline xsmooth69x
« on: June 05, 2011, 12:07:04 AM »
when i took off my grips .... well even before that, i noticed that plastic twisty part under my grip was brittle and was broken off.
is there a technical name for this piece that i can search the internet to find another one?
also since it is broken is their a better upgrade?
1975 CB550 (FINISHED?!?!?)
Offline 77honda
Re: throttle twisty grip
« Reply #1 on: June 05, 2011, 01:26:19 AM »
Throttle Grip Pipe,
CB750 K7
« Reply #2 on: June 05, 2011, 01:38:27 AM »
throttle pipe.
Offline xsmooth69x
« Reply #3 on: June 05, 2011, 02:27:58 AM »
can i buy any throttle pipe or do i have to get the cb550 plastic one?
« Reply #4 on: June 05, 2011, 03:08:27 AM »
youll need the 500/550 one with the double cable set up,i think its a common honda thing amoung other models.look here.
http://www.davidsilverspares.co.uk/CB500K2-FOUR-1973-USA/part_62166/
Offline Hush
« Reply #5 on: June 05, 2011, 04:15:16 AM »
Yep I was going to suggest David Silver too.
Offline johnrdupree
« Reply #6 on: June 05, 2011, 08:02:05 AM »
No reason to ship something from the UK, your local dealer will be able to get it.  OEM part #53141-300-010.
Motion Pro has what they claim is an equivalent part for $10:
http://www.motionpro.com/motorcycle/partno/01-0052
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
« Reply #7 on: June 05, 2011, 09:27:52 AM »
ive got one in good condition
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline xsmooth69x
« Reply #8 on: June 05, 2011, 10:43:00 AM »
could i use this?
http://www.motionpro.com/motorcycle/partno/01-0054/
i think this lets you control the twist so u dont have to twist as much?
anyone use something like this?
« Reply #9 on: June 05, 2011, 12:31:51 PM »
a quick action throttle can be too quick for these engines,you have two cables,one makes sure it closes,if you run only one hope the return spring dosent snap or become unhooked.
Offline xsmooth69x
« Reply #10 on: June 05, 2011, 05:37:58 PM »
ok stock push pull throttle it is  ;D
Offline Frankenkit
  • Industrial Strength
« Reply #11 on: June 05, 2011, 08:02:01 PM »
Don't know if the 550 is the same as a 650 in this respect, but you can get a stock fireblade throttle pipe that is just a little bit quicker and goes right on.  The problem is that you end up fighting the burly return spring more, it seems.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
