Author Topic: im totally crushed :( by cb550 build is now kinda dead in the water  (Read 13598 times)
Offline xsmooth69x
so im in the stage of painting everything for reassembly and i was grinding down the engine to get all the paint off and after that i decided to take off my sat cover and then my kick start cover to polish.
after taking the kick cover off i noticed some broken metal pieces.
then looking closer i noticed that literally the molded section of the engine that holds the kick starter spring broke off........
ill take a picture tomorrow but im screwed...... ill have to replace the hole bottom end of the motor to fix it.
im so pissed! now there is no way i can ride before the snow falls.... guess im rebuilding the engine  :-\
« Last Edit: September 03, 2011, 11:18:16 AM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
KingCustomCycles.com
Re: im totally crushed :( by cb550 build is now dead in the water
« Reply #1 on: September 03, 2011, 01:24:41 AM »
Or use the electric starter, i'm just sayin'  :-)
Offline xsmooth69x
« Reply #2 on: September 03, 2011, 01:39:49 AM »
http://forums.sohc4.net/index.php?topic=91542.msg1022327#msg1022327
this was a thread a started a while back that there is something wrong inside the bottom end of my motor that i cant use my starter......
so said F fixing it because i have to tear down the bottom end of my motor and decided to be all raw and kick start it only......
and now my kick start is broken............  FML
Offline xsmooth69x
« Reply #3 on: September 03, 2011, 01:48:38 AM »
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: September 03, 2011, 01:53:19 AM »
JB Weld.
« Reply #5 on: September 03, 2011, 01:56:58 AM »
A skilled tig welder could get that back together for well under $100.  No disassembly required.
Offline xsmooth69x
« Reply #6 on: September 03, 2011, 01:58:19 AM »
JB Weld.
seriously? that will hold the tension of the kick start and me kicking it?
i know you cant weld on white metal but the epoxy will seriously hold it?
Offline camelman
  • Man... Myth... Legend
« Reply #7 on: September 03, 2011, 02:29:59 AM »
That part really doesn't take much load.  It only holds the spring that returns the kick start lever from slipping to the side.  JB weld, or even a half-@$$ welding job would easily hold that.  I'm curious why it broke though.
Just to be sure, the location (dowel) you have the spring right now is incorrect.  It is supposed to hook behind that piece that is broken off.
Congrats, that's a stroke of luck that is wasn't worse!
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline 65Ch3v3LL3
« Reply #8 on: September 03, 2011, 02:31:59 AM »
You can also use this. It's a low temperature aluminum brazing solution that from what I understand is a durable repair. The great part is you only need a torch and not a TIG or the skills to use a TIG.
LINK
1979 CB650
2011 Harley Road King
2008 Harley V-Rod VRSC DX
2012 Sierra Denali 2500HD
1965 Chevelle Malibu SS
1922 Ford T-Model
Offline coma13
  • Lex Talionis
« Reply #9 on: September 03, 2011, 10:09:15 AM »
this
They wail and weep,
The march of the sheep,
As they go to that cross on the wall.
Offline xsmooth69x
« Reply #10 on: September 03, 2011, 11:01:39 AM »
...I was grinding down the engine to get all the paint off...
What?!?  :o
the engine was splotchy so i decided to grind off all the paint..... well maybe not grind but use one of those brush knot attachments.
then paint with vht universal aluminum. from what i understand its close to the stock color.
Offline xsmooth69x
« Reply #11 on: September 03, 2011, 11:02:54 AM »
Camelman
ya when i pulled the kick start case off thats when i heard the spring fling around and i guess thats where it landed and held itself  :P
Offline xsmooth69x
« Reply #12 on: September 03, 2011, 11:04:38 AM »
im going to try and jb weld the section first  ;D i hope it holds. if that doesn't work then ill go to a welder.
i thought i couldn't weld on this "white" metal stuff
Offline WarwickE36
« Reply #13 on: September 03, 2011, 11:11:21 AM »
worse case scenario drill a hole through it and the case. tap some threads into the case and put a small bolt in it.  If all the already mentioned methods fail you, it could probably be done.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: September 03, 2011, 11:38:18 AM »
Get the area super-clean (brake cleaner) and dry thoroughly before applying the JB Weld.  Come up with a way of clamping the piece into place with some force, i.e. don't just tape it into place.  The rough broken surfaces are already ideal for taking JB weld, and the piece should jig-saw right back into place exactly.
Use the slow-drying stuff, it's final strength is greater than the quick-dry stuff.  Don't use JB Stick, use the thin stuff in the little tubes.
The cases are aluminum so if you can weld that, just be aware that the alloy isn't pure AL.  That aside they can be and have been welded.
mystic_1
- John Augustus Shedd
Offline xsmooth69x
« Reply #15 on: September 03, 2011, 12:10:06 PM »
mystic_1
ya i have the industrial size 2 part slow cure jb weld (that good shiat)
Re: im totally crushed :( by cb550 build is now kinda dead in the water
« Reply #16 on: September 03, 2011, 01:38:57 PM »
hacksaw or file a slot for the spring to locate into.
Offline mystic_1
  • 1970 CB750K
« Reply #17 on: September 03, 2011, 06:23:05 PM »
Looks to me as if spring pressure, and also probably the engine cover, will serve to hold that piece in place, and all forces on it should be compression forces.
I think JB will hold it fine so long as its carefully applied.
Tip, once it's more or less dry but not fully cured, that's the time to remove any squeezed-out excess with an exacto knife or razor blade.
mystic_1
« Reply #18 on: September 03, 2011, 07:24:50 PM »
Can you not locate the spring on the part of the case is left?
Offline Rgconner
« Reply #19 on: September 03, 2011, 09:41:26 PM »
I would pin it for extra strength
Drill a small hole one both sides and place a bit of piano wire in there. 1/8 or 3/32nds should do it.
Get jb on it before you stick it in and it should help to hold place as it dries.
1975 CB550K aka "Grease Monkey"
« Reply #20 on: September 03, 2011, 11:26:27 PM »
i just had a gander at a case i have,it forms the return stop for the kick spindle aswell,youll want plenty good jb weld.
the easy way out is dont fit the kicker and use electric only,,the kicker mustave had a knock in the return direction to snap that off?or some one let it fly back without releasing it with the foot a few times?
« Last Edit: September 03, 2011, 11:30:18 PM by dave500 »
bollingball
« Reply #21 on: September 03, 2011, 11:52:49 PM »
I volt for JB weld part just the way it is no pin to have to line up on both sides. Give it a extra day to cure it will work just fine.like mystic said clean the extra off before it dries.
« Reply #22 on: September 04, 2011, 12:05:54 AM »
did you break it yourself xsmooth?the kicker would be able to go forward as much as to touch the clutch housing,you never saw that?if the jb lets go you run the risk of a jam up if that bit gets free,leave it or have it welded properly.
« Last Edit: September 04, 2011, 12:48:01 AM by dave500 »
Offline Hush
« Reply #23 on: September 04, 2011, 12:10:13 AM »
I'm with Dave500 on this, I'd file a small slot so the spring dosesn't slip across.
I don't think that JB will hold such a heavy spring (hey I could be wrong) and I always prefer the simple approach to repairs. :)
« Reply #24 on: September 04, 2011, 12:24:45 AM »
im with hush,,internal glue?the return stopper isnt functional now,weld it.
