Author Topic: Custom oil tank for CB 750  (Read 24909 times)
Offline anotherCB
« on: October 06, 2011, 11:39:53 AM »
I have been pondering the idea of getting a custom oil tank for my CB 750 and opening up that triangle. I plan on getting a custom made flat tank that hides between the frame where the inner fender sits. I found someone on ebay who makes me one for a reasonable price. Now I was wondering, do I need those big size original oil lines or can I go with a smaller diameter? Anything else I should be watching out for?
Also, what is a good small battery that I can lay down in my seat hump and what is the min cranking amerage I need?
Thanks a lot! Olaf
1978 CB750K, 2016 R1200 GS/LC, 1973 R75/5
Offline anotherCB
Re: Custom oil tank for CB 750
« Reply #1 on: October 06, 2011, 06:31:10 PM »
No I think it's another guy. What about the size of the tank? Should I make it as big as the original or can it be smaller? Any experience with that?
« Reply #2 on: October 07, 2011, 10:22:04 AM »
 MOST lines are smaller OD for correct size than the stock Honda ones.
 If you are thinking of reducing capacity, think about how hot the temps will be that you ride in and if you will be getting stuck in traffic a lot.
 If I am riding across a desert in high temps I like to throw in an extra quart, which you can do with the stock bucket.. idling in traffic can get a bike VERY hot...
Offline yellowbirdrs
« Reply #3 on: October 07, 2011, 01:22:15 PM »
I did mine to match the OEM capacity just hide it under the custom gas tank also keep the OEM OD hoses
a pressure old test video and you can see where it's located and the shape
<iframe width="420" height="315" src=" frameborder="0" allowfullscreen></iframe>
X/A
Summer 2011
Offline splitt
« Reply #4 on: October 07, 2011, 08:05:10 PM »
There have been many dry sump bikes that have been built using smaller oil tanks than stock one. An oil cooler will definitely help with the heat issues. You will need to change the oil sooner also.
Online scottly
« Reply #5 on: October 07, 2011, 09:29:10 PM »
I personally would not use any line with a smaller ID than stock, especially on the supply line to the oil pump. 5/16" ID line is asking for disaster, IMHO.
« Reply #6 on: October 07, 2011, 10:28:16 PM »
+1, so is running less oil, it will heat up faster stay hotter and need changing more regularly, loose a little and you will be in big trouble...
Offline anotherCB
« Reply #7 on: October 08, 2011, 02:42:35 PM »
First of all thanks guys. I definitely do not want to run an oil cooler since I want to stay as minimalistic as possible. I ride a lot in the heat, CenTex was in the 100s most of this year, so from all I hear I think I might be staying on the safe side and won't go as small as possible, neither with the tank size nor with the line diameters.
One other question I had, what is a good, cheap battery to hide in the seat hump and what is the cranking amperage I need for a stock K7? Also, isn't there an after market rectifier out there that is much smaller?
Thanks again, Olaf
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #8 on: October 08, 2011, 02:45:58 PM »
Check our my build thread, my oil tank will double as a bit of an oil cooler.  100% hand made from Al, so thermal exchange should  be decent too.  I haven't mounted it yet, but with TT's "anti-pod" intake, I should have a very nice open triangle!! :)
Offline wannabridin
  • -Garrett
« Reply #9 on: October 08, 2011, 02:46:39 PM »
Oh ya, im in NE TX, just south of DFW airport, where are you??
« Reply #10 on: October 08, 2011, 08:14:19 PM »
 How many K on the choppers.. Under marginal conditions, going 5 or 8 K is bugger all.. I meam many of us have put 30 K or more on CB 750 motors or bottom ends.. some over 100 K
Offline anotherCB
« Reply #11 on: October 10, 2011, 06:49:41 AM »
Wannabridin, that's an amazing oil tank! Would you mind me askin who made it and what you paid for it? I am starting the process of getting a tank done that is going to sit where the fender is, but now after seeing yours......oh and I am located in Austin.
Thanks guys.
Offline wannabridin
  • -Garrett
« Reply #12 on: October 10, 2011, 03:19:03 PM »
Thanks guys.
little_horse from here made it.  his name is Andrew and it's in Beaverton, OR.  HELLUVA guy, had the chance to meet him a couple nights ago up there and go to dinner.  he is quite an awesome fabricator!  i won't divulge the price i paid for it, as him and i worked on some deals since i gave him a good amount of work (fully custom cowl, oil tank, gas tank work, a custom exhaust tip and bushings for my truck) over the past few months.
i ordered the bungs and filler from BungKing.com and shipped them to him.  he fabbed up the tank to my dimensions, which i had another member on here, Brenden throw together in solidworks for me.  here's what he did.  i certainly love these forums, the people on here rock!!
i think the cooling fins will work well, and the tank should hold about the same amount of oil as the stock tank, maybe just a tad less.  shoot Andrew a PM, he would love the business!  here's his build thread: http://forums.sohc4.net/index.php?topic=64250.0
Offline anotherCB
« Reply #13 on: October 10, 2011, 04:10:43 PM »
Thanks man! So you wouldn't mind if I "steal" this from you and copy it? Would you by chance have a pic with the tank on the bike? I agree, this forum rocks!
Offline wannabridin
  • -Garrett
« Reply #14 on: October 11, 2011, 05:01:28 PM »
i don't mind you borrow it, just as long as you give credit where it's due.  me for the design but mainly andrew for the work and brenden for the cad skills.
but the main thing, don't just copy mine.  make it your own, come up with some of your own ideas.  andrew loves a challenge, so give him something that's cooler and better than mine!  no sense just copying something that's already out there.  take it to the next level on your own.  ii even considered vertical fins on the rear, so start thinking of stuff to customize your own bike.
Offline DORIGTT
« Reply #15 on: October 11, 2011, 06:02:51 PM »
Hey Wannaberidin,
Can I get the guy in Beaverton's contact info?  I live 25 minutes from there and would love to get in contact with him to get a tank made for myself.
Offline wannabridin
  • -Garrett
« Reply #16 on: October 11, 2011, 09:31:30 PM »
sure.  i'll PM you his address.  tell him Garrett sent you!
anothercb, check out my build thread.  i put some close up and semi-mounted pictures of the tank in the frame.  lemme know if you have anymore questions.
Offline anotherCB
« Reply #17 on: October 12, 2011, 05:45:55 AM »
Thanks Wannabridin!
Offline greddm
    • CB750 Cafe Build
« Reply #18 on: November 21, 2011, 01:05:43 PM »
Does anyone have a picture of the tank installed?  I would love to see what it looks like.
Offline Really?
« Reply #19 on: November 21, 2011, 01:20:18 PM »
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline anotherCB
« Reply #20 on: April 16, 2012, 07:15:33 PM »
Just wanted to warm up this old thread and post a pic of my final product. Thanks for all your input! You got me motivated! Will post more pics soon and I am also writing up a build thread.
« Reply #21 on: April 16, 2012, 10:37:42 PM »
Any feedback on the yoshi rep pipe mate..?  Thats one of Chris's isn't it.?
Offline Blitzburgh207
« Reply #22 on: April 17, 2012, 05:05:02 AM »
Wow that looks great! Excellent work!
1978 CB750 K8
Offline anotherCB
« Reply #23 on: April 17, 2012, 06:00:50 AM »
Wow, good eye RetroRocket. Yes it is a stainless steel from motogpworks and I was told someline named "Chris" makes them. Excellent product!
Thanks Blitzburgh, I will post a detailed thread soon, there are some more photos here if you are interested
http://forums.sohc4.net/index.php?topic=105433.msg1179000#msg1179000
« Reply #24 on: April 17, 2012, 03:15:16 PM »
I have the same pipe.... ;D  Just curious as to how loud it is and ease of fitting.....
