Author Topic: Its time to build a 836 Turbo  (Read 114433 times)
Re: Its time to build a 836 Turbo
« Reply #600 on: October 09, 2015, 06:08:16 PM »
Thanks David and we will have dyno time soon................see you tomorrow at commerce
ET Finals
go team
Good luck guys.
Offline Jim F
  • go baby go
« Reply #601 on: October 10, 2015, 03:53:11 PM »
Today was canceled because everyone forgot
There rain tires
Sunday should be a better day
Rained all day
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline hotdog
« Reply #602 on: October 25, 2015, 04:03:00 AM »
Any updates on this Jim..?
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline Jim F
  • go baby go
« Reply #603 on: October 25, 2015, 06:50:08 AM »
Sorry guys but usually I am not going to post if we are still trying
To get the air fuel correct
Top end is still lean (no boost) with an AF of almost 16.1
Going to go to 240 mains (we have 230 mains now) and I have the drill set on stand by
Will let you know next Saturday (hopefully) and we'll see were
We are at
This Motor loves fuel and I am going to give it as much as needed
Jim
Offline Jim F
  • go baby go
« Reply #604 on: July 02, 2016, 03:56:36 PM »
Well it's back
Yes I was on the dyno today and this is what we found
1 could not use more than 1lb of fuel pressure befor it would start to leak
Out the over flow
A, pulled carb to check needle and seat and o ring around seat had turned to
Dust
With that fixed back on the dyno and AF was still lean
Increased fuel pressure and it came down. Increased to 4.5 lbs and AF is at 12.1
Jetting change to run less pressure ?????
Running 240 main
The charging system decided to crap out and had to go to a back up
Batterie
We got air/fuel good at 12.1 all the way to red line
But there is a lean spike just as it comes on to the needle
Past that it's flat line 12.1
I have an oil tank that needs better venting
Had some oil spitting out the breather lines
Pulled the filler cap off and all is good but needs to be addressed
We decided to put boost to it but the waste Gate is not working
Needs to be looked at to see why there is no boost
All in all a good day as we FINALY got the AF figured out
More to come
Jim
« Reply #605 on: July 02, 2016, 04:26:33 PM »
Sounding positive Jim. I remember the parts on your bench.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #606 on: July 02, 2016, 06:09:28 PM »
Way to go Jim, now I understand,  lol, I called  a couple days ago to book , have to wait til the 13/14th.  Can't wait to see you put some boost to it!  K, Bill
BentON Racing Website
BentON Racing Facebook
Offline Ilja
« Reply #607 on: July 07, 2016, 02:09:39 PM »
Well it's back
Out the over flow
Dust
Running 240 main
Batterie
More to come
Jim
Nice that you got it tuned correctly!
I also had some oil breather spitting problems when running over 0.5bar / 7psi boost...
Had it one of the first rides I did with the bike, with the boost set too high.. and a month ago when I blew the ringlands of two pistons because of pinging.
I think the first time it happened it might have already temporarily snatched some rings, causing blowby.
After the last oil spit you could see the bike blow white smoke out of the breather tubes... so be carefull if it's spitting oil! Could be some broken ringlands that are still floating around between the rings! (mine were)
Now building it back togheter with correct CR and squish and an additional breather vent next to to original one on the cam cover.  ;)
« Last Edit: July 07, 2016, 02:13:10 PM by Ilja »
Offline Jim F
  • go baby go
« Reply #608 on: July 07, 2016, 07:49:25 PM »
We tried putting boost to it but the waste gate is not working
Going to put on a new version of the old that terry Kizer sells at Mr. Turbo
Don't think I'll have problems with pinging the rings as the ignition system will start to retard
The ignition, 1.5 degrees after 2 lbs of boost all
The way to 15 lbs, as long as the AF stays consistent we will be good
But that can be programmed to take out more timing
Or put timing back in
Right now it's set at a very safe set up
Keep us posted on yours also
Jim
« Reply #609 on: July 07, 2016, 08:04:13 PM »
Jim
Christ.....I'll stick with N/A ;D
« Last Edit: July 08, 2016, 05:47:04 AM by MRieck »
« Reply #610 on: July 07, 2016, 08:05:22 PM »
Jim, is that 1.5 degrees for every 2 pounds of boost, so 11-12 degrees at 15 lbs?
« Reply #611 on: July 07, 2016, 08:07:18 PM »
Coward.... ;D ;D ;D
Offline Ilja
« Reply #612 on: July 09, 2016, 02:02:49 AM »
Jim
Be carefull with trusting on the A/F ratio. My A/F ratio was right at 11:1 all the way... even had it richer then that and it still pinged over 0.5 bar.
The rich a/f ratio is primarily to prevent overheating and pre-ignition when running full throttle with things heating up a lot.... you know, those pictores with melted holes from glowing spark plugs. Thats why you need to run rich.
Pinging is a different story, it's just small explosions (small ticks) around the edge of the pistons furthest away from the spark plug, caused by too high pressures for your fuel.. and hard to hear, especially with a loud exhaust.
My compression in the end was 9.4:1 so it pinged it's nuts of over 10psi... ringlands broke but the pistons are clean as hell, not a single overheating sign.
Tricky stuff.... mine even had good compression with broken ringlands, because the rings were still loose!
It started to show as misfire above 7000rpm... Only when I pinched a ring tight between the ringlands I got the white smoke and oil coming out of the breather.  ::)
Your ignition is a good idea, and the right way to get some additional insurance for your pistons..  :)
I tried retarding ignition but 5 degrees didn't make a noticable difference, but 10 did... When running 25 degrees instead of 35 I could run a bit more boost but not much.... 2-3psi before hearing the midgets with little center punches again.  ;D ;D
AWESOME bike by the way! 8)
« Last Edit: July 09, 2016, 03:52:30 AM by Ilja »
Offline Jim F
  • go baby go
« Reply #613 on: July 09, 2016, 06:44:25 PM »
hey jerry
It won't start to retard the ignition untill after 2lbs of boost
With the timing set at 34 degrees (I think)
Then after 2lbs of boost then it's 1.5 degrees after every lb of boost up
To 15 lbs. it should fall on its face rich and that's what we want
It's just as easy to put timing back in after that
« Last Edit: July 10, 2016, 04:47:11 PM by Jim F »
