Author Topic: Necessary to Remove Swingarm Bushings Before Powdercoating?  (Read 3946 times)
Offline Harsh
  • 74 CB750 and two 72 CB350's
« on: March 01, 2012, 09:00:56 AM »
I am nearing the stage of my build where I will be getting things powder coated, the swingarm being one of the items.  Is it necessary to remove the bushings prior? I have a K4 750 which does not have the zerk fitting(s).
Re: Necessary to Remove Swingarm Bushings Before Powdercoating?
« Reply #1 on: March 01, 2012, 09:32:51 AM »
The heat they'll use to bake the powder will not do those bushings any good! To remove them will ruin them too, but there is no choice.
Remove everything and mask off the end of the s-arm tube to keep the paint powder out.
Offline Harsh
« Reply #2 on: March 01, 2012, 10:01:04 AM »
Are the bushuings not steel?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: March 01, 2012, 10:05:14 AM »
The better question is, why wouldn't you take it apart? If you're going to the lengths to rebuild and restore,I would think new bushings would be a must.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Harsh
« Reply #4 on: March 01, 2012, 10:24:48 AM »
Because nothings appears to be wrong with them.  The swingarm moved freely up and down with no slop before I removed it.  I was using the if it aint broke don't fix it mentality.
Offline messeduptriple
« Reply #5 on: March 01, 2012, 10:55:49 AM »
I had mine just powdered... I left everything inside and they gave me back without bushings and stuff.. I just took my swingarm to my local Honda shop and they ordered everything I needed for around 35$ they will install it as well. I think its a good deal
I'll be picking it up in few days..for me its worth it.
Sent from my PC36100 using Tapatalk
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: March 01, 2012, 11:01:09 AM »
It's a wearable 35+ year old part, why not replace it while everything is apart? Don't be one of those POs that made the bike look really pretty just to fall apart on the next owner.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Prospect
« Reply #7 on: March 01, 2012, 12:41:09 PM »
If you don't want to remove them then at least protect them from powdercoat.  I used a long bolt with a large washer on both sides to cover the holes.  It's next to impossible to remove the powdercoat from deep inside the swingarm.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
nomad
« Reply #8 on: March 01, 2012, 01:45:49 PM »
This is what I did with mine and it turned out fine.  The only difference was I used a long threaded rod instead of a carriage bolt.
Offline CycleRanger
  • No comment about being an
« Reply #9 on: March 01, 2012, 02:55:27 PM »
Any good powder coater will want them removed to avoid oil contamination in their bake oven.
« Last Edit: March 01, 2012, 03:49:55 PM by CycleRanger »
Offline Eydugstr
« Reply #10 on: March 01, 2012, 03:14:20 PM »
Remove them, then get as much grease as you can out of the swingarm tube, then cap it off as decribed above.
Online HondaMan
« Reply #11 on: March 01, 2012, 06:07:51 PM »
When folks have me rebuild them with Oilite bushings, I have them cap off the ends as described above (with 12" long allthread rod, 2 fender washers, nuts) and paint them. They come out fine.
nomad
« Reply #12 on: March 01, 2012, 06:25:57 PM »
I'm proud to say I'm one of HM's "folks."  ;D  Like I said... it worked just fine for me doing it as HM described.
