Author Topic: My chain lost its master link  (Read 1743 times)
Offline 68grandprix
« on: May 31, 2006, 01:01:51 AM »
I was just cruising along at 30mph and heard noises and my engine died. I'm lucky it didn't happen at high speed, and I was only about 50yrds from my house, but this really sucks. Jimmy
Offline Lumbee
    • My pics...
Re: My chain lost its master link
« Reply #1 on: May 31, 2006, 07:45:26 AM »
...slap some JB weld on it and ride by brotha....
"I'm not a welder, but I play one on HondaChopper.com"
Offline 74cb750
« Reply #2 on: June 03, 2006, 12:58:33 PM »
Let us know how it turns out.
michel
Laugh at least once a day.
Life  $ucks, then you die.
Offline 68grandprix
« Reply #3 on: June 03, 2006, 06:41:42 PM »
I bent the edges of the hole back out so they wouldn't contact the trans(?) gears and JB welded the piece and all the cracks. I used rtv between the cases. Today I rode it a little and I didn't see any oil leaking, so I guess it's good for now. I also installed a 17 tooth countershaft sprocket from a 550(stock on mine is 18) so the bike should be a little quicker. Jimmy
« Reply #4 on: June 03, 2006, 08:54:05 PM »
Jimmy, by installing the 17 tooth sprocket you have geared the bike down, it will be a little slower but it will accelerate faster.
On the early models, Honda fitted smaller sprockets front and rear and had your problem from the outset.
They changed to larger sprockets to slow the chain speed down, this made the chains last longer, but if you don't look after it or use old master links or cheap chain the problem will not go away.
Sam.
Offline jotor
« Reply #5 on: June 04, 2006, 05:52:53 AM »
While you were down there did you safety wire the master link?
I'd rather ride a Yamaha than eat worms.
Gallery.....http://www.sohc4.us/forums/index.php?topic=2254.0
ElCheapo
« Reply #6 on: June 05, 2006, 06:45:07 AM »
One of the motors I am running has one of those lovely air conditioning vents  ;D No problems so far. Leaks a little but no major problems  ;)
