Author Topic: brandEn's K4  (Read 333900 times)
Offline Leafshutter
Re: La Flama Blanca aka The K4 - painting the tank... AGAIN.
« Reply #275 on: April 26, 2013, 01:17:30 PM »
That engine is going to be pure bike porn!  ;)
Great work brandEn!
Offline brandEn
« Reply #276 on: April 27, 2013, 02:30:15 PM »
I started mocking up the fender and caliper arm brackets for my dual disc conversion. For those that have done this mod,  is this how your fender fits? One side of the fender between the fork and caliper bracket?
« Last Edit: April 27, 2013, 03:10:11 PM by brandEn »
Offline brandEn
« Reply #277 on: April 27, 2013, 02:34:10 PM »
It took me nearly five hours to clean the powdercoat from the threads to install my tappet covers!
Offline brandEn
« Reply #278 on: April 27, 2013, 02:36:57 PM »
Pistons and rings installed.
« Reply #279 on: April 27, 2013, 03:42:35 PM »
The brite silver of the cases looks great. Those threads for the tappet covers would be tough to mask. How did you remove the  powdercoating from that area?
Offline brandEn
« Reply #280 on: April 27, 2013, 04:12:13 PM »
I used a big 16mm tap, a scribe, wire brush, and a box knife. Luckily I have a bunch of old tappet covers because I had to sacrifice a few. I messed up a few threads.
Offline WhyNot2
  • I'm finally an
« Reply #281 on: April 27, 2013, 04:45:18 PM »
Man, that engine looks great.....................!!!!!!!
Offline tweakin
  • tear down
« Reply #282 on: April 28, 2013, 05:28:04 AM »
Coming along nicely B. Should have used those extra tappet covers to protect the threads during powdercoat. :o  I have a set I use exclusively for coating valve covers.
When we riding?
« Last Edit: April 28, 2013, 08:17:24 PM by tweakin »
Offline brandEn
« Reply #283 on: April 28, 2013, 01:24:04 PM »
Last time I did that and I ruined my cam cover because blasting media worked its way into the threads and and I couldn't remove the caps. The tappet covers actually broke!
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #284 on: April 28, 2013, 04:42:46 PM »
When we ridding?
That's a good idea.
The riding part too.  ;D
« Reply #285 on: April 28, 2013, 06:07:21 PM »
Yes....I have had that happen to me too. Sucks!
Offline tweakin
  • tear down
« Reply #286 on: April 28, 2013, 07:05:36 PM »
Yes, I just loosely screw them in to protect the threads, have not had a problem yet.  Guess I am lucky...
« Reply #287 on: April 28, 2013, 07:18:40 PM »
The point is bits of bead get into the coarse threads. The caps thread in OK but when you try to back them out they jam up bad. It blows the threads out Tige. You have to take a toothbrush etc with brake cleaner to get the crap out. I have problems screwing the caps in, blasting , cleaning but enough $hit was there to F up the cover threads. Be careful and clean the hell out of those threads. I have 2 perfect covers that are f'd up that I use for painting now......lesson(s) learned.
Offline tweakin
  • tear down
« Reply #288 on: April 28, 2013, 08:20:06 PM »
I see where I am off...  I usually blast with aluminum oxide, it is toxic, but cleans out of all the threads easily with air, then acetone and a toothbrush.   I screw the tappet covers in loosely for powdercoating.
Offline brandEn
« Reply #289 on: April 30, 2013, 07:47:09 PM »
Received my MLS top end gasket kit from Cycle X today and wasted no time getting the top end set in place. Thanks to all my efforts with TAO it only took me about 15 minutes to get everything set in place. I am waiting for some HD nuts from Voxonda and I will torque er down.
Offline jerry h
« Reply #290 on: April 30, 2013, 08:26:11 PM »
Hard to stop lookin at it........beautiful engine! ;)  Can't wait to see what you have in mind for the rest of the bike.
Offline brandEn
« Reply #291 on: April 30, 2013, 08:50:30 PM »
Thanks Jerry. I hope she runs as good as it looks!
Offline SF
  • I burn gas very well
« Reply #292 on: May 01, 2013, 07:08:49 AM »
she's a beaut! hope she turns out to be a beast too
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #293 on: May 01, 2013, 07:35:53 AM »
What about using plumber's tape on the caps?  They would seal well and are easy to remove.
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
Offline brandEn
« Reply #294 on: May 10, 2013, 02:21:37 PM »
So I started a new thread because I have hit a snag with my dual discs...
http://forums.sohc4.net/index.php?topic=121438.new#new
« Reply #295 on: May 10, 2013, 04:18:36 PM »
good idea....I'll try it next time. ;)
Offline brandEn
« Reply #296 on: May 10, 2013, 09:35:32 PM »
Well it looks like I need a new front hub. Apparently I have the ultra rare K0 hub. It was made 4mm wider so the flange the speedo drive sits on is not as tall.
Oh well.
On a positive note at least I got something done today. Rear wheel laced and fitted to the swingarm.
This 3.5" wide rim looks great.
Offline Flying J
« Reply #297 on: May 10, 2013, 09:53:35 PM »
I may have a hub if you need one. If you need one PM and ill get you pics.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #298 on: May 11, 2013, 01:21:17 AM »
Looks PERFECT!
Offline Doctor_D
« Reply #299 on: May 11, 2013, 07:37:43 AM »
Where'd you get another box section swingarm?
Take care,
David
1978 CX500
1971 Norton Commando
