Author Topic: Mongrel  (Read 44987 times)
Offline Damage Inc
Re: Mongrel
« Reply #75 on: May 01, 2014, 01:57:49 AM »
A little bit of progress today.
Tacked in tail light mounts.
There is nothing Man makes, that Man can't break.
Offline Damage Inc
Re: Mongrel
« Reply #76 on: July 10, 2014, 01:59:34 AM »
Made a length alteration on the seat
Mocking up the exhaust to set up rearsets.
Offline Damage Inc
Re: Mongrel
« Reply #77 on: August 07, 2014, 12:36:34 AM »
Made a pair of headlamp brackets
Just need to weld out
Offline Damage Inc
Re: Mongrel
« Reply #78 on: August 08, 2014, 01:43:03 AM »
Started on a bikini fairing today, looking at a few different angles. Let me know which angle you think looks best.
A full profile photo of the bike might be needed to give a better idea.
Re: Mongrel
« Reply #79 on: August 08, 2014, 03:30:34 AM »
The first pic lines up the lip of the fairing with the outside line of the headlight, looks better that way... ;)
Offline SF
  • I burn gas very well
Re: Mongrel
« Reply #80 on: August 08, 2014, 08:06:54 AM »
do you want to push the wind or be aerodynamic?! race or cruiser? lookn good
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Damage Inc
Re: Mongrel
« Reply #81 on: August 08, 2014, 03:28:12 PM »
Thx Retro, I agree with the lines around the lamp, even perhaps slightly forward so it sits just behind the trim. I've got enough length in it that it would have those lines regardless of the angle, I'll trim to suit. So I'm thinking the lamp lines of the top one, with the angle of the bottom one.
Thx SF, this bike won't be much of a cruiser. With the clip ons and rearsets, I'll more than likely be laying on the tank from time to time. Aerodynamic, I think. Once it's on the road, I'll have a go at making some different pipe set ups, that will let me fit a bottom cowling.
Re: Mongrel
« Reply #82 on: August 08, 2014, 04:06:53 PM »
Damage, i like the angle of the top pic as well, sit on the bike and see where the air it deflects will go, pic 3 looks like it will hit you square in the face.... You'll hate it if it does, it will buffet your helmet and drive you mad... ;)
Offline Damage Inc
Re: Mongrel
« Reply #83 on: August 08, 2014, 08:25:07 PM »
Too true.
That will be the next step
Offline Trad
Re: Mongrel
« Reply #84 on: August 08, 2014, 08:47:46 PM »
I too like the first angle for the fairing. Really dig the lines of the seat/tail section.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Damage Inc
Re: Mongrel
« Reply #85 on: August 14, 2014, 12:58:24 AM »
Thx Trad, as it turns out, I've had to increase the angle slightly and I've moved it forward as well. This is were it will stay.
Offline Damage Inc
Re: Mongrel
« Reply #86 on: September 17, 2014, 03:33:07 PM »
G'day all.
I'm after some advice please.
Originally I planned just a top end rebuild, so I purchased a gasket kit to do just that. Now I've decided to strip the bottom end as well.
My question is can I get a bottom end kit or do I need to get the rest seperatly? If so what do I need to get? Should I get a complete one and off load the top end one? I got this one off eBay, is there some where better to get them?
Any advise would be appreciated?
Re: Mongrel
« Reply #87 on: September 17, 2014, 03:58:43 PM »
What's prompting the bottom end rebuild?  There is no turn-key bottom end kit.  The most important thing about the bottom end is checking wear on the crank, rods, bearings, transmission, primary chain and primary chain tensioner.  If you are going to rebuild the bottom, buy a new primary chain, too.  If you are looking for mods, one is to have the crankshaft balanced.
Offline Damage Inc
Re: Mongrel
« Reply #88 on: September 17, 2014, 05:43:52 PM »
When I purchased the bike, the top end was removed and I don't know for how long the case was open to the elements. Anything that could've dropped in past the pistons could be still there. So it's manly exploratory, and I can check wear and tear while I'm there. So as far as gasket options, a complete kit or separate individuals, looks like my options. I'll look into that crank balance, might be able to squeeze more coin into it. Thx
Re: Mongrel
« Reply #89 on: September 19, 2014, 03:25:12 PM »
I picked my head with new valves and seals, valve seats and ports done as well.
pick up piston clips early next week, then I'll have all my bits to put it back together.
That leaves me with the carby rebuild. Need to save some bucks to get 4x rebuild kits, in the mean time I start stripping them down.
It looks like you had a nice clean bead blast of the head and replaced the valves and seals.  Springs and retainers, too?  Who did the port job?  Can you take pictures of the intake ports.  Mike Rieck is the resident porting god out of Massachusetts, but additional resources are always good to know especially if it is local for others.
Offline Damage Inc
Re: Mongrel
« Reply #90 on: September 19, 2014, 04:52:35 PM »
When I've said "ports done", I don't think it's a complete port job. My local ( Geelong, Victoria, Australia) motor reconditioner, who builds mainly race car engines. When I got him to check the head, he recommended new valves. The springs and retainers were fine, so they weren't replaced. When he did the valve seats, he machined into the ports about 15mm, if my memory serves me correctly. Tried to take some photos, but too dark. I went and spoke to one of the guys yesterday, about the crank. They don't have a lot of experience with bikes and this bloke felt that the crank would probably be close to "spot on", due to its Japanese construction. I say this not to question your suggestion of a crank balance (I think it's worth looking at), but to highlight the mind set of the machine shop guy. He said he will check it out for me.
Re: Mongrel
« Reply #91 on: September 20, 2014, 02:13:26 AM »
Cycle X typically finds the crank and rotor to be slightly out of balance.
Offline Damage Inc
Re: Mongrel
« Reply #92 on: September 29, 2014, 02:42:20 PM »
I'll take mine in and get it done, appreciate the feed back.
I found this "B" kit. Is it a bottom end kit????
Offline Damage Inc
Re: Mongrel
« Reply #93 on: September 29, 2014, 02:45:39 PM »
Link didn't work, sorry. I'll see if I can get a photo up.
Offline Damage Inc
Re: Mongrel
« Reply #94 on: September 29, 2014, 02:49:03 PM »
Look at this on eBay:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=251560079159
Honda CB500Four Gasket Kit NOS Genuine CB500 GASKET SET B 06111-323-315 CB500F
Offline Damage Inc
Re: Mongrel
« Reply #95 on: October 10, 2014, 10:40:51 PM »
Painted some engine parts this week
Offline Damage Inc
Re: Mongrel
« Reply #96 on: October 15, 2014, 03:03:22 AM »
Just a couple of question on some mods that I'm considering!!
Firstly, with the clip on bars. I'm going to have an issue with contact of the hand controls onto the tank. Two remedies I've considered are tank dents and a turn reduction by altering the stops.
Initially the tank mod was the way I was thinking, along with knee dents. But I have grown attached to the original shape of the tank and not to keen on the thought of the reduced fuel capacity.
So I've been considering altering the stops. I can see that it will affect parking, but as I have limited road bike experience, I'm wondering how much it will effect general travel or emergency manoeuvres.
Secondly, on a performance level. I've had a bit of trouble finding the rest of an airbox over here in Oz. So I have the chamber that the carbs attach to, but I don't have the filter box. I have seen a adapter plate made that attaches to the chamber of a single larger K&N filter or other brand. The question is has anyone had some experience with this type of set up and what did you discover?
Any feed back will be much appreciated.
Re: Mongrel
« Reply #97 on: October 15, 2014, 10:57:02 AM »
Nice looking custom work 'Damage Inc.'  8)
Offline Damage Inc
Re: Mongrel
« Reply #98 on: October 15, 2014, 06:46:48 PM »
Thx grcamna2, it's been a slow process. I feel like I'm getting the look I'm after. I'm looking forward to the day I ride it, and that's my motivation.
If you want clip-ons and to retain the stock tank, get some that have a rise to them and are adjustable in the "pull back". It should allow you to have the best of all worlds.
Thx calj737, unfortunately I already have some clip-ons and they aren't of the adjustable variety. I suppose I could consider resale and update to a adjustable set. That's an option.
Re: Mongrel
« Reply #99 on: October 15, 2014, 06:55:47 PM »
Gday Damage, are you fitting rear sets to the bike..?  These bikes are horrible with clip ons and stock pegs, ergonomics are all wrong, stock pegs are too far forward and its as uncomfortable as hell, been there done that, if you are running rearsets then you its a bit better but in all seriousness, these bikes aren't really designed to work with clip ons, thats why the CR race bikes have a very long tank, look at the post classic racers, they all use superbike style bars, which clear the tank..... ;)
