Author Topic: taking out the oil pump?  (Read 5724 times)
pat english
« on: June 01, 2012, 08:21:30 PM »
So im getting ready to take the engine out of the 750.Got the bike mostly stripped down.I took the exhaust studs out and took the oil pan and pump out.Iv got these engines out before without taking the oil pan off,but its ruff.Im hoping the extra inch or so will give me what i need to get it out easy....But im worried about the oil pump.am i going to run into any problems?does the pump need to synchronize or does it just bolt right back on?thanks,
        pat
Offline killersoundz
Re: taking out the oil pump?
« Reply #1 on: June 01, 2012, 08:31:49 PM »
It might need primed when you put it back on. Also may need to replace some seals? I have a new gasket set maybe someone else can advise if I need to replace any o rings on the pump or anything?
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
pat english
« Reply #2 on: June 01, 2012, 08:44:33 PM »
ok.thanks for the tip.now im wondering about those lil o rigs too.mine look in good shape though..this is probly a sill question,but  do the pump and pan use a gasket?cuz i dont remember seeing any when i took them off.just the lil o rings.
« Reply #3 on: June 01, 2012, 10:17:45 PM »
The pan should have and needs needs a gasket.Lots of time it sticks to the pan.
pat english
« Reply #4 on: June 01, 2012, 11:19:59 PM »
Ah ok.Well i got the engine out.It was ALOT easier to get the engine out with the pan and pump off.Got it out in less then 15 min.The pan didnt have a gasket though.Just some silicone crap.
« Reply #5 on: June 02, 2012, 04:03:18 AM »
Did you see any bits of silicone laying in the bottom of the pan when you took it off. That stuff can be bad news when or if it starts floating through an engine. The little jets that control oil to the head can become clogged very easily resulting in some severe and expensive damage.Do not use any when putting it back together.  ;)
pat english
« Reply #6 on: June 02, 2012, 02:25:12 PM »
Nope. Just found sludge.Okey doke.A gasket kit should come with a new gasket for the pan right?
« Reply #7 on: June 02, 2012, 02:31:54 PM »
Yup. I got a 'versa' gasket kit for my motor. Has pretty much everything except the 6 rubber pucks under the cam towers
My project thread:
pat english
« Reply #8 on: June 02, 2012, 02:41:23 PM »
Right on.Ill be tearing down the engine soon.I got it pretty much stripped down.
Offline wrenchmuch
« Reply #9 on: June 02, 2012, 03:15:27 PM »
The pump does have a gasket. It comes in the Athena kit and in the kit Cycle x sells. I'm not sure about Vesra. The gasket goes between the pump body and the casting that contains the screen , check valve , and high pressure relife valve. The 3 o rings that seal the pump to the engine come in most kits but the big o rings that seal the pump rotor covers don't. They
measure 2 mm x 46 mm. There is also a seal in the pump that isolates the scavenge side of the pump from the engine supply side. It measures 11 mm x 15 mm x 3 mm. Hondaman and others have posted on this seal before. It's not available as a 750 part from Honda but can be ordered as a Goldwing part. Western hills Honda lists it as part # 91208-MN1-771. Search for it as a GL 1100 part in the 81 model year.
CB750K1
CB750K4
« Reply #10 on: June 02, 2012, 03:39:44 PM »
my 'vesrah' kit lists an oil pump gasket as well as an oil pan gasket. I do not believe it has the big o rings you're talking about either though.
How necessary is it to prime the oil pump if you've pulled it out and it's got nothing but air in it? When I'm assembling the engine couldn't I just put a good quart of oil in the bottom of the case or whatever submerges the pump and leave enough room in the oil tank for it?
My project thread:
Offline wrenchmuch
« Reply #11 on: June 02, 2012, 03:59:35 PM »
Air in the pump is VERY hard to get out once installed . Prime the pump before installing and keep the engine upright untill you run it .
CB750K1
CB750K4
« Reply #12 on: June 02, 2012, 05:10:28 PM »
Ok. I'm going to be changing my car oil in the next few days do you think it would hurt to prime it with the old 5w-30 out of my car? lol I'm not at the point to purchase the MC oil I'll be running in it yet. I'll be doing an oil change shortly after the initial start up and break in.
My project thread:
« Reply #13 on: June 02, 2012, 06:30:53 PM »
You may be joking but at least buy a qt of cheap new 10-40 to dunk it in.Use the rest in your mower or something or dunk and purge it in some of the fresh oil that will be going in your car first..
« Last Edit: June 02, 2012, 06:34:21 PM by ekpent »
« Reply #14 on: June 02, 2012, 06:44:00 PM »
kk. So after I prime it I can't turn it upside down? Dang the only real way I'm working on that part of the engine is with it upside down I don't have an engine stand. hmmmm I'll have to figure something out. Not only that but going back into the bike, the motor is going to have to be laid on its side to get the frame over it. Lots of complications there!
My project thread:
pat english
« Reply #15 on: June 02, 2012, 06:53:14 PM »
Ah ok good to know.My pump didnt have a gasket.The o rings are small.About the size of a dime.I dont know what the parts are called but they go around the 3 bushing type thingys in between the pump and the case.
I dont understand whats so hard about priming the pump.Wouldnt it prime itself if you kicked it over a few times?(without starting)
« Reply #16 on: June 02, 2012, 06:58:54 PM »
[/quote]
Well, not if all the oil is sitting in the oil tank and there's nothing but air in the oil pump, it wouldn't suck anything.
My project thread:
pat english
« Reply #17 on: June 02, 2012, 07:01:33 PM »
So i should fill the pump with as much oil as possible and bolt it on?(sorry if these are dumb questions,ive never done this before and i dont have a manual)
« Reply #18 on: June 02, 2012, 07:05:31 PM »
The oil pump gasket is only necessary if you disassemble the oil pump, not recommended. Otherwise its just the 3 ORings.
Priming, just set it in a pan of oil. Turn the drive gear till you see oil come out of one of the openings i forget which the manual shows.
had it been run anytime recently or is it 10 years doemant?
pat english
« Reply #19 on: June 02, 2012, 07:17:35 PM »
Ok cool.I didn't take the pump apart.Sounds easy enough.No.The engine was seized up and the oil was super black and sludgeified..The tags said 96.So i'm guessing its been over 10 years since it ran.
bollingball
« Reply #20 on: June 02, 2012, 07:27:49 PM »
Why not
Offline Spanner 1
« Reply #21 on: June 02, 2012, 07:48:00 PM »
b.ball +1.... asking questions here and admitting you don't have a manual is akin to a Protestant admitting they haven't got a Bible  :D :o
pat english
« Reply #22 on: June 02, 2012, 09:22:26 PM »
lol..i just dont.
Offline onepieceatatime
« Reply #23 on: June 02, 2012, 10:09:06 PM »
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
« Reply #24 on: June 03, 2012, 05:12:25 AM »
That's what I was concerned about. The pump's got that old oil in it so I'd want to get the old oil out. Priming will do that.
