When I replaced my forks seals and cleaned out the forks the rubber gasket went bad on the nut that goes over the spring. Part right above the top of the triple. Well Home depot 31MM gasket didn't work and I was soaked in Honda Pink fork fluid. I replaced it with an old part and now no more leak. Although when I tried to fill the fork with more fluid it wouldn't take any. Springs are in, poured in and over filled. I know the fork does not have the right amount of fluid. It's low. Am I missing something when filling it up?
