Author Topic: CB550 Rear disc conversion  (Read 6688 times)
Offline Jonny Rock-it
« on: August 16, 2012, 08:13:03 PM »
So I saw a video on youtube where a guy used a 750 hub and disc for a rear disc conversion on a 550 and I started wondering if a 750 front hub will fit a 550 rear axle without any mods?
Everyone Pities the weak, Jealousy must be earned
Re: CB550 Rear disc conversion
« Reply #1 on: August 17, 2012, 12:10:34 AM »
how will the drive sprocket bolt on?the 500/550 and 750 share the same front hub.
Offline fastbroshi
  • Puppet
« Reply #2 on: August 17, 2012, 02:36:32 AM »
I think the easy way to approach it would be to just grab the whole rear end off of a 750F.  Slightly longer swingarm but the pivot point width on the 750 arm should be real close to the 550.  Might have to shim out/in the sprockets.
Just call me Timmaaaaay!!!
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #3 on: August 17, 2012, 04:03:03 AM »
Using a front wheel for the rear is not easily done. A mill and a lathe help alot.
 Using a 750 disc/rear wheel and swingarm would get you more than halfway there.
Pics are a 750 front wheel converted to rear wheel use on a 750. Bearings needed to be changed to 20mm, adapters needed for sprocket and disc, new axle spacers needed, caliper mount made,etc...
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
« Reply #4 on: August 17, 2012, 04:09:32 AM »
so?,no damper drive?
Offline fishhead
« Reply #5 on: August 17, 2012, 04:12:45 AM »
Nope.
 This wheel replaced a Shelby-Dowd wheel that also didnt have a cush drive.
Offline voxonda
« Reply #6 on: August 17, 2012, 04:38:20 AM »
The one I am building, and have build before, do have a damper drive. But like fishhead says it involves some work.
Rob
« Reply #7 on: August 17, 2012, 07:26:57 AM »
Nope.
Wow that's cool! What size rim?
You and I are going to have to deal on something someday. Your stuff is too cool.  Maybe a 4 piston caliper setup for a 75F?
Anyway, for those watching, that's a cross 2, ALL INSIDE spoke pattern.
Where'd you get the spokes?
Offline fishhead
« Reply #8 on: August 18, 2012, 04:32:16 AM »
The rim is 18 X 2.5.
  I believe the spokes are heavy gauge front CB/GL that were cut down and rethreaded (with a proper thread roller). I used inner lacing because it lined up best with the rim holes.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #9 on: August 18, 2012, 09:40:30 AM »
Very nice.
Offline Peekster
  • you are probably underestimating me
« Reply #10 on: April 16, 2019, 05:33:50 PM »
IM looking to do a rear disc conversion on my 74 CB550, exactly how well will a CB750 rear swing arm fit. im not worried about length ill factor it in when I chop the frame to hoop it.
1974 CB550
Modifying custom parts
Offline Bankerdanny
  • Endeavor to persevere
« Reply #11 on: April 17, 2019, 08:04:04 AM »
The width of the pivot is the same, so it should bolt up fine.
« Reply #12 on: April 17, 2019, 09:28:16 AM »
May be too wide to fit inbetween pillion loops
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #13 on: April 17, 2019, 09:43:44 AM »
Following
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Peekster
« Reply #14 on: April 18, 2019, 07:42:15 PM »
1974 CB550
