Author Topic: Coil Grounding  (Read 6665 times)
Offline Prospect
Coil Grounding
« on: August 19, 2012, 03:42:40 PM »
Are the coils grounded to the frame via the two metal mounts or is it via the black wire?  I'm trying to diagnose a possible coil issue.  Bike is a cb750k1
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline killersoundz
Re: Coil Grounding
« Reply #1 on: August 19, 2012, 03:44:21 PM »
Nope they don't get grounded. The plugs ground out to the engine.
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
bollingball
Re: Coil Grounding
« Reply #2 on: August 19, 2012, 03:53:23 PM »
+1 They can hang in the air or be rubber mounted ;D
Ken
Re: Coil Grounding
« Reply #3 on: August 19, 2012, 04:09:15 PM »
1- coils need no frame ground
2- Black wires on these Hondas are NOT Ground.  Black wires in the harness are switched +12V.  Harness Grounds are green.
It's in the FAQ, as well as a wire diagram for the bike.
Offline Prospect
Re: Coil Grounding
« Reply #4 on: August 19, 2012, 04:58:55 PM »
ok thanks.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Re: Coil Grounding
« Reply #5 on: August 19, 2012, 06:56:42 PM »
The main harness green wire is grounded on one of the coil mounting bolts. The coils themselves are "grounded" thru the points, via the blue and yellow wires. ;)
Offline Raul CB750K1
Re: Coil Grounding
« Reply #6 on: August 20, 2012, 07:29:30 AM »
All the above is true
BUT
if the condensors are located at the coil bracket, you need it grounded.
I commited that mistake. Painted the frame and thought no ground was necessary. My CB350 run like crap.
It took me a lot of "not seeing the forest because of the trees" to realize that without the condensor grounded, the spark was not strong enough. Wire-wheeled the frame at the bracket bolt, and the bike run well again.
Can't remember where does the fours have the condensors. They coul be at the points plate but I dont' remember, it's been years since I don't have to adjust my CB750 points. If such is the case, then you don't need ground at the coils bracket.
Offline CycleRanger
  • No comment about being an
Re: Coil Grounding
« Reply #7 on: November 24, 2012, 11:31:54 AM »
BUT
if the condensers are located at the coil bracket, you need it grounded.
I committed that mistake. Painted the frame and thought no ground was necessary. My CB350 ran like crap.
Just the information I was looking for.
The forum provides... :)
Offline Xnavylfr
Re: Coil Grounding
« Reply #8 on: November 24, 2012, 12:27:09 PM »
Another thing to add, Make sure when you install new points you have the phenolic washers BETWEEN the wires and connection post or it will ground out and NO SPARKY>>
Xnavylfr(CHUCK)
Re: Coil Grounding
« Reply #9 on: November 24, 2012, 02:31:49 PM »
While the coils don't need grounding, the condensers do.
However, it would be extraordinary for the SOHC4 condensers to NOT be grounded, as they are located on the points plate.  If the plate isn't attached to the engine block (ground), the points won't function either.
If you painted the points "pocket" in the engine block and points plate mount posts, then the three mount screws need to make ground path.
You will need a good ground path between battery NEG and the engine case, as well, with no paint insulators.
Re: Coil Grounding
« Reply #10 on: November 24, 2012, 06:18:43 PM »
The transformer core is grounded.
True, but that is a mechanical mount feature.  It is not required for proper operation.
Re: Coil Grounding
« Reply #11 on: November 24, 2012, 07:58:44 PM »
no.  Nothing informative or very clear at all, really.
Certainly nothing to help understand what is needed for function.
bollingball
Re: Coil Grounding
« Reply #12 on: November 25, 2012, 11:56:58 AM »
Did I say it was needed for proper operation?
rt
No you did not. Which makes me wonder why did you bring it up at all?
It is clear that he has an electrical problem and needs to know if the (transformer core) needs to be grounded. Then you come back and say it is grounded. That could confuse a person trying to understand how this works. It would have been better to say it is grounded but does not need to be. Just saying ;)
Ken
