Author Topic: structural question - fork swap with the dreaded drum brake.  (Read 4236 times)
Offline greenjeans
  • 1972 CB750K2
« on: September 04, 2012, 02:19:50 PM »
I know this makes absolutely no sense but...
I have a giant 4LS drum brake (been hoarding it for years) that I want to use on my current toy - (73 CB750K)   Not much trouble there.   My problem is:   Now I want to run that brake with a modern inverted fork off a GSX or CBR what ever ends up being easier.
The drum brake requires a stay for each side.   No problem on the older style forks - you'd just use the fender/brace mounts.
Since I'd be using the inverted forks, the only places to mount the stays would be on the caliper mounts.    Again, i don't really see too much of an issue there - I could be wrong.    My concern would be if the mounts for the calibers would be strong enough for the drum stays.   The calipers have 2 mounting holes, where the drum stay would only require one.   I guess I could make a stay that used both.
And if that isn't enough, I'd like to remove the excess material from the lower fork as well to clean it up.   Most of them look like the are a cast piece then machined.  Would that be a bad idea ?
And finally, this isn't going to be a race bike or anything.   I've finally accumulated enough bits and pieces to build myself something I can keep for a while.
I'll be shopping for a fork this weekend.
« Last Edit: September 04, 2012, 02:25:09 PM by greenjeans »
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: structural question - fork swap with the dreaded drum brake.
« Reply #1 on: September 04, 2012, 04:51:50 PM »
Interesting concept.
I'd be surprised if the drum brake could exert the forces required to stress a modern USD fork.
Especially on day to day riding conditions
« Reply #2 on: September 04, 2012, 05:13:29 PM »
Interesting indeed.  Most guys change to the modern front end and go modern with the brakes, too.  Your combo is a bit of a mindbender:  better handling but older braking (a good twin leading shoe probably beats a stock un-rebuilt disc though!).
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: September 04, 2012, 06:34:50 PM »
Purely aethetics.  I plan on stripping the anodized finish off the forks so they don't immediately give things away.  Want to keep a vintage race-bike "look" but with some subtle changes so it's not as easy to recognize things.   At the risk of saying it...industrial.
Offline Flying J
« Reply #4 on: September 04, 2012, 08:47:24 PM »
I like it. Get it done.
« Reply #5 on: September 04, 2012, 08:59:22 PM »
Love the look of frt drums...
Offline fastbroshi
  • Puppet
« Reply #6 on: September 05, 2012, 01:50:02 AM »
I think it'd be easier to do with a USD fork that doesn't use radial mount brakes.  Some member here just picked up a rough ZX-7 that he's going to part out, I'm pretty sure those had mounts you could use.  I think the member's name is Dmitri something.
Just call me Timmaaaaay!!!
Offline lucky
« Reply #7 on: September 05, 2012, 10:28:43 AM »
It is the same force.
Drum or disc.
Just make sure you make a good link or plate.
It is done all the time.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #8 on: September 05, 2012, 11:31:55 AM »
Drum or disc.
Not if the drum can't stop the bike in as short a distance as a disc.
Offline lucky
« Reply #9 on: September 05, 2012, 03:36:20 PM »
Drum or disc.
Some drum brakes are better than the disc brake. They have more swept area and some have multiple shoes being actuated.
« Last Edit: September 05, 2012, 03:38:09 PM by lucky »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #10 on: September 05, 2012, 04:02:09 PM »
That may be true of disc vs drum brakes of a similar vintage, but your earlier statement was directed at my comment below.
"forces required to stress a modern USD fork" being of importantance.
Offline greenjeans
  • 1972 CB750K2
« Reply #11 on: September 07, 2012, 08:31:59 AM »
When you see the braking surface of this monster, you'll understand.   It won't be as nice as a modern 4-piston caliper brake, but it will stop this beast as good or better than the original.   A lot of the vintage race guys use this exact brake.  (It's off the 72 Suzuki GT750)
Still searching for a front end at a somewhat reasonable price.
Offline Toxic
« Reply #12 on: September 07, 2012, 08:38:14 AM »
and those GT750 brakes are getting hard to find and cost a pretty penny.
Lucky you.
