Author Topic: Bad idea to powder coat these?  (Read 4197 times)
Offline ncstatecamp
« on: October 04, 2012, 11:28:46 AM »
Can I powdercoating these engine mount bars or Is the fit to tight?
Re: Bad idea to powder coat these?
« Reply #1 on: October 04, 2012, 11:47:40 AM »
I would not do it.
Offline lrutt
« Reply #2 on: October 04, 2012, 11:48:12 AM »
no way you will get those back in if PC. Just paint the heads and ends. Apply grease to the center sections to aid in assembly and keep them from rusting. Or you could zinc plate them if you buy one of those kits I guess.
Offline mono
  • Definitely no
« Reply #3 on: October 04, 2012, 11:52:51 AM »
yeah, clean/lightly grease them.   lol.  no one sees them anyways.
and +1 on them never going back in with PC on them.
« Reply #4 on: October 04, 2012, 12:16:59 PM »
...plus, one of them performs the crucial task of grounding the frame and engine...
Offline ncstatecamp
« Reply #5 on: October 04, 2012, 12:35:14 PM »
Ok off the rack then! Thanks all!
Offline JohnG
  • 1976 CB750F - original owner
« Reply #6 on: October 05, 2012, 02:59:17 AM »
guys who do PCing can mask parts off just like painters can.  So perhaps just have the heads done.  You will then need some fairly gentle scheme for knocking them in place so the plastic does not get dinged up.
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
bollingball
« Reply #7 on: October 05, 2012, 03:38:09 AM »
What plastic?
Ken
Offline trueblue
« Reply #8 on: October 05, 2012, 03:40:30 AM »
What plastic?
Ken
Powder coat is a plastic ;)
1979 CB650Z
bollingball
« Reply #9 on: October 05, 2012, 03:55:46 AM »
What plastic?
Ken
Did not know that thanks
Ken
bollingball
« Reply #10 on: October 05, 2012, 03:59:14 AM »
Powder coating is a type of coating that is applied as a free-flowing, dry powder. The main difference between a conventional liquid paint and a powder coating is that the powder coating does not require a solvent to keep the binder and filler parts in a liquid suspension form. The coating is typically applied electrostatically and is then cured under heat to allow it to flow and form a "skin". The powder may be a thermoplastic or a thermoset polymer. It is usually used to create a hard finish that is tougher than conventional paint. Powder coating is mainly used for coating of metals, such as household appliances, aluminium extrusions, and automobile and bicycle parts. Newer technologies allow other materials, such as MDF (medium-density fibreboard), to be powder coated using different methods.
I guess it could be a plastic or a polymer what ever that is.
Ken
Offline LesterPiglet
  • 1977 CB550F2
« Reply #11 on: October 05, 2012, 04:21:34 AM »
Wiki
A polymer is a large molecule (macromolecule) composed of repeating structural units. These sub-units are typically connected by covalent chemical bonds. Although the term polymer is sometimes taken to refer to plastics, it actually encompasses a large class of compounds comprising both natural and synthetic materials with a wide variety of properties.
Because of the extraordinary range of properties of polymeric materials,[2] they play an essential and ubiquitous role in everyday life.[3] This role ranges from familiar synthetic plastics and elastomers to natural biopolymers such as nucleic acids and proteins that are essential for life.
bollingball
« Reply #12 on: October 05, 2012, 06:44:03 AM »
Wiki
Dang now I can't live without powder coat.
Offline Old Scrambler
« Reply #13 on: October 05, 2012, 08:21:24 AM »
LESTER..........I'm still on the floor ;D ;D ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
  • 1977 CB550F2
« Reply #14 on: October 05, 2012, 08:42:26 AM »
My sig? It's Mentalsoft approved.
« Reply #15 on: October 05, 2012, 09:09:08 AM »
All that aside, what socket size do you think you would have to use if you did put-cot the bolt head?
Offline trueblue
« Reply #16 on: October 05, 2012, 07:26:43 PM »
It would probably all chip off when you try to tighten it, PC is horribly brittle stuff, I used a catalysed acrylic paint on my frame and fixtures, it is as hard as PC but not as brittle.
1979 CB650Z
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
« Reply #17 on: October 05, 2012, 07:28:09 PM »
are you wanting to PC for corrosion reasons or just looks(bolt heads)?
Offline Lostboy Steve
« Reply #18 on: October 06, 2012, 07:34:29 AM »
I think most PC dries to 2-3mil so go on that i guess. But anyway, I had my aluminum fork tubes gun coated with NIC industries flat black because it is "clamp-able". Might look into that. I believe it goes on super thin like an anodize and is resilient as well. Even after clamping, removal new seals and re-clamping, not cracks or chips in the finish. Also, PURPLE POWER and SUPERCLEAN don't affect it so it must be strong.
« Last Edit: October 06, 2012, 07:36:49 AM by twistedengineering »
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #19 on: October 06, 2012, 08:02:41 AM »
When I make parts to fit over powdercoat, I allow 20-30 though for the powder thickness.
