Author Topic: Greggo's Boss K4  (Read 33471 times)
Re: Greggo's Boss K4
« Reply #75 on: April 04, 2015, 05:30:16 AM »
Front end came in...all very nice!  Black powder coated legs with new tubes and progressive springs.  He had the super bike bars flipped, so I'll have to re-work those to set up in the standard position.
I'll be using some aluminum rims from a 750A or a GL1000 (can't remember)...the rear is meaty, but I have to find a hub and spokes...the front is laced up already, but the brake disc needs to be swapped.
What is the front end from?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #76 on: April 04, 2015, 09:07:10 AM »
They look bent in that pic on the carpet.
Dang Stev-o!  You're right.  I had to measure to make sure, and they're only off by 1/4".  Dang...I can't use those superbike bars either.
Offline Greggo
  • Somebody's
« Reply #77 on: April 04, 2015, 09:09:49 AM »
A K5.  The legs are powder coated.  I bought it all from another member.
« Reply #78 on: April 04, 2015, 10:01:42 AM »
Thanks!
Offline Greggo
  • Somebody's
« Reply #79 on: April 04, 2015, 10:10:15 AM »
Thanks!
Forgot to mention that the wheel is from a GL1000.  It's the same hub and spokes, but the rim is aluminum.  I'm using a rear rim (buying from Bill Benton) from a CB750A.
Offline Greggo
  • Somebody's
« Reply #80 on: April 04, 2015, 05:58:02 PM »
Started in on the carburetors.  They'll clean up alright.
I turned my later fuse assembly into an early style single-fuse setup with a pair of prongs left to hold a spare.  It screws onto the battery box for this bike, and I didn't want to spend more money where it's not needed on the real part.  I cleaned up the connectors, and it will function just as I need it to with the K0 harness.
The rectifier looks good, and won't need any work.  My starter solenoid however, was FRIED.  I've opened up a few of these, but have never seen worse corrosion or deeper pits.  I would have just filed down the contacts and run it, but the yellow/red wire was hanging on by two strands going into the piece you can't open up, so it's toast...luckily I have a spare that's been rebuilt.
« Reply #81 on: April 05, 2015, 12:55:55 PM »
I'd just buy some new bars from 4into1.  So many used bars are bent why take a chance?
http://4into1.com/emgo-chrome-daytona-touring-handlebars-7-8/
Offline Greggo
  • Somebody's
« Reply #82 on: April 05, 2015, 03:07:25 PM »
I found these...basically the stockers powder coated black for $25 shipped...deal!
http://www.ebay.com/itm/331416834886?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline Greggo
  • Somebody's
« Reply #83 on: June 12, 2015, 08:23:41 PM »
Tapered steering bearings installed with the new forks today.  Rolled it out into the sunshine...realized I'm going to thank myself later if at this point I just pull a few more parts off, mask everything else, and rattle can the frame.
« Reply #84 on: June 12, 2015, 08:29:19 PM »
Do it!
Offline Bill/BentON Racing
    • BentON Racing
« Reply #85 on: June 13, 2015, 05:13:04 AM »
I think they are....bent! Nice build, Bill  ;D
BentON Racing Website
BentON Racing Facebook
Offline Greggo
  • Somebody's
« Reply #86 on: June 13, 2015, 09:54:52 AM »
Thanks Bill :)
Hey, how far would you go cleaning up the spokes on that aluminum wheel you sent?  Think I need to disassemble it?
Offline Greggo
  • Somebody's
« Reply #87 on: June 26, 2015, 04:40:41 PM »
Painted the frame with Rustoleum and a foam brush.  Spent less than $20 and probably added a few hundred to the eventual asking price ;)
« Reply #88 on: June 26, 2015, 05:00:20 PM »
Hey Greggo........you been riding?
Offline Greggo
  • Somebody's
« Reply #89 on: June 26, 2015, 05:30:28 PM »
Not at all man...thought about picking up a ZRX1200, but decided not to spend the dough. I'll have this one finished by the end of summer.
« Reply #90 on: June 26, 2015, 09:08:37 PM »
Not at all? C'mon Man!   You still have the 500, right?
Offline Greggo
  • Somebody's
« Reply #91 on: June 26, 2015, 10:21:41 PM »
The 500 with the Lesters? Gone...sold to pay for sandcast project parts.  That bike was ready for a whole lot of work that I didn't want to do.  Really, I just miss those wheels ;)  If I could find a cheap 16" rear, or even a decently priced 18" I could pair with my NOS 19" front I'd throw them on this bike.
Offline Greggo
  • Somebody's
« Reply #92 on: January 10, 2016, 07:45:44 AM »
Drilled and wired some bars with new Yamiya switches.  Still working on the RC Webers.
« Reply #93 on: January 10, 2016, 10:05:03 AM »
 Was wondering what bike the Webers were going on.
Offline Greggo
  • Somebody's
« Reply #94 on: January 10, 2016, 10:22:45 AM »
I'm pretty excited about it.  I just this morning ordered the last couple pieces I need to put the second carburetor back together.  Still lots to do on the bike..have a 16" rear Lester in poor cosmetic shape that needs to match a NOS 19" front.
Offline Greggo
  • Somebody's
« Reply #95 on: January 16, 2016, 08:48:05 AM »
A little progress...the internally wired bars are on.  The shock lowering mounts are off, and the KONI's are on.  I repainted the keyswitch bracket and put that on.  The second Weber body is cleaned, and ready for reassembly.
« Reply #96 on: January 16, 2016, 10:04:26 AM »
Lookin good Greggo, glad to see progress.  Did you service the Koni's?
I have an old set too that I may use on the K1, one day.
« Reply #97 on: January 16, 2016, 10:15:43 AM »
Those Koni's are decent shape. Did you rebuild/service them?
Offline Greggo
  • Somebody's
« Reply #98 on: January 16, 2016, 10:38:56 AM »
They're in good shape, no rebuild.  The threads on the clevis are pretty much stripped, so I have those longer bolts and nuts.  I'm thinking about drilling a hole for a cotter pin.
Offline Lostboy Steve
« Reply #99 on: January 20, 2016, 02:51:32 PM »
Greggo, I'm disappointed in a sense. I like what you're doing here, but I really wanted to see that turbo bike go. ;)
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
