Author Topic: CB750 K3F - AKA The Red  (Read 192243 times)
Re: CB750 K3F
« Reply #375 on: August 23, 2015, 03:20:59 PM »
Time for Rebel Yell sipping whiskey. She is back together, on the road and shifts like there was never nothng wrong.
Re: CB750 K3F
« Reply #376 on: August 23, 2015, 03:39:36 PM »
HELL YEAH
Offline Restoration Fan
  • My wife will never call me
Re: CB750 K3F
« Reply #377 on: August 23, 2015, 05:17:47 PM »
Great news, Prokop!  To quote Stev-o and Cal, "Now ride it like you stole it!"
Re: CB750 K3F
« Reply #378 on: August 24, 2015, 03:58:18 AM »
Took her out yesterday with Dorothy's license plate  ;D
Re: CB750 K3F
« Reply #379 on: August 25, 2015, 02:56:56 AM »
I made an honest woman of her yesterday, she is insured and registered, still needs an inspection.
Re: CB750 K3F
« Reply #380 on: August 25, 2015, 08:33:17 PM »
That's a good feeling to be legal.  I register my bikes as antiques, then no inspection required.
Does VA have anything like that?
Re: CB750 K3F
« Reply #381 on: August 26, 2015, 03:36:09 AM »
Yes it does but since I use it as a daily driver I want regular tags.
Hmm, that makes it look like I have some moral muscles but I am definitely missing those  ;D ;D
Re: CB750 K3F
« Reply #382 on: September 01, 2015, 03:17:28 AM »
After the first ride, the very next day she would not shift again.  I opened her up and checked oil passages by cranking with the cover off.  There was a healthy spray of oil coming out.  After that I blew air through the bearing retainer, again all passages were clean.
I decided on two prong approach, based on recommendation by Hondaman above I poured whole bottle of Rislone in the oil tank (11oz instead of 8oz recommended by manufacturer) and took off the neutral arm stopper (#12) to decrease the drag on the shift drum.
So far so good.  Will run her like this for few hundred miles and try again with the neutral arm installed.
Re: CB750 K3F - AKA The Red
« Reply #383 on: September 02, 2015, 05:18:25 AM »
Installed top case to make life easier.  Thanks again, Larry  ;D
Not sure if I will move on with those side Shoeis, future will tell.
« Last Edit: January 07, 2016, 11:34:18 AM by 70CB750 »
« Reply #384 on: September 02, 2015, 05:24:24 AM »
Bike looks good Prokop.   Would look even better with the side bags.
Offline MoMo
  • Ride like you're invisible
« Reply #385 on: September 02, 2015, 05:25:10 AM »
Shoeis would be handy but that old K&G trunk has quite a bit of storage.  You're welcome...Larry
« Reply #386 on: September 02, 2015, 05:25:48 AM »
I'm like Stev-o.  I'm interested to see what it would look like with the side bags because I actually like the look of that top bag there.  It's probably the best I've seen on a SOHC.
« Reply #387 on: September 02, 2015, 05:46:51 AM »
Problem with Shoei are turn signals, you have to use turn signals in luggage - otherwise it does not fit.
Maybe if find Don Vesco fairing, I will put Shoeis on to complete the look  ;D
Offline MoMo
« Reply #388 on: September 02, 2015, 06:05:51 AM »
Prokop, you need to use a Vetter rather than Vesco to complete "the look" ::)...Larry
« Reply #389 on: September 02, 2015, 06:16:13 AM »
I will think about it :)
« Reply #390 on: September 02, 2015, 03:28:54 PM »
Dont do it. Will ruin the l0ok of the bike [sorry Larry]
Offline MoMo
« Reply #391 on: September 02, 2015, 07:55:31 PM »
Was saying if he decided to put on a fairing a Vetter would be more period correct than a Vesco, actually I windshield would be even more correct...Larry
« Reply #392 on: September 05, 2015, 07:01:20 AM »
Doing a go over after a week of riding.  Also will try 125 jets, 120s with needle all the way up are flat around 5500 rpms.
Just little things, the biggest problem so far is a bouncy speedo, don't really feel like topping up the pot, seems to be involved and precise  >:(
« Reply #393 on: September 07, 2015, 09:51:33 AM »
So the Red with 40 idle and 120 main jets was idling fine, but around 5000 rpms there was significant hole, not just butt dyno feeling, real hickup.
The needles were already all the way up (5th notch) , decided I need 125s.  I estimated that I should go with needle in the middle and 125 and it would be just perfect.  Got it all done on Saturday, confident she is in good shape, didn't bother test start/ride her.
Fast forward to Monday morning, 7AM.  In full gear, started her up and she would not move, rev up in idle, nothing.  Only the idle was there.  Dropped the helmet, jacket, gloves, started wrenching.
Set the  I needles all the way down (1st position) and that was quite the surprise.  She idled right at 3000 rpms  ;D and there was no way to knock her down, nothing.
Pulled it apart again - BTW, jetting K0 carburetors with breadbox filter is kids play compare to this.  On K0 I can move needles up and  down with carburetors still installed - to realize that the needle sticks in the top jet. The needle taper was too big for the top jet, slides were staying up, she was reving like crazy - you got the picture.
Luckily I had decent set of needles in my stash.  Set needles on the first position, took her up and down the road, all is well.  Geared up again, 3 hours later, smelling of gasoline, took off.  30 miles on local roads, she revs easily, accelerates as expected, plenty of power.
Offline MoMo
« Reply #394 on: September 07, 2015, 01:03:33 PM »
Confucius say better to reek of gasoline that be doused with gasoline.   Good to hear you are good to go...Larry
« Reply #395 on: September 09, 2015, 05:04:13 AM »
Dorothy donated rectifier and regulator.  Red charges much better.
Also swapped oil presure gauges from Dorothy to Red, it looked like Red has lower pressure in idle but turned out it was just the gauge.
Offline Kickstart
« Reply #396 on: September 09, 2015, 11:49:01 AM »
Finally getting caught up on this thread... good progress on dialing her in!
Keep us posted when you put the neutral arm stopper back in.  Hopefully everything just needed a good flushing.
- Chris
75' CB750F Blue (Project)
No Reserve Racing #171 AHRMA
« Reply #397 on: September 09, 2015, 03:16:19 PM »
Thank you.
I certainly hope that few hundred miles and increased zddp  is all she needs to fix the shifting for good.
« Reply #398 on: September 18, 2015, 03:13:58 AM »
800 miles and oil change, not the first one, she had like 200 miles on her before I split the engine again.
Anyway, oil clean, nothing bad coming out, magnets on the oil filter cartridge had only small amount of very very fine ferrous material - I presume from rings/cylinders.
« Reply #399 on: September 22, 2015, 04:04:11 AM »
Took apart el cheapo feelers and made me a tappet measurement tool.  I should have done it long time ago, much easier to use.
I made two of the same to fight back that german who always hides #$%* on me  ;D
