Author Topic: Shortround's New Project ////888cc\\\\  (Read 19758 times)
Offline SHORTROUND
Re: Shortround's New Project ////895cc\\\\
« Reply #50 on: March 05, 2013, 03:25:23 PM »
Laser? Water jet? I WISH! I drilled 1/4 holes all around the perimeter then connected them with the Dremel. Final cleanup and shaping was done by hand with a file. The vent cover was .014 aluminum sheet. I cut it with a pair of scissors. Drilled and tap the hole 8/32 for the Allen head bolts.
Offline SHORTROUND
« Reply #51 on: March 05, 2013, 03:33:58 PM »
Here's a photo of one I made out of carbon fiber.
Offline chris mcshifty
« Reply #52 on: March 05, 2013, 05:00:51 PM »
Very cool like the brake
« Reply #53 on: March 05, 2013, 07:23:21 PM »
You do a nice job polishing and like your design philosophy...simple clean functional...
« Reply #54 on: March 05, 2013, 10:49:02 PM »
Awesome!
Offline SHORTROUND
« Reply #55 on: March 08, 2013, 04:34:02 AM »
Off the lift and standing on her own two feet.
Offline iron_worker
« Reply #56 on: March 08, 2013, 07:16:00 AM »
Yummy!
IW
Offline brandEn
« Reply #57 on: March 08, 2013, 08:17:28 AM »
lookin good. I bet thats a GREAT feeling to have her on the ground.
Offline SHORTROUND
« Reply #58 on: March 09, 2013, 06:18:16 AM »
One off the lift only to put another one up on the stands. If only the tires were as cheap.
Offline SHORTROUND
« Reply #59 on: March 10, 2013, 05:40:53 AM »
Wheels? Where's that turbine I had lying around the shop?
Offline USCG_C130
« Reply #60 on: March 11, 2013, 09:08:12 AM »
project looks great did you paint or powder your frame? i did a silver too but was not happy with the our come and and thinking im going to powder it now. keep up ithe great work it looks so clean even without the tins on it
Offline SHORTROUND
« Reply #61 on: March 11, 2013, 11:52:56 AM »
Thanks. The frame is painted. Single stage urethane with an HPLV gun. If you're gonna build multiple machines its actually cheaper. I've painted two complete sets of tins and this frame; I still haven't finished the quart container.
Offline snowman
« Reply #62 on: March 12, 2013, 01:22:25 PM »
Looking good, keep up the good work, giving me lots of ideas for my build. Anxious to see where it goes.
Offline SHORTROUND
« Reply #63 on: March 12, 2013, 06:13:09 PM »
I wish I had $400. I would have just bought a fiberglass tank. I love the look of knee indents but this filling and sanding is getting old.  ::)
Offline SHORTROUND
« Reply #64 on: March 21, 2013, 06:33:42 PM »
Been busy at work, so no real progress. I did find time to make some new oil lines.
« Last Edit: March 23, 2013, 10:10:52 AM by SHORTROUND »
Offline SHORTROUND
« Reply #65 on: March 23, 2013, 10:13:59 AM »
She's alive. Firing on all cylinders baby! The cam sounds sick.
« Reply #66 on: March 23, 2013, 01:11:13 PM »
COOL!
Offline SHORTROUND
« Reply #67 on: March 29, 2013, 06:20:27 AM »
Seat Pan  Wrapping 101.  8)
Materials needed:
Seat pan
Camping foam pad
Vinyl, leather, ostrich, etc.
Contact cement (trust me, old school is better)
Clips
« Last Edit: March 29, 2013, 06:26:12 AM by SHORTROUND »
Offline SHORTROUND
« Reply #68 on: March 29, 2013, 01:56:49 PM »
1. Glue two layers of foam to the pan one layer at a time. Egg rate side facing each other.
2. Use 100 grit sand paper to shape the countour. Take your time and don't press hard, let the sandpaper do the work, that's what you bought it for.
3. Have a beer. It makes th process of making a seat cushion more manly.
Tune in tomorrow for final episode. I have an ostrich to catch.......
« Reply #69 on: March 29, 2013, 01:59:30 PM »
67mm bore =888cc   8)
« Reply #70 on: March 29, 2013, 02:10:10 PM »
Hey, in Henry Abe numbers it's a 900  ;) so if we're gonna get that technical we are riding CB736's  :)
« Reply #71 on: March 29, 2013, 02:14:05 PM »
Yep, i have the MTC 67mm 900 set, but 888 it is and its going in my 736...... ;D ;D ;)
Offline bgfootball67
« Reply #72 on: March 29, 2013, 07:58:57 PM »
Great work Shortround.  Makes me want to start another one of my projects.
Columbus VinMoto
Ohio Cafe Racers website - http://www.ohiocaferacers.com
Offline SHORTROUND
« Reply #73 on: March 30, 2013, 07:14:36 AM »
People always ask which bike is my favorite. My reply is always the same; "The next one."
The bad part about opening up a motor and finding Henry Abe pistons is locating a set of rings for them. Where do you find a set of rings? You don't. I shipped the pistons to Top Seal and had them make me a set. It was $175; not much more than a set of NOS Honda rings, but you'll have to use a ring file to set the ring gap. I'm only 125 lbs. The motor has so much compression I can't kick it over LOL.
« Last Edit: March 30, 2013, 07:20:53 AM by SHORTROUND »
Re: Shortround's New Project ////888cc\\\\ LOL
« Reply #74 on: March 30, 2013, 10:47:13 AM »
Too bad you had to go to that trouble. I posted up the Total Seal part numbers for these rings a long time ago  ;)
Top  203778
2nd  201336
Oil    001549
Did you ditch the electric starter? I installed a AGM battery and it turns mine easily.
