13 to 1 sounds good! Heres some more pics.
CB500/4,CB750/4,CB900F/4....Used to think the reason I could spin the little 550 to 13,000+,never a rod problem,eas due to shorter length.Well,yes,but look @ 500 rod,so much better,even has a lower pin hole on small end.A lot like the 900F,Honda learned in the 2 years before 500 came out!!
Well,if the piston won't fit,the sleeve got no chance!!!
Looking Good!
I think you can tell which side I been working on.
When that little blk mark gone,we'll be done on that side!Was all the way across.
1100F rods not out ther rt now,ebay today.I can get the 250 pistons(ain't telling which ones,you guys bought all the 1100 rods!)Bear ,not .050 available,but .025 are.Can get them,cost plus 10% for @ $300.00,don't mind bit need the rods for 17mm pin.I like the pin height 3mm up! ;)Back to filing.Guys,Thanks,Bill
