Author Topic: Sandcast 4286 Project  (Read 196891 times)
Offline Prospect
Re: Sandcast 4286 Project
« Reply #375 on: November 22, 2013, 06:01:29 AM »
More check-marks off the list:
PeakMoto:
Good tapered steering bearings
CB750Supply:
Fork gaiters
Rear brake shoes
Spokes
Front wheel seal
From Yamiya:
K0 engine gasket set
Rear shock top nuts and bottom bolts and other screws & washers
Engine screw kit
Chain case mounting kit
Battery box top rubbers (x4)
I saved $7 by using paypal with Yamiya, I guess because their exchange rate was favorable today.
Splitting the cases this weekend, hopefully that won't cost me anything ;D ;D ;D ;D ;D ;D ;D ;D ;D
I bought a set of fork gators from cb750supply and I have to say they were not an exact or even a good match to the originals.  I think you can still get them from Honda.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #376 on: November 22, 2013, 06:23:56 AM »
PeakMoto:
CB750Supply:
Fork gaiters
Rear brake shoes
Spokes
Front wheel seal
From Yamiya:
Engine screw kit
Hmmm, hopefully they're OK, but if not I have another bike I'll use them on.  I was trying to get the total over $100 for free shipping, and I thought I'd give them a chance.  The spokes are a cheap experiment as well ;D
Offline Roach Carver
« Reply #377 on: November 22, 2013, 08:30:05 PM »
I used those spokes. They were "okay". I can tell you from first hand experience, they dont do well with dog pee.
Offline Greggo
  • Somebody's
« Reply #378 on: November 23, 2013, 07:11:26 AM »
Alright, no dogs around this one, but I'll evaluate 'em when they show up next week.  If I have to, I can get a good deal on buchanan spokes...probably should have just done that :-\  Lots of goodies showing up next week: parts from the painter, head in the mail, spokes, Yamiya gaskets & stuff...hoping to get the cases apart and cleaned out today.
Offline toytuff
  • "watching the pinheads"
« Reply #379 on: November 23, 2013, 11:01:42 AM »
Oh boy, Thanksgiving all the way around!  :D 8)
tt
Offline Greggo
  • Somebody's
« Reply #380 on: November 23, 2013, 02:31:13 PM »
They're apart!  Everything went relatively smoothly for my first 750 tear-down.  Figured out that the pistons have to come off to remove the crank from the top case.
I pulled the oil pan first, and only found a few metal scraps, and some primary chain tensioner rubber bits (yes, it needs replacing).  It looked like the bottom end never came apart for the most recent rebuild because I found a riveted cam chain ::) ::)
Found what I think are crank bearing markings on the outer front edge of the top case.
We pulled the cases apart, and my dad immediately remarked: 'You're going to need crank bearings, those are a little chewed up.'
The gears all looked nice
The crank journals looked great
Still need to remove the kick starter spindle, the top half of the gearbox, and the shift linkage.
Removed the oil pump to examine and compare to MarkB's #97.  It looks to be original.
« Last Edit: November 24, 2013, 07:24:18 AM by Greggo »
« Reply #381 on: November 23, 2013, 06:04:30 PM »
I like good news, glad to hear it
Offline Greggo
  • Somebody's
« Reply #382 on: November 23, 2013, 09:42:48 PM »
Chock full of it ;D Bearings and chain adjusters (soaking in evapo-rust) came in.
« Reply #383 on: November 23, 2013, 10:05:57 PM »
Hey, you're lucky yours has the 3 O-rings on the oil pump dowels! There was a string of them that got out in the summer of 1969 that had either undersized O-rings there, or missing altogether. Honda recalled the bikes for 100% inspection and replacement, and made the shop owners fix them quietly. The ones with no O-rings were reporting "flashing oil lights" when idling hot.
If you're missing that fancy pan gasket in your kit, I think I have one here somewhere.
Offline Greggo
  • Somebody's
« Reply #384 on: November 23, 2013, 10:37:46 PM »
That's good to hear Mark.  Did the dealers replace the entire pump assembly, or just put the missing parts in?  I was careful to keep track of which dowels went where, and I'm waiting on a rebuild kit from Elan.
The right pan gasket should be in the kit, but I'll keep that in mind, thank you.
Offline Greggo
  • Somebody's
« Reply #385 on: November 24, 2013, 05:26:42 PM »
Primary chain tensioners: Go with stock NOS (can be found), or get the new Cyclex piece with its heat resistant material?  They're both the same price, and the Honda parts have been proven to deteriorate over time.  Has anyone heard anything about the Cyclex piece?
"Introducing remanufactured OEM tensioners with our special material for the wheels unaffected by heat and will never wear. This is the same material used on our cam chain tensioners and manual primary chain tensioners. Guaranteed for life."
Offline Bankerdanny
  • Endeavor to persevere
« Reply #386 on: November 26, 2013, 03:03:04 PM »
Stev-o, here's a pic of a later cylinder, where you can see on the bottom side, the extra bolt hole, and the difference in the area surrounding it.  I'm lucky these are still on my motor...the last set that sold on ebay went for over $700.  I wish I wish I could find the right head before I button this thing up.
Things that make you go "hmmm". Are you a female impersonator Greggo? Otherwise methinks that is not your hand. :)
Offline Greggo
  • Somebody's
« Reply #387 on: November 26, 2013, 03:32:28 PM »
Great info Gregg! I see you did your nails?? :o
LoL!  Google pic ;)
Offline Greggo
  • Somebody's
« Reply #388 on: November 26, 2013, 06:06:06 PM »
I like the spokes, but as mentioned the fork boots were not quite like the originals.
Offline Greggo
  • Somebody's
« Reply #389 on: November 28, 2013, 11:37:10 AM »
Happy Thanksgiving!!  I got a chance to check out my painted and clear coated parts that the painter dropped off.  Everything is just about perfect!  The gloss level is just right, and he was able to fix up my center stand bracket.
My Yamiya stuff came in
MarkB let me know how to check for the original 10mm crank, and this one does indeed have the 17mm bolt, signifying the 10mm hole :D
« Last Edit: November 29, 2013, 06:46:40 AM by Greggo »
Offline Greggo
  • Somebody's
« Reply #390 on: November 28, 2013, 11:59:08 AM »
Clear coated hubs to get laced up this weekend
« Last Edit: November 29, 2013, 06:47:17 AM by Greggo »
« Reply #391 on: November 28, 2013, 02:16:37 PM »
Cool! Parts to give some thanks for, fits the season.  :D
When the "oil pump SNAFU" happened, we just had to pull the pans and pumps, install the missing parts and new O-rings. Poor Honda ran plumb out of oil pan gaskets, though, because the parts "pipeline" hadn't filled up yet for the 750. I think our manager at Spring Street Honda ended up making one, once. I still have this mental image of him trying to cut that square hole in the gasket with his pocketknife...
Offline toytuff
« Reply #392 on: November 28, 2013, 04:59:18 PM »
Hubs look great!
tt
Offline Greggo
  • Somebody's
« Reply #393 on: November 28, 2013, 05:38:55 PM »
Hubs look great!
tt
Thanks!  The painter did a great job taking my prep work, going the last few yards with the acid wash/clear coating.  He gave me a great deal on everything too...nice to have a good local guy on hand.
Definitely thankful Mark :D  Nice to have the parts back and looking good.
Offline Greggo
  • Somebody's
« Reply #394 on: November 29, 2013, 10:15:11 AM »
It was easy once I got the inner spokes right.  If the last set of outer spokes don't fit, you have to go back down to the inners, and offset one side of them by one hole.
« Reply #395 on: November 29, 2013, 10:37:01 AM »
Nice Adidas socks, Greg!
Offline Greggo
  • Somebody's
« Reply #396 on: November 29, 2013, 05:33:47 PM »
LoL!!  They're pretty comfy for lacing rims ;D
Offline Greggo
  • Somebody's
« Reply #397 on: November 30, 2013, 08:34:28 AM »
Found some time this morning to finish off the front.  I'll take 'em up to the shop to use the truing stand in the next couple weeks.  Going to get started on assembling the forks this afternoon.
Offline Greggo
  • Somebody's
« Reply #398 on: November 30, 2013, 10:57:49 AM »
I didn't disassemble these forks, so I had to really think about which circlips went in which slot, and which direction the front damper valve faced.  I'm replacing the bottom bolt, so the damper rod is just snug in there to keep the parts together.  They're wrapped up with loose pieces installed to be finished at the shop, so I won't break either of the NLA piston holder clips with the wrong pliers.
Offline Greggo
  • Somebody's
« Reply #399 on: December 01, 2013, 07:47:06 AM »
Well, look at what showed up in the mail yesterday ;D ;D  It's the never ending project!!  This one needs a full rebuild with fresh everything :o
