Author Topic: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'  (Read 72699 times)
Offline BPellerine
Re: TSUNAMI-1978 CB750 K8 DONOR TO CAFE'
« Reply #400 on: November 12, 2016, 05:04:24 PM »
yes I built a 890 engine but took a break from it so maybe this winter.we had a great summer but it is coming to an end once more.funny vid ,billp
1978 CB 750K ard and webers
another anfob
Offline Tsunami
  • There's No Place Like This Place Any Where Near This Place So This Must Be "THE PLACE"!
  • Life's to Short, Carry On!
« Reply #401 on: November 17, 2016, 11:08:41 PM »
 :) 8)Well an update is in order. I'm getting so close! It feels like Christmas when I was a kid. Last time I started the engine (on the rack) I had no oil pressure.  :(  Subsequent test's indicated no oil to the top end, checked to see if I had the lines on as they should be and they were. I found a cut out picture of the oil system, the first place it goes is to the filter.  I removed and inspected and it appears as it should be. Well push comes to shove it was time to pull the pump. >:( In so doing I had to loosen the exhaust to gain clearance too the two screws on the right side. I ordered a rebuild kit as long as I was going to pull it.  Close to $50, I later found out I could have purchased a complete pump with all new parts and tested for $62.50 or so. I'm still waiting for the kit.  Meanwhile I educated myself to the whys and where fore's of the pump. My neighbor suggested to see if the plunger that keeps the oil from filling the crankcase when the pump is off would move?    Not wanting to scratch anything I removed the end piece and spring to see if it was loose. shook it, nope. Gave it a little rap on the bench, no joy, didn't budge, tried again a little harder, no luck.  Found a small plastic dowel and pressed it from the inside out and it began to move and definitely was dragging.  So I figure after sitting in the garage for 3.5 years something may have dried out and kept it from moving to pass oil. New parts and a good prime and hope I'm in business. I'm happy that Tsunami started right up and made a joyous sound The parts will not arrive until the 23rd, I won't have any finger nails left until they do arrive. Meanwhile in order to actually ride it I have to tidy up a few things, bleed the brakes, air up the tires, do a check to see that everything that should be tight, is. Also need to source someone to paint the tank which should have been done long ago. Since the custom painter wanted $2200 I'm searching for alternatives or I will have to set up the paint room and try it again. I did a pre- launch test of the electrical system including getting all the wiring back into the light bucket. I did but it was really tight and in the process managed to disconnect the horn and the kill switch connectors.  Pulled it all out again and plugged the two so everything works. I may have to remake some lines shorter or find a bigger bucket.  The bucket it had on it originally was plastic with a well-worn covering of whatever they used to make it shine like chrome.  I bought a Kawi bucket because it was metal and had a great finish on it. Front to back though it was shorter. :'(
So that's as much as I can remember these days. So if and when I  F-I-N-A-L-L-Y  get it started I will be recording from two vantage points and will pop it onto Utube for all to see.
I and my family wish all the members SOHC members and their families a Thankful Thanks Giving! For our members outside the country, please, please pray for us, it’s going to be a wild ride. God Bless America
[Tsunami Build Link]
CL450 early 70's
New 1973 CB750 Flake Sunrise Orange
CB350 Chopper early 70's
CB350 Cafe' early 70's
Honda Cub 90cc late 60's
Other's
Offline BPellerine
« Reply #402 on: November 19, 2016, 12:26:26 PM »
ya wild ride indeed,scoping out Canada?hahabill
another anfob
Offline Tsunami
« Reply #403 on: March 26, 2017, 12:20:40 AM »
Well I'm not dead yet, engine runs, that was a relief. The wire bundle to the key switch/dash was too long finished shorting that a couple of days ago.  Have gotten really good a crimping connectors. Finished placing the rivet's over the new aluminum tank covering.  Should be dry tomorrow so will start painting high lighting to the panel lines. Then I start weathering the tank with some rust.  I certainly will be different one of those love it or hate it kind of things. Then I can do the 2k clear coats, place the knee rubbers. Then finally assembly to both tank a seat.  That should put me within the hair of a gnats ass to being able to ride!  How many times have I said that. Best laid plans and all that.
« Last Edit: March 26, 2017, 12:33:07 AM by Tsunami »
CL450 early 70's
Other's
Offline BPellerine
« Reply #404 on: March 27, 2017, 05:58:49 PM »
looking good greg,may you get to ride it this year!bill
another anfob
Offline Tsunami
« Reply #405 on: April 07, 2017, 12:15:28 AM »
Hey Bill good to hear from ya! Wet your whistle on these pics!
« Last Edit: April 07, 2017, 03:55:06 AM by Tsunami »
CL450 early 70's
Other's
Offline BPellerine
« Reply #406 on: April 07, 2017, 07:41:33 AM »
looks cool greg,almost battle ready!haha bill
another anfob
« Reply #407 on: April 07, 2017, 08:46:46 AM »
Looking great.  Is she complete or still have some "to do" items left?
Offline Tsunami
« Reply #408 on: April 07, 2017, 02:26:32 PM »
WHO YOU CALLING A "WIPPER SNAPPER"  I'm so old I forgot your name #1235? It is all "about done"! You both know its about tying up the loose ends. I'm waiting for Shawn to finish my longer hose , the top from the master to the T manifold. The other I estimated to short, it works but is too tight for my liking and that is one thing I really don't want to fail. It runs and sounds strong from the tailpipe but it seems to me to be making more of a clattering sound on the top end so I'm rechecking the valve lash and resetting the cam chain tension. Lastly I have to adjust the rear sets to function with my big feet and the angles my legs will be in. I spent some time rechecking wires in the light bucket. Its so tight in there the last time I set the light the horn, and aux lighting (dash lights and tail light had pulled out, that's fixed. Of course I have to put the light back in.  When that raised its ugly head I had to go in and shorten a load of wires and install  a bunch of new connectors.  In the process I bought an upscale crimper which worked very well. If any body out there is struggling with the quality of the connections, get a good crimper you will be glad you did!   I also need to align chain. I should probable check the clutch cable alignment as well.  I'm sitting here running through my memory items I need to tidy-up. Have to install the fuel tank valves and make and run the lines to the carb. See what you started? I'm writing these all down so I don't miss anything? That may be it. I may have as much as an hour of run time on the bench so to speak. Then if everything works on the next test I'll try to ride around the block, pray for me! LOL
I also finished painting the Firestone moniker on the tires last weekend.  Not easy given the size of the text but I like the results. It remains to be scene if the "Ranger" paint holds up.  Did a lot of research on that one and there stuff got great reviews.  Brush's of no use. Used the time of a sharp popsicle stick, tip of a small screw driver and the point of small sharp tool to flow it on worked best.  I hadn't done it prior to the last set of photos, Ill run down and take a shot then Ill have to get back to work on my dead line.
CL450 early 70's
Other's
Offline BPellerine
« Reply #409 on: April 07, 2017, 05:48:27 PM »
hope you make it around the block!old school white letter tires,I remember my first set of mickey Ts !bill
another anfob
Offline Tsunami
« Reply #410 on: April 07, 2017, 07:47:16 PM »
Funny Bill, their making a comeback down here in the low country. Hell I've been running ROWL Michelins that came on my 1999 Ram Sport for the last 18 years .   I really liked the Guy too bad someone murdered him.
He achieved international fame in 1960 when he became the first American to break the 400 mph barrier, driving his Challenger 1 to a one-way top speed of 406.60 mph at the Bonneville Salt Flats and surpassing John Cobb's one-way world record mark of 402 mph.
Thompson then turned to racing, winning many track and dragster championships. Later he formed sanctioning bodies SCORE International and Mickey Thompson Entertainment Group (MTEG).
In 1988 Thompson and his wife Trudy were mysteriously gunned down at their home in Bradbury, California. The crime remained unsolved until 2007, when a former business partner was convicted of having orchestrated the murders.[Wikipedia]
Shawn over at Slingshot says the line is shipped!
Woo Hoo
« Last Edit: April 07, 2017, 07:49:16 PM by Tsunami »
CL450 early 70's
Other's
« Reply #411 on: April 08, 2017, 12:06:55 AM »
Amazing!  Finish her up so I can nominate her for BOTM!
Offline Tsunami
« Reply #412 on: April 08, 2017, 02:10:04 AM »
Thanks Don, see I remembered! You and Bill will be the first to know!I came here from your Tapatalk and when I sent the message with pics it dropped the whole thing?  Meanwhile ------)
So I will try one if it drops I will go in another way Well it would not post, Ill try two at a time see if that works. Sorry for all the messages coming through but not my fault I think.
It would not do any over 3 pictures at a time, very disconcerting.
« Last Edit: April 08, 2017, 02:36:47 AM by Tsunami »
CL450 early 70's
Other's
« Reply #413 on: April 08, 2017, 09:01:35 AM »
Love the shirt Greg!
You tell us when you deem it a "complete" runner.
Offline BPellerine
« Reply #414 on: April 08, 2017, 01:17:53 PM »
looks nice in the sun,which we are just starting to see more of here,I worked at Michelin for 31 yrs uuuugggg!bill
another anfob
Offline Bootsey
« Reply #415 on: April 08, 2017, 07:34:08 PM »
Just caught up on your build, there's some very impressive touches in there, kudos!
What was the final finish you went with on the tank & seat - some kind of covering rather than the chrome-like paint?
Offline Tsunami
« Reply #416 on: April 09, 2017, 02:07:14 AM »
Bill, thanks!  31 years bill? That's sick! What is sicker? Me being a residential appraiser for 37 years and still going. UUUUUUUG
CL450 early 70's
Other's
Offline Tsunami
« Reply #417 on: April 09, 2017, 03:44:20 AM »
Hi Bootsey, thanks for the compliment.
The final finish?  Well it is for now. Its also a bit of a story.  My wife's father was a WWII P-38 pilot in the pacific. He was a ground attack grunt so was always being shot at.  He actually lost 5 planes in the war having had them shot out from beneath him! We used to call him Americas only Japanese Ace. 5 planes = Ace. So doing he had little time to fancy up his plane like the guys whose job was to shot down enemy fighters like Bong the great P-38 ace.  At the time Captain Shaw did get credited for one shoot down. The time we talked about it I could see in his eyes the disappointment in them. He so wanted to have placed his wife's likeness on the nose.  This nagged at me until I realized I could build that plane for him!  I had been a modeler of some note and quite a slope glider guider and builder in my day.  So I bought a kit that had the fiberglass booms and pod with some foam cores to make the wings with.  When I got to the part of how to paint the plane I was stymied in how to get the aluminum look?  Then I ran across a product called flight metal.  It was pages of really thin aluminum with an adhesive on one side with a paper covering which you cut to size and rubbed on. It was great when covered it was very shiny but working P-38's were not all shiny but dull and dirty.  So I proceeded to weather the finish after I placed all the markings of his outfit and a likeness of his wife on the nose. When I presented it too him he was overwhelmed. One of my better days.
and a few of my other planes
Its 15:30 in the morning and I still have to upload some Pics with this. Roger Wilco I'm out
So I had tried to do this new chrome/polished aluminum look, expensive and I should have has pro do it and it would have been done long ago.  Well I couldn't afford it so tried to it myself with limited results.  Here again I should have stopped there and be satisfied with it but NoOOOOO not me. So then set out on an odyssey of using other paints to gain a different look by was still not satisfied, did I stop there?  NoOOOOOO I finally gave up for awhile so when I got near the finish of the build last year I tried to find a reasonable painter to do the job?  NoOOOO $2200 Then I learned about hydro graphics, which was suppose to be affordable, well all the guys I found to do it apparently didn't get the memo.  Tank and Seat $2400 so NoOOOOO I ran out of ideas. Then the weirdest thing happened, it came to me in my sleep of all things, I hardly ever dream but the idea woke me up.  I remember the P-38, hell if it worked on that why not on my stuff.  The Metal Flight stuff was too thin and too expensive so I had more research to do.  I solved the problem when I found rolls of aluminum that heating and cooling workers used to seal joints with it.  I came in array of thicknesses and widths.  Most any length was available on flea bay.  I went with a much thicker one, had I to do it again I would get something thinner (more workable) 6" wide and 65 feet long.  I hadn't thought about the fact this stuff didn't come with a paper backing but I could live with that.  Took some preplanning to make it fit the curvature of the tank, (work from the top down).  I had used these artist sticks of tightly wound paper, they would use it to smudge chalk or something forgot the name of them be it didn't mark the metal.  I could use it to stretch the metal if needed to a certain extent.  My theme is something of an industrial look, not a show bike but I like to think of it more as a "Gentleman's Ride". So its not perfectly polished which I like, adds a juxtaposition to the other polished parts of the bike. I know its different , pops a little   I wanted rivet's but my painting skills just weren't up to it so I thought to simulate rivets.  I used 3/8" upholstery tacks.  The seat I could drill small holes for them, a tight fit and some "goop" on the inside.  The tank I could not drill so just gooped them well.  I have used this stuff before and it is tenacious in it hold ability and if you need to you can remove it sort of like rolling off rubber cement.  I couldn't find an aluminum lookin tack so painted them myself, I later found some zinc, I think, or not a polished nickel which would have saved me some work. The aluminum is also able to be removed, don't know what it might be like in a couple years to do.  Theoretically you could remove it all and go some other direction at a later day with little harm that could easily be repaired (the little holes in the seat, very small).  Once that was all done I set out to weather it a little with giving some dimension to the panel lines and rusting the rivets a little.  I may at a later date get a name on it.  Well that's my story and I'm sticking too it!  Are there any questions?
Too finish the pilots story in brief he was shot down near the end of the war , in New Guinea, between the dropping of the atom bombs, captured by General Yama#$%*a's army, didn't lose his head, taken to his camp, interrogate by the General, who had hoped to find out what the Atom Bomb was all about, which he knew little of, given a letter to take to his General and was instrumental in getting General Yama#$%*a to surrender in so doing saving many lives on both sides.  The rest of it you will have to buy the book to find out.  Its fantastic, hope we can do it some day? Title "Between the Bombs" a Pilot, a letter and a Promise.  Quite a man, very unassuming and the exploits would make your head swim, he went through flight training with Chuck Yeager and Bob Hoover all some of the best of the best pilots their ever were. IMHO
« Last Edit: April 09, 2017, 04:42:13 AM by Tsunami »
CL450 early 70's
Other's
Offline budman
  • 1914X
    • LeCompte Electric Bass
« Reply #418 on: April 09, 2017, 06:34:39 AM »
Wow!  Crazy build.  Impressive.  Congratulations.  Great story about your father-in-law.
Bud
1973 CB750K3 Chopper (in pieces)
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #419 on: April 09, 2017, 07:37:46 AM »
I love the bike, the story and the effort put into the dedication for your father.  I nominated the bike for BOTM since Bud threw me in the mix, I figured I would add one myself.  :)
« Reply #420 on: April 09, 2017, 09:26:59 AM »
Well assuming it is complete, your bike has been nominated and seconded, and only requires that you "accept" in the following BOTM thread:  http://forums.sohc4.net/index.php/topic,164763.0.html
Offline palepainter
« Reply #421 on: April 09, 2017, 10:28:53 AM »
Ya, my bad.  Thought it was completed.
« Reply #422 on: April 09, 2017, 11:32:32 AM »
Just caught up on your build, nice job. Only 4.5 years in the making...
Offline Tsunami
« Reply #423 on: April 09, 2017, 03:04:10 PM »
Gentlemen, not so Gentlemen and Ladies I am over whelmed with your enthusiasm! I have looked forward to joining this club but am unable to accept at this time. I like SOHC4 Cafe Racer Fan eloquently put it the bike should be adequately functional to be nominated.  I have been so close before to getting this done I could taste it, but as we all know life and its ramifications sometimes do not agree. Like my planes when you compete, you must be able to fly to win. I wish not to dampen you enthusiasm but engage you to vote for me next month SOHC4 Café Racer Fan had already expressed to nominate me when the bike is completed and I agree.  So with deep regret I must decline nomination for this month.
I will say however if I can’t get Tsunami on the rode by next month I will haul out the engine puller, lift it and put it in my boat, drive to Santa Cruz, motor out to the deepest part of Monterey Bay and that trench is very deep then dump her in never to be seen again!
Mind you I will however be ready by then.
Meanwhile I will be voting for Pale Rider, I love that bike.  He and his family’s provenance, well let’s say I am deeply impressed! So I say vote for Pale Rider!!
I’m taking this to heart fellas and won’t let you down. It’s important to stick with tradition, I will be there with bells on, oh wait I already have them--
The meaning of motorcycle bells is often associated with little gremlins and/or demons that hide along the highways and sabotage motorcycles, causing bikes to crash.
But their history goes back, way back.
As early as the 11th Century AD, Catholics in England and Scotland rang "dead bells" in a funeral procession to ward off evil spirits. The use of bells grew in popularity in the Catholic Church as a way to mourn passing souls and continues to this day. The use of bells hanging from windows, doors, and overhangs, have been used in many cultures to ward off malicious spirits.
It wasn't until the 1920s, when pilots of the Royal Air Force began talking of little creatures that wreaked havoc with their airplanes. The word "gremlin" was coined, deriving from the Old English, "gremman" or "gremian", which means to "to vex". It described little humanoid creatures that sabotaged airplanes perhaps as humorous way to explain the fault-prone construction of RAF technology.
Roald Dahl was a pilot in the RAF during WWII, and advanced the idea into a children's book entitled, "The Gremlins", which was eventually published by Walt Disney. The book sold 50,000 copies initially with an additional 30,000 later on. American pilots adopted the gremlin folklore and even claimed to have seen them just before a crash or malfunction. It was enough to convince many pilots to use charms to ward off gremlins, including the centuries-old dangling bell.
When American pilots returned home from WWII, many of them continued their wartime camaraderie on motorcycles. Some of them formed clubs, making lifelong friends of their fellow servicemen.  They brought the same gremlin myth to their motorcycles, and some of them hung small bells from their bikes.
As motorcycle club culture increased in popularity, accessory manufacturers began looking for ways to capitalize, and began selling motorcycle bells. The notion that a motorcycle bell had to be given as a gift in order to gain protective powers seemed to discourage sales, however. Manufacturers countered by introducing a contrasting myth that a self-purchased bell already has sufficient power, but that a gift-given bell has double powers.
CL450 early 70's
Other's
Offline Tsunami
« Reply #424 on: April 09, 2017, 10:21:28 PM »
Here I go again, my apologies to the board and esp Pale Painter, it was 4 am and I got rushed,  Just the same insert Pale Painter instead of Pale Rider ( Clint is going to kill me). and I still like his bike its not about the dollars its the bike no matter how much it cost.  Someone tell SOHC4 café racer fan to stop beating the bottom of my feet with that old brake rod. I'm sorry, ok.  Just me guys I like to kid around and over do everything.
CL450 early 70's
Other's
