Author Topic: My snotty filthy new Bridgeport milling machine  (Read 29229 times)
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« on: March 22, 2013, 09:11:27 PM »
I recently purchased an old mill and have begun the process of cleaning.....yikes. The X axis shakes and everything is stuck with aluminum dust. Either way I am frigging pumped to have my own mill.
This morning I had to remove the head and motor. Just like when you go to WebMD and look up "rash" I had gone to Google and looked up "removing a Bridgeport mill hear"...ug. I found so many drawn out over built well thought out approaches to undo those 4 bolts. I took notes. Made a fixture, bolted it to the bed, bla bla...got stuck 1/4" from coming completely out dut to the bandsaw table (in pic). I ended up just bearhugging the frigging think and pulled it away. Done. Be careful.
I used some WD40, orange degreaser, laquer thinner and a brass wire brush. only had about 30 mins to play.
Re: My snotty filthy new Bridgeport milling machine
« Reply #1 on: March 22, 2013, 09:38:21 PM »
I just looked up the serial number...it is a 1961.  8)
Online scottly
« Reply #2 on: March 22, 2013, 09:46:20 PM »
Hey, snotty filthy is better than dry, rusty, and crusty! 8)
« Reply #3 on: March 22, 2013, 10:00:09 PM »
Can't wait to see what you can make with that. What's first on the play sheet?
« Reply #4 on: March 22, 2013, 11:28:39 PM »
Nice score your honor    8)
Offline BLUE71TURBO
« Reply #5 on: March 23, 2013, 12:09:42 AM »
 Now come's the real " VERY EXPENSIVE " fun part.....accumulating the tooling to do all those fun projects !    :o :o :o
 I know this from hanging with my best friend who is a retired machinist from Santa Fe Railroad. The amount of tooling and knowledge he has is amazing. Everyday i learn something new from him. The first major piece's to add will be a rotory table and a clamp like the one in the picture below.  ;)
  Here is the mill i use with digital readout attached..........
« Last Edit: March 23, 2013, 12:11:26 AM by BLUE71TURBO »
« Reply #6 on: March 23, 2013, 02:29:44 AM »
i just got this russian stanko..  tool maschinery are just great ..all can be done..just get a idea and do it....
Offline faux fiddy
  • bike in a box
« Reply #7 on: March 23, 2013, 04:23:14 AM »
You musta got a deal?
Fixer uppers  if you can make them accurate you end up with the advantage a shop full of useable machines  and none of the disadvantages of $350,000 of debt
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline faux fiddy
  • bike in a box
« Reply #8 on: March 23, 2013, 04:31:53 AM »
....from what I gather they go for $3500 most anywhere and in a wide range  of conditions, but there are deals to be had.  A friend just picked a  surface grinder that a guy wanted to keep together but only asked 3,000# scrap price for it .
« Reply #9 on: March 23, 2013, 04:38:23 AM »
I have a rotary table and a couple 6" vices already. My first plan is to use it for cleaning up my alloy points covers. I have been trying to program a CNC lathe to do the simple contour...frigging thing don't like me. Rotary table, 45° angle turn turn turn. I am thinking about putting a stepper motor onto the table.....
Offline faux fiddy
  • bike in a box
« Reply #10 on: March 23, 2013, 04:42:11 AM »
Practical machinist forum? I think that's what it's called. My buddy is on there, setting up a 4 axis cnc.
« Last Edit: March 23, 2013, 04:43:50 AM by faux fiddy »
« Reply #11 on: March 23, 2013, 04:59:52 AM »
I just joined last night! "frankenstuff" is the name. I have been going there a lot to see how things move and come apart.
I built a small 3 axis cnc east year. Rather than converting this mill into CNC I am going to build a 3 axis table....to sit on the table. Only needs about 2" in the z. Just a daydream right now. What I really need is a frigging garage or building to use. Basement no good no more.
Offline 333
  • Time for change
« Reply #12 on: March 23, 2013, 06:43:56 PM »
I might have mentioned this before; OWWM.org. (Old Wood Working Machines).  Because of the demand, they added a metal working area about a year ago. Great resource.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
« Reply #13 on: March 23, 2013, 06:46:36 PM »
Thanks for the tip Stan. I did some cleaning up my new woodshop area.
It is going to be a busy summer. After the mill I still have to move the band saw.
Offline faux fiddy
  • bike in a box
« Reply #14 on: March 23, 2013, 10:43:35 PM »
 You can do some stuff with a turntable. Adds an axis (?)
Those guys at practical machinist are where to go. Those guys have a lot of sh8 in their necks about how to ....
« Last Edit: March 23, 2013, 10:45:27 PM by faux fiddy »
« Reply #15 on: March 25, 2013, 09:17:52 PM »
Yeah so, I got kicked out of work with the mill. I am now
 doing the cleanup in my basement. All of the rust looking stuff is
mahogany dust. This mill was used in a pattern making shop in the 60's
and 70's. Fun fun fun. I am 3 hours and 2 glasses of scotch into the
cleanup......
« Reply #16 on: March 28, 2013, 07:13:54 PM »
Blue turbo man- I am looking into getting a phase converter so I can just plug the mill into my  220 dryer outlet......what do you think?
Offline BLUE71TURBO
« Reply #17 on: March 29, 2013, 11:45:36 PM »
 Mr. " F "  I'm the last guy you wanna talk electrical stuff with, but i found this on the web..........
                       http://www.garagejournal.com/forum/archive/index.php/t-116503.html
  Hope this helps ya !   ;)
« Reply #18 on: March 30, 2013, 01:58:01 AM »
in denmark,,north europa, ve have 400 volt 3 fase..ve can drive a 3 fase engine with a kondensator..to kompensate for 2 fases..but the engine loose 1/3 of power.(.but aur 1 fase are 240 volt 16 amps..)
if you not are use the mashine for hard vork..it can fine vork on 2/3 power..i have a diragram for kondensator yf kapasity/hk/kw..at min work.( elektro revinding shop.) takes a few days before i get there
the kond kosts nothing..but you gets not the free rpm as the converder gives
« Reply #19 on: March 30, 2013, 04:31:02 PM »
Bought a static phase converter for the mill. Like styro says, I will lose a bit of HP but....I am not doing heavy stuff.
« Reply #20 on: March 30, 2013, 09:24:28 PM »
I used to run a pricey Delta RotoPhase..7.5 hp max,  multiples up to 25 hp total..worked well.
 So are you going to get one for the bandsaw too.?
Online scottly
« Reply #21 on: March 31, 2013, 07:42:23 PM »
I have a rotary phase converter on my BP that was made from a used 3 phase motor, with some capacitors and some other device. I'm guessing the motor may be 5 HP, and it works fine for my 2 HP spindle motor, but it wouldn't run a 3 HP series2 BP. (That's why I ended up with it ;D)
Offline faux fiddy
  • bike in a box
« Reply #22 on: April 09, 2013, 08:35:39 AM »
The electrician is working on the phase converter this month. Ea$ier than stringing  it  up from the nearest pole which costs in excess of $10k.
« Reply #23 on: May 05, 2013, 06:51:55 PM »
I just got the bed off and into the basement.
« Reply #24 on: May 05, 2013, 07:05:40 PM »
how ya gonna get the rest of it down there?!
