While working on the new 750 this evening, I ran into some obstacles with the front sprocket; three obstacles to be exact. I would very much appreciate some help.
Here's the backstory:
The bike is a 1975 750F with 1978 750K motor. I bought a 17T front sprocket, 48T rear sprocket and a 530 chain because, from what I understand, the conversion is supposed to be pretty straight forward. I am aware that the '78 motor with '75 swingarm causes an offset issue and will wear the chain unevenly; at the moment I am not worried about that.
Issue 1:
What is the sizing of the central bolt? The one I removed had a head size of 13mm which struck me as being very odd. I had imagined that it should've been a 12mm.
Issue 2:
This sprocket (existing) sits flush against the shaft end.
This sprocket (new) sits proud of the shaft and will not pull in any closer.
What do I do about this alignment? To do this conversion, does the counter sprocket
have to be milled down? Maybe I read the wrong threads.
Issue 3:
Do I reinstall the washer (in first picture) after the conversion? It's very possible that this is a stupid question, but I am wondering if the 1975 sprocket fixing plate works instead.
