Author Topic: Strange question - anyone flipped their cylinders/head around?  (Read 5959 times)
Offline nick5446
I've seen it done on a handful of old Triumphs, but never on a CB. I've got a "nothing to lose" type of project going on and was thinking about trying it if it seems do-able. I'd love to have the carbs sticking out front sucking in cold air and the pipes going straight out the back.
I don't know a lot about Triumphs, but I've heard it's an easy switch. The only big issue I can see on the CB750 is the cam chain spinning the wrong way. I'm having a tough time wrapping my brain around how I could work around this. The other issue would be bolt holes potentially not lining up, but I should be able to work around that if I can figure out the cam chain. The frame is/will be totally custom so I should be able to make everything fit.
Picture for reference.
Offline DJ_AX
Re: Strange question - anyone flipped their cylinders/head around?
« Reply #1 on: April 30, 2013, 11:59:39 AM »
I don't know the answer to your question .... but ... Why?
Offline nick5446
« Reply #2 on: April 30, 2013, 12:04:40 PM »
Why not?
Offline cabrala
  • Super Duper
« Reply #3 on: April 30, 2013, 12:43:29 PM »
Yes it has been done. I agree with the "why" and will accept your "why not". There is plenty of reading in the link below.
http://forums.sohc4.net/index.php?topic=80234.0
Interesting to note is that there seems to be no information about that bike being finished or running for that matter. Much of the debate in that thread was about how the engine would perform, but the OP never laid down the proof.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
Offline pangloss
  • CB500 K2 1975 NZ model
« Reply #4 on: April 30, 2013, 12:56:18 PM »
That's not an engine. It's a sculpture... Anyway triumph is easy coz its twin cams which can be switched front to back
Offline nick5446
« Reply #5 on: April 30, 2013, 12:58:55 PM »
That makes sense, thanks!
Offline nick5446
« Reply #6 on: April 30, 2013, 12:59:21 PM »
I got some reading to do, thanks!
Offline iron_worker
« Reply #7 on: April 30, 2013, 01:12:23 PM »
You could potentially get a custom cam ground for a reverse rotation engine but I can't imagine it would be cheap.
If you flip the cylinders then the oil pressure and return lines won't line up with the case anymore. If you don't flip the cylinders then your chain tensioner is on the wrong side.
There will be a myriad of problems you'll encounter and they will require some custom design and machine work to overcome I believe. It's an interesting idea but seems a bit far fetched.
IW
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #8 on: April 30, 2013, 01:16:55 PM »
Keep posting here if you do this! I'd love to see this insanity happening!  ;D
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline nick5446
« Reply #9 on: April 30, 2013, 01:20:29 PM »
Yeah, looking over that 550 thread it's not looking too promising. A custom cam would work, but like you said, not cheap.
Oh well, not heart broken, just wanted to look into it.
« Reply #10 on: April 30, 2013, 01:54:10 PM »
...and all the popcorn a poppin'...
Offline DustyRags
« Reply #11 on: April 30, 2013, 02:34:02 PM »
Hey, never forget, some lunatic built one with a sideways engine: http://forums.sohc4.net/index.php?topic=116469.msg1337072#msg1337072
1976 CB550K- sold
Offline nick5446
« Reply #12 on: April 30, 2013, 03:36:08 PM »
Hahaha....now THAT is something I can get behind.
I'm going to pull the motor out of the frame tonight and strip the paint off of each of them and see what I'm working with.
Someone mentioned that if I flipped it all over, and the cam was spinning in reverse, I could maybe adjust the timing 180 and then I'd be all good. Any thoughts on that?
By the way, this is a Hondamatic that I'm working with, so it's going to be an odd bike no matter which way the motor faces.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #13 on: April 30, 2013, 03:44:36 PM »
Some how missed that one. Having looked now, how does that exhaust arrangement impact engine performance? Must require some compensation mods??
« Reply #14 on: April 30, 2013, 03:55:09 PM »
Cam can be  turned, lf you run an external belt drive...one problem solved..
Where you at.. I have worked on stranger parts before....like the CHEVarlay..
« Last Edit: April 30, 2013, 10:00:11 PM by 754 »
Offline nick5446
« Reply #15 on: April 30, 2013, 04:04:07 PM »
Cam can be  turned, l you runan external belt drive...one problem solved..
I'm a little ways south of you in Portland, OR
Offline Schnell
« Reply #16 on: April 30, 2013, 05:17:13 PM »
That explains some. I've heard of the lenient pot laws there.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline brewsky
« Reply #17 on: May 01, 2013, 03:34:02 AM »
It actually does make sense from an efficiency standpoint, as the intake and exhaust flows wouldn't have to turn 180 degrees each to get where they are going.
Yamaha started using the "reverse head" design on the YZ450F in 2010.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline LesterPiglet
  • 1977 CB550F2
Offline lrutt
« Reply #19 on: May 01, 2013, 04:46:50 AM »
Have to keep in mind that on an air cooled motor it is especially important to keep the exhaust valves / seats / ports cool to prevent distortion / cracking. hard to do when they would be on the back side.
Offline cabrala
  • Super Duper
« Reply #20 on: May 01, 2013, 05:21:23 AM »
What about this then?
http://www.dwmsracing.com/forum/index.php?topic=14.0
I linked to his SOHC4 thread above. Seems like your link might be the place to keep track of recent progress.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
  • 1977 CB550F2
« Reply #21 on: May 01, 2013, 06:09:09 AM »
I wonder how I missed that.
Offline Xnavylfr
« Reply #22 on: May 01, 2013, 06:48:59 AM »
Here you go guys/gals something else to wrap your brain around!!!
http://hondachopper.yuku.com/topic/50336/1975-8-cylinder-Honda-engine#.UYEc10pLkg8
Xnavylfr(CHUCK)
Offline Schnell
« Reply #23 on: May 01, 2013, 07:26:55 AM »
Xnavylfr(CHUCK)
Conjoined quads!
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
« Reply #24 on: May 01, 2013, 07:51:36 AM »
Cool, have not seen him on here much. I have a small bmw rear end NOS that may be of use to him with that setup.
