Author Topic: Recommendations for 18" Non-Spoked Wheels  (Read 1882 times)
« on: June 04, 2013, 04:19:17 PM »
I am thinking of going with matching front and rear 18" wheels on an upcoming CB750K2 project, but with mag-style wheels.  Lester and Morris made 18"R/19"F, but I can't find a source for matching 18" wheels front and rear that will fit without too much brain damage.
Re: Recommendations for 18" Non-Spoked Wheels
« Reply #1 on: June 05, 2013, 09:45:51 AM »
Anyone??
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #2 on: June 05, 2013, 10:11:23 AM »
KZ wheels
 i used the wheelks from 81-82 kz750
« Last Edit: June 05, 2013, 10:15:53 AM by KRONUS0100 »
MATT
Offline madScientist
« Reply #3 on: June 05, 2013, 10:45:12 AM »
Did you have to modify those at all or did they bolt right up?
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline goldarrow
  • one day, i'll be an
« Reply #4 on: June 05, 2013, 03:22:06 PM »
18" front are seldom come by.  I have a pair of Henry Abe 18 front and rear, but the wheels are set up for 400F bikes.  they would look wayyyy too skinny on 750 bikes, plust won't properly fit on the 750 swingarms.
CB550 K0
Offline KRONUS0100
« Reply #5 on: June 05, 2013, 07:36:05 PM »
rear wheel you need the axle, spacers and conversion bearings to the cb750 axle.  also will need to bore the rear caliper mount to accept the honda axle.  front end is basically a bolt on if you allready have dual discs up front.  the kz speedo cable hooks up to the cb speedo...just have to make a spacer for the caliper mounting brackets........the pads fit the rotors exactly where they should even tho the rotors are slightly smaller.   oh yea............you have to replace the rear wheel inner bearing spacer with 1 that fits the honda axle.................i used a piece of pipe i had laying around that fit perfect
MATT
« Reply #6 on: June 05, 2013, 09:55:58 PM »
Early GSXR750-1100 wheels, not much to make them fit and they look great, 18 inch front and rear,  rear disc though...
Offline goldarrow
« Reply #7 on: June 05, 2013, 10:00:06 PM »
Retro, awesome bike :)
CB550 K0
« Reply #8 on: June 05, 2013, 10:31:48 PM »
Heinz the owner is a member here, his handle is CB500four... ;)
Offline 750K
« Reply #9 on: June 06, 2013, 12:40:50 AM »
There's a set of 18" front and rear Henry Abe's of of a 74 c 750 on fleabay right now, Although the rear has been converted to disc brakes.
77 Cb750, 78 Kz1000
Offline goldarrow
« Reply #10 on: June 06, 2013, 05:33:56 AM »
Those are not Henry Abe wheels
CB550 K0
Offline 750K
« Reply #11 on: June 06, 2013, 04:45:36 PM »
 ^^^Whatever they are their both 18's
77 Cb750, 78 Kz1000
Offline goldarrow
« Reply #12 on: June 06, 2013, 05:27:27 PM »
Link? May be I'm looking at different one
CB550 K0
« Reply #13 on: June 06, 2013, 06:48:25 PM »
Sick!!
« Reply #14 on: June 06, 2013, 06:54:52 PM »
Sick
Yes, it sure is nice... ;)  It also has a modified early GSXR750 swingarm.... ;)
Offline 750K
« Reply #15 on: June 06, 2013, 08:04:25 PM »
Not sure how to link from the eBay phone app, I was wrong about both being 18's. I just double checked and it's a 19 front and an 18 rear.
77 Cb750, 78 Kz1000
