Author Topic: CB550 charges at times  (Read 1535 times)
Offline Glaede
« on: June 12, 2013, 01:53:57 AM »
Hi guys
I have a charging issue with my bike. I thought it was down to a bad regulator/rectifier, so I bought a new unit of ebay. The thing is that the bike is only charging properly at times. For example, yesterday I changed to the new regulator/rectifier and measured a nice steady charge of 13.8-14v. Took it for a spin and it rode beautifully and pulled strong. When I got home I took another measurement and now it was only like 12.8v. How could this be? I had the same problem with my old regulator and rectifier (org. setup), so I think I can eliminate that. Could a bad battery refuse to "accept" the charge? I don't think its the battery though, since I have no problem charging it with my charger..
Offline trueblue
Re: CB550 charges at times
« Reply #1 on: June 12, 2013, 03:25:07 AM »
Sounds like you either have a bad connection somewhere or a broken wire.  First place to check is under the chain cover on the engine, there should be 3 bullet connectors under there on the yellow wires that come from the stator.  It is pretty common for these to come loose and give intermittent charge issues ;D
1979 CB650Z
Offline Glaede
« Reply #2 on: June 12, 2013, 03:48:39 AM »
Okay thanks, well I did pull the cover a few weeks ago to change the gear shaft seal and I noticed a green/white wire as far as I recall from the stator, but I didn't see any yellow ones (or maybe I just didn't pay attention). Should they come out of the stator or where should I be able to find them?
Offline trueblue
« Reply #3 on: June 12, 2013, 03:59:45 AM »
I'm pretty sure that's where they are, there are 3 yellow wires that come from under the stator cover, then up and behind the cylinders.  They are the AC voltage wires from the alternator that run up to the rectifier.
1979 CB650Z
Offline Glaede
« Reply #4 on: June 12, 2013, 04:01:37 AM »
Great, well I do have the yellow wires at the regulator, so they must be there somewhere ;-)
But thanks again, I'll try finding them and take a look at it!
Offline trueblue
« Reply #5 on: June 12, 2013, 04:05:44 AM »
Let us know how you get on
1979 CB650Z
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: June 12, 2013, 04:17:49 AM »
Stuartni had a charging problem, turns out his Ebay reg/rec was faulty. Maybe check it out.
Offline Glaede
« Reply #7 on: June 12, 2013, 04:19:47 AM »
Okay, well I don't think that's my problem since I had the same issue with my old original regulator/rectifier setup. With my new setup it does charge better (higher voltage at lower rpms), but still doesn't charge properly all the time.
Offline kghost
« Reply #8 on: June 12, 2013, 06:05:34 AM »
Where are you measuring the voltage at?
What RPM are you getting the readings at?
Remember a discharged battery will initially draw more voltage.
After a ride (and the subsequent battery charging) 12.8 is not uncommon at Idle.
Stranger in a strange land
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #9 on: June 12, 2013, 07:44:58 AM »
Here try this FAQ:
http://www.oregonmotorcycleparts.com/FAQ.html
its your best bet instead of buying parts willy nilly that you may or may not need.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline strynboen
« Reply #10 on: June 12, 2013, 09:47:11 AM »
here are the yellow vires..and how they are plugged in the stator and rotor/elektro magenet
you can send it to "langelands elektro"..and i vill thek it aut for  free
i hate all this v-w.... vords
« Reply #11 on: June 12, 2013, 10:00:45 AM »
From the shop manual
Offline kghost
« Reply #12 on: June 13, 2013, 12:34:55 AM »
Same thought I had Lloyd lol
Offline Pasoren
« Reply #13 on: May 26, 2014, 12:54:30 PM »
Hi
Did you find the fault? I have the same problem...
Offline Glaede
« Reply #14 on: May 26, 2014, 11:28:59 PM »
Well, I think my fault was due to corroded wires, so I took some householding vinegar in a plastic bag and strapped it around the different plugs that needed attention. After that I gave it some contact cleaner and put it all together again. Since that I can't remember having charging issues.
