Author Topic: Alternative oil pressure sensor replacement.  (Read 4497 times)
Offline Joemac
« on: June 17, 2013, 08:15:00 PM »
Howdy
So my 550 is going through some oil pressure issues so i'd like to replace my current sensor so I can rule it out.  Though the Honda part seems a liiiittle pricey.  Any recommendations for a more affordable alternative?
Things I have consider are; the psi at which the switch engages, thread size, and overall size of the unit so it fits within the cover.. correct? (id prefer not having to modify one.)
Does this unit fit the criteria?
http://www.autopartswarehouse.com/sku/Suzuki/XL-7/Replacement/Oil_Pressure_Switch/2003/REPT311401.html?apwcid=productads&003=27846857&010=apwREPT3114012003suxloiprsw&gclid=CLmisY7L7LcCFQE6QgodSysAAA
thanks in advance
Offline trueblue
Re: Alternative oil pressure sensor replacement.
« Reply #1 on: June 18, 2013, 04:05:16 AM »
PSI will be fine, I'm pretty sure the Honda's use an 1/8 NPT thread, only thing I can't guarantee is it will fit behind the cover.  The original one is fairly large though, so shouldn't be too much of an issue.
1979 CB650Z
Offline Joemac
« Reply #2 on: June 18, 2013, 08:46:29 AM »
thanks for the heads up.  the listing says its 1/8 in. x 28 NPT,  is that "28" figure something I should consider first?
« Reply #3 on: June 18, 2013, 10:30:51 AM »
that would be number of thread per inch.
http://en.wikipedia.org/wiki/National_pipe_thread
thread size and pitch have to match.
Offline Joemac
« Reply #4 on: June 18, 2013, 04:01:35 PM »
Cool, i have a die cutting set with tools to measure the threads.  That could have been a very costly mistake, trying to fit the wrong two sizes together.  thanks
bollingball
« Reply #5 on: June 18, 2013, 04:25:24 PM »
Have you considered a remote gauge? I like one mounted between the clocks right in your face with a light for the night.green looks good at night. IMO.
Ken
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: June 18, 2013, 04:29:54 PM »
Ken
Got pics and a link? Either or, preferably both. :)
« Reply #7 on: June 18, 2013, 05:37:13 PM »
There is a guy here who offers something like that - in services offered.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #8 on: June 19, 2013, 09:02:53 AM »
Howdy
thanks in advance
I found an oil sender unit for a 1980s Civic from NAPA that was cheaper and fit just fine.
My problem was it worked fine but was leaking too much oil.
Offline Joemac
« Reply #9 on: June 19, 2013, 09:33:29 AM »
Ken
Speak of the devil, I was just in Pepboys last night looking at parts to rig one.  I've done a few thread searches on them and saw some neat examples, some up top some by your feet.  Definitely something i'll be installing soon.
Offline Joemac
« Reply #10 on: June 19, 2013, 09:34:20 AM »
Howdy
thanks in advance
w/ teflon on the threads?
Offline iron_worker
« Reply #11 on: June 19, 2013, 10:29:47 AM »
If you just want a gauge you could try something like one of these:
http://www.cyclexchange.net/Oil%20System%20Comp%20Page.htm (about half way down the page)
They are meant to replace the oil gallery plug but are for a 750.
You could do something similar on a 550 I'm sure. Drill and tap one of the oil gallery plugs for a pressure gauge.
IW
« Reply #12 on: June 19, 2013, 12:13:49 PM »
Howdy
thanks in advance
It wasn't leaking from the threads, it was wore out and ready for replacement.
Offline Joemac
« Reply #13 on: June 19, 2013, 02:59:21 PM »
IW
Now that I think about it...Could I just install it where the oil pressure sensor is?  Then drill a hole through the left cover and rig the gauge externally
Offline iron_worker
« Reply #14 on: June 19, 2013, 03:07:03 PM »
Sounds feasible. So long as you can get a gauge with the same thread, drill and retap for the size you need, or rig up some type of adapter. You'll also need some flexible tubing but I think probably comes with any mechanical pressure gauge you would buy for automotive uses.
IW
Offline Dream750
« Reply #15 on: June 20, 2013, 05:04:01 AM »
Forum member: Terry in Australia made a clean and impressive looking remote oil pressure gauge setup for a 550, see the pics in reply #11 of this thread:
http://forums.sohc4.net/index.php?topic=61551.0;nowap
Also, forum member: Midnight 08 makes an interesting dual purpose gauge adapter:
http://forums.sohc4.net/index.php?topic=114969.0
Anyone remember the dash mount (circa 1973-74) “SuperByke” kit with the backlight gauge?
Offline Joemac
« Reply #16 on: June 20, 2013, 09:07:19 AM »
I dig Terrys setup, very clean looking and might be the right choice, but Im a little apprehensive about its location and the possibility of it breaking off.
also..Is there much worry about shavings getting inside the case when drilling and tapping into that gallery plug?
I was actually looking at this thread last night, then I could keep the oil pressure sensor and have a gauge as well, seemed neat.  Though it wont fit with how the 550's oilpump is setup...unless I cut some holes in the chain cover and have the adapter outside. But that means the sensor would have to be outside...exposed to the elements and well, looking ugly. haha
Ill think about the adapter... but for now, heres some pics i took from the internet and with my amazing Michelangelo painting skills, presents what I had in mind..
Id cut the chain cover two spots and feed a hose up through the top
Offline Joemac
« Reply #17 on: June 20, 2013, 09:09:08 AM »
chain cover cuts
Offline 23tbucket
« Reply #18 on: June 20, 2013, 07:14:41 PM »
Just a side note: The oil sender threads are 1/8" BSPT not 1/8" NPT. There is a different number of threads per inch and the pitches between the two are slightly different as well. You can cross thread 1/8" NPT in there and it probably won't leak, but it's not right.
