Author Topic: Remove and Install CB500 engine on its side  (Read 1327 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« on: June 24, 2013, 06:05:51 PM »
Hello,
       I found a post once that showed a  cb500 engine installed in the frame with the engine on its side. Does anyone have a post and/or pics of this being done. Or is it easier to install with the frame upright. Newly painted frame don't want to scratch.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline goldarrow
  • one day, i'll be an
Re: Remove and Install CB500 engine on its side
« Reply #1 on: June 24, 2013, 07:02:42 PM »
Remove the oil filter and frame should drop over the engine, as it lay on the right side.  You can also wrap the frame with rags or towels wherever necessary.
CB550 K0
Offline MotorFist
    • MotorFist
« Reply #2 on: June 24, 2013, 07:17:11 PM »
+1
And when in doubt about scratching something, wrap it in masking tape.
I had to remove the sump cover on my wife's 400 for this trick to work. Unfortunately, I learned about it AFTER I did my 500.
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline rtbmrgl
« Reply #3 on: June 24, 2013, 09:14:44 PM »
Thanks for the info, opted not to power coat the frame and paint it instead. Will have to be a little careful as not to scratch the paint. Going to try a new clear coat, SprayMax 2K Clear Coat, suppose to be harder than regular.
thanks again.
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #4 on: July 13, 2013, 11:35:09 AM »
Got the engine in the frame without a making a scratch, thanks
thanks, Mark
Roseville, Ca
Got Points!
Offline MotorFist
    • MotorFist
« Reply #5 on: July 15, 2013, 08:29:24 AM »
Congrats man! What did you paint your engine with? It looks great
77 CB400 (Hers)
68 CB160
72 CL350
70 A65 Lightning
72 DT250
16 TE300
Offline rtbmrgl
« Reply #6 on: July 17, 2013, 10:11:51 AM »
Thanks, I painted with VHT engine enamel,
SP995 Nu-Castâ„¢ Aluminum
SP145 Gloss Clear
I painted the engine about a month ago so its had time to dry, I've already spelt gas on the engine and it didn't effect the the surface.
thanks, Mark
Roseville, Ca
Got Points!
« Reply #7 on: July 17, 2013, 10:18:17 AM »
Also exhaust studs are good to remove if your engine has them.
